| Autoworld.com.my |
Jul 6 2009, 09:29 PM
Post
Probation ![]() Group: Members Posts: 26 Joined: 30-March 09 Member No.: 85,519 |
i got problem with my waja 1.8 gearbox
the autobox light will lite up whenever i try to drive up to the hill. It cannot engage to higher gear. I have to stop and start the engine again. any fixes to this problem? |
Jul 7 2009, 08:26 AM
Post
Advanced ![]() Group: Members Posts: 76 Joined: 30-January 04 Member No.: 33,404 |
Please service your car by changing the ATF every 20,000 km. I had this problem in the past, now no issues. FYI Im also an NGV user, so its assumed have more headaches but till now 7 yr old car, the feeling is great. Also please fix yr ABS lighting up as well rite ? I had this done a of month back after delaying for nearly 3 years.
Jul 7 2009, 08:27 AM
Post
Road Warrior ![]() ![]() Group: Members Posts: 597 Joined: 31-December 06 From: Kuala Lumpur Member No.: 63,220 |
i got problem with my waja 1.8 gearbox the autobox light will lite up whenever i try to drive up to the hill. It cannot engage to higher gear. I have to stop and start the engine again. any fixes to this problem? we have a few threads on this waja 1.8 gearbox problem. you just do a search and read up on it. So far we have these 3 common problems: 1. solenoid valve/sensor problem 2. TCU problem 3. Gearbox itself take your pick suitable for your problem. -------------------- No! Not Me!
Jul 8 2009, 08:56 AM
Post
![]() Veteran ![]() ![]() Group: Members Posts: 215 Joined: 27-December 06 Member No.: 63,150 |
Jul 9 2009, 08:14 AM
Post
Driver ![]() Group: Members Posts: 41 Joined: 23-December 08 Member No.: 77,045 |
renaultmatic d3 syn is so smooth..
Jul 9 2009, 01:32 PM
Post
renaultmatic d3 syn is so smooth.. According to ex-Proton mechanic/technician (he runs his own workshop now), ESSO ATF 4HP20-AL4 (LT71141) is better. -------------------- No! Not Me!
Jul 26 2009, 09:08 AM
Post
Advanced ![]() Group: Members Posts: 98 Joined: 22-February 03 Member No.: 25,356 |
"Also please fix yr ABS lighting up as well rite ? I had this done a of month back after delaying for nearly 3 years. "
Hi, where you fixed your ABS lighting & how much it costs??? I've been ignoring the lighting for somtime & is time to get it fix now. Thanks. Cheers -------------------- << Miffy >> |
Jul 31 2009, 10:18 PM
Post
"Also please fix yr ABS lighting up as well rite ? I had this done a of month back after delaying for nearly 3 years. " Hi, where you fixed your ABS lighting & how much it costs??? I've been ignoring the lighting for somtime & is time to get it fix now. Thanks. Cheers U check thru the old threads, there is someone by the user id kiamtiap , he's doing in freelance now my car is free of bugs. |
Aug 1 2009, 12:19 AM
Post
Tokyo Drifter ![]() ![]() ![]() Group: Members Posts: 2,905 Joined: 21-February 04 Member No.: 34,250 |
Have u check the gearbox mounting....sure koyak aready...means the sensor/selenoid not working well due to error of reading...so before you change anything..do check the mounting..then replace to new ones..
Enjoy driving!! -------------------- MY WAJA 1.8 STILL MOVING STRONG
Aug 3 2009, 06:14 PM
Post
Road Warrior ![]() ![]() Group: Members Posts: 781 Joined: 16-September 05 Member No.: 52,209 |
Have u check the gearbox mounting....sure koyak aready...means the sensor/selenoid not working well due to error of reading...so before you change anything..do check the mounting..then replace to new ones.. Enjoy driving!! Ellehh. bro razak hehe, kau pun berfoya kat sini kah ingat kuat main amoi ja, haha kat sini pun ada jejak kau pula apa macam? ada baik? bila nak buat tt ni ? dah lama tak join gang lanun kat WPC tu.. tolong lah aku cari HID4300k yang murah, tapi quality ok and power windows switch (master) ,ada ? thanks. |
Lo-Fi Version | Powered By IP.Board © 2008 IPS, Inc | Time is now: 24th May 2013 - 07:38 AM |
