QUOTE (scifu @ Mar 11 2010, 03:29 PM) <{POST_SNAPBACK}>
Hi CYC,
1. Pressure regulation fault - if this unit broke, it must be a fault CODE in the computer Diagnose report. Is it? But i will take note of this as if i repalce the ATF, still got the same problem. EVM sensor - noted.
2. Will consider if the problem arise again. Gear Knob sort of cable - noted.
Haa.. rite, this is what happen to my lion (engine die off during cold start and low speed). Thats why BB and kauntan SC repalce the idle stepper motor (twice already). Becoz it appear in the computer diagnose report stated "idle stepper motor permanent fault".
Tq CYC..
Tq CYC..
Scifu,
It won show Pressure Regulation Fault during Diagnose, unless u drive ur car to diagnose when both lights are in blinking mode.
The Low speed die off might also happened when the ignition valve miss firing or the connector of Stepper motor rusted.
