Vios 1st Gen Facelift 2006
Posted 08 March 2010 - 01:57 AM
when engine is switch off at the engine still hot temperature, interval like 10 mins, start again, NO PROBLEM.
when cold start, NO PROBLEM,
but if driving for 30 min and above then off the engine for 1 or 2 hours (for lunch), it will need 2 time of crank just can fire the engine!
i didn't do any modification on my car at all
below is what the latest major service i done recently and the return to the workshop for the complaint service.
BUT TOYOTA STILL DIDN'T FIX MY CRANK START PROBLEM!
what is the problem , pls help
Posted 09 March 2010 - 11:05 AM
1. service all injectors
2. service all sensors
3. service starter motor
4. inspect inhibitor switch (neutral start switch at auto gearbox to prevent starting in D or R)
Posted 09 March 2010 - 10:03 PM
I also suspect that, but seem service injector is not in the list of toyota service and maintainance guildline
From the invoice above , i believe they have check the sensor already right?
From the cold start with no problem at all, i don't think is starter motor problem
I confirm i didn't start at D or R only P.
Posted 11 March 2010 - 11:13 AM
Just some questions:
1. You said need 2 starts....was the first one totally empty, or still cranking but fail to start? It could be the relay for the starter.
Any car wiring shop can change that for you.
2. From your Service Invoice seems like you did it at the Mutiara Toyota SC infront of Giant Plentong....those guys only know how to service only, same as Saksama Toyota SC in Tmn Shahbandar or other dealers. I really dunno why Toyota is not really controlling these Subcontrators very well.
I would recommend you to make an appointment with the main UMWSC at Larkin as over there they have more experience in such problems. But make sure you got time in your hands. Registration takes half and hour....and even taking back the car keys takes 45 min...haha..but as long as you are satisfied, why not?
Posted 11 March 2010 - 11:16 AM
Seriously, is cranking the engine twice such an issue?
Posted 11 March 2010 - 11:43 AM
It does when you got your Wira/Waja friends in the car....
Posted 11 March 2010 - 06:25 PM
The first start is still cranking but fail to start (not empty). even put some gas on the accelerator pedal, still the same
mind to explain about the relay for starter? because it has no problem for cold start!
yes, i am thinking to send the car to larkin for coming service, no confident to mutiara already.
Posted 12 March 2010 - 04:39 PM
So they ( Wira/Waja friends ) are trying to find some excuse to complain / comment about your car ?
They know that plotong got too many things to complaint about so just trying to find fault with yours compared to theirs to make them feel better.
Posted 10 October 2010 - 01:26 AM
1. the first start is cranking but fail to start.
2. tell u what larkin service center also the same. lousy service
Posted 10 October 2010 - 01:42 AM
(NFS Underground)
