| Autoworld.com.my |
Apr 21 2010, 03:36 PM
Post
Advanced ![]() Group: Members Posts: 91 Joined: 3-March 05 Member No.: 45,529 |
Good day,
Can anyone recommend a good replacement absorber for Honda City Type Z SX8? I am thinking to change to Monroe. Anyone knows the price range and buying from where? Any other recommendation? Please state the product name, price and where to buy. The current situation is very noisy "kok kok kok" sound traveling on uneven surface. Went to the workshop to check the lower arm and ball joint. They jacked up the car to inspect. They said no physical sign of damage of the lower arm and ball joint. When turning, no noisy sound. Only on uneven surface. Therefore, they said the absorber is "kong". Should I change the absorber bush as well? Thank you in advance? |
Apr 21 2010, 05:43 PM
Post
![]() Forum Ninja ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 64,143 Joined: 11-November 04 From: Petaling Jaya Member No.: 41,856 |
Good day, Can anyone recommend a good replacement absorber for Honda City Type Z SX8? I am thinking to change to Monroe. Anyone knows the price range and buying from where? Any other recommendation? Please state the product name, price and where to buy. The current situation is very noisy "kok kok kok" sound traveling on uneven surface. Went to the workshop to check the lower arm and ball joint. They jacked up the car to inspect. They said no physical sign of damage of the lower arm and ball joint. When turning, no noisy sound. Only on uneven surface. Therefore, they said the absorber is "kong". Should I change the absorber bush as well? Thank you in advance? Try checking with Leon of Quicksave or Sifu Drex of EA Auto, whether they have the dampers for your ride..... -------------------- ![]() |
Apr 26 2010, 09:13 PM
Post
Road Warrior ![]() ![]() Group: Members Posts: 838 Joined: 30-March 05 Member No.: 46,591 |
Good day, Can anyone recommend a good replacement absorber for Honda City Type Z SX8? I am thinking to change to Monroe. Anyone knows the price range and buying from where? Any other recommendation? Please state the product name, price and where to buy. The current situation is very noisy "kok kok kok" sound traveling on uneven surface. Went to the workshop to check the lower arm and ball joint. They jacked up the car to inspect. They said no physical sign of damage of the lower arm and ball joint. When turning, no noisy sound. Only on uneven surface. Therefore, they said the absorber is "kong". Should I change the absorber bush as well? Thank you in advance? I would suggest that you should check on the Absorber Mounting, too. |
Apr 26 2010, 09:18 PM
Post
I would suggest that you should check on the Absorber Mounting, too. Especially the front ones.... -------------------- ![]() |
Apr 27 2010, 11:15 PM
Post
I went to spare part shop to make inquiry. They asked me to check the front mounting bearing also. There is a bearing in the mounting. RM 60 each. Original shock front RM 160 per pc, rear RM 170 per pc. Front mounting RM 60 per pc.
Apr 28 2010, 10:23 AM
Post
I went to spare part shop to make inquiry. They asked me to check the front mounting bearing also. There is a bearing in the mounting. RM 60 each. Original shock front RM 160 per pc, rear RM 170 per pc. Front mounting RM 60 per pc. Normally the front shocks should be more expensive..... -------------------- ![]() |
May 3 2010, 02:45 PM
Post
1st Gear Group: Members Posts: 1 Joined: 3-May 10 Member No.: 94,462 |
Good day, Can anyone recommend a good replacement absorber for Honda City Type Z SX8? I am thinking to change to Monroe. Anyone knows the price range and buying from where? Any other recommendation? Please state the product name, price and where to buy. The current situation is very noisy "kok kok kok" sound traveling on uneven surface. Went to the workshop to check the lower arm and ball joint. They jacked up the car to inspect. They said no physical sign of damage of the lower arm and ball joint. When turning, no noisy sound. Only on uneven surface. Therefore, they said the absorber is "kong". Should I change the absorber bush as well? Thank you in advance? Maaf mencelah sket, saya ada pakai Honda SM4 1991, keta ni saya baru buat cat `in & out' masalahnya lining cermin belakang dah rosak masa buka ari tu. Dah puas saya cuba dapatkan ganti, tapi sampai sekarang lum dapat lagi. kalau ada sesiapa yang boleh dapatkan minta tolong sms saya 0125281064, kalau bleh nak tau arganya sekali. Pakat tolong reramai ya. |
May 5 2010, 12:59 AM
Post
Maaf mencelah sket, saya ada pakai Honda SM4 1991, keta ni saya baru buat cat `in & out' masalahnya lining cermin belakang dah rosak masa buka ari tu. Dah puas saya cuba dapatkan ganti, tapi sampai sekarang lum dapat lagi. kalau ada sesiapa yang boleh dapatkan minta tolong sms saya 0125281064, kalau bleh nak tau arganya sekali. Pakat tolong reramai ya. Please try this webpage http://www.facebook.com/group.php?gid=3217...wall&ref=ss or http://kirie-auto.blogspot.com/search/label/Rubber%20Seal Found these 2 webapges are very useful for City drivers. |
May 5 2010, 11:09 AM
Post
Please try this webpage http://www.facebook.com/group.php?gid=3217...wall&ref=ss or http://kirie-auto.blogspot.com/search/label/Rubber%20Seal Found these 2 webapges are very useful for City drivers. His SM4 is Honda Accord from 1990 to 1993 -------------------- ![]() |
May 5 2010, 11:27 PM
Post
Lo-Fi Version | Powered By IP.Board © 2008 IPS, Inc | Time is now: 19th May 2013 - 04:29 AM |
