| Autoworld.com.my |
Apr 1 2011, 06:02 PM
Post
Probation ![]() Group: Members Posts: 21 Joined: 15-November 05 Member No.: 53,901 |
hi folks, need a bit of advice here.
went to service my car at umw recently - 2005 altis. they inspected and told me 'FRT LHS driveshaft boots torn' and it needs to be replaced. estimated costs RM900!!!!! 1. pls dun mind but what is this driveshaft boots thing? 2. can i continue to drive and for roughly how long?? will it be dangerous? knowing our legendary umw service centers - it takes forever to get an appointment and it's gonna take whole day to replace 3. any cheaper alternative? 900 is big sum thanks |
Apr 1 2011, 07:56 PM
Post
![]() Road Warrior ![]() ![]() Group: Members Posts: 576 Joined: 11-August 10 Member No.: 96,492 |
Go outside workshop...........cheaper!!!! Try google then u know better....
Apr 1 2011, 09:02 PM
Post
Taxi Driver ![]() ![]() Group: Members Posts: 369 Joined: 16-December 09 Member No.: 91,933 |
To answer your queries:
1) driveshaft boots is driveshaft cover (in layman term) 2) The car is still driveable, but i suggest get it replaced ASAP to reduced chances of costly replacement. This is because torned driveshaft boots may allows water/sand to enter driveshaft head, by that time, whole driveshaft head will need replacement. 3) You can refer to outside workshop for cheaper replacement if you have a regular workshop and/or foreman. FYI, torn driveshaft boots is quite common for Vios after 5 - 6 years. For Vios and maybe Altis driver, i suggest get this thing inspected if your ride is more than 5 years. |
Apr 2 2011, 04:43 PM
Post
Taxi Driver ![]() ![]() Group: Members Posts: 316 Joined: 1-January 04 From: Putra Heights Member No.: 32,700 |
Bro.. the rubber boot should cost 50 bucks or less.
Can you ask them why it cost so much. Get a Itemised quote.... This is rubbish...... I suggest get it down outside... |
Apr 5 2011, 11:50 PM
Post
Member ![]() Group: Members Posts: 16 Joined: 24-October 02 Member No.: 23,188 |
Last saturday, just changed RHS driveshaft boots for my Vios Yr 2006, Cost
2pcs boot $35 X 2 = $70 Transmission oil Top up = $20 Greese = $10 Workmanship = $35 Total cost $135/=. Time taken about 2 hours. Did it at Winner Tyre Shop, behind Honda showroom at Jalan TAR, KL. Look for Ah Kit. Very satisfied and good workmanship. |
Apr 10 2011, 10:22 PM
Post
thanks guys.
i just changed today. found back my old workshop. rm38 new cover - one side only. the other side still alright rm35 workmanship total rm73 my mechanic did mention that the part is japan part and not original which costs more. my shop is at sidestreet parallel to lokeyew near the old fajar sg besi thanks for the lead about the jalan tar workshop too! the 1st verbal quote i got was from umw cheras. wat's wrong wif these ppl? rm900.. |
Apr 12 2011, 09:53 PM
Post
Road Warrior ![]() ![]() Group: Members Posts: 650 Joined: 13-July 04 Member No.: 38,018 |
thanks guys. i just changed today. found back my old workshop. rm38 new cover - one side only. the other side still alright rm35 workmanship total rm73 my mechanic did mention that the part is japan part and not original which costs more. my shop is at sidestreet parallel to lokeyew near the old fajar sg besi thanks for the lead about the jalan tar workshop too! the 1st verbal quote i got was from umw cheras. wat's wrong wif these ppl? rm900.. My camry changed 4 boots n oilseal cost rm258. Toyota quote RM 700 perpiece |
Jan 1 2013, 05:29 PM
Post
6th Gear Group: Members Posts: 6 Joined: 1-January 13 Member No.: 125,877 |
Guys any recommendation of such work (replacing of driveshaft boot) in puchong or subang area?
Feb 3 2013, 08:53 AM
Post
Taxi Driver ![]() ![]() Group: Members Posts: 289 Joined: 6-October 05 Member No.: 52,776 |
Altis driveshafts spoilt every 4 years, many altis owner experience this due to low quality.
Feb 3 2013, 03:39 PM
Post
White Lightning ![]() ![]() ![]() Group: Members Posts: 6,863 Joined: 2-September 00 Member No.: 551 |
Guys any recommendation of such work (replacing of driveshaft boot) in puchong or subang area? Any good workshop should be able to do this for you. You should ask them to check the driveshaft boots every time you service the car. Replacing torn boots is a simple thing and the spare parts do not cost a fortune either. -------------------- Regards,
Flee ![]() |
Lo-Fi Version | Powered By IP.Board © 2008 IPS, Inc | Time is now: 24th May 2013 - 08:42 AM |
