| Autoworld.com.my |
Oct 16 2007, 04:19 PM
Post
Probation ![]() Group: Members Posts: 34 Joined: 21-September 07 Member No.: 68,495 |
i am thinking to buy this tyre. does any one have experience about this
tyre. is it ok for size 195/55 or 195/50 r15 |
Oct 16 2007, 06:25 PM
Post
![]() Forum Ninja ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 64,186 Joined: 11-November 04 From: Petaling Jaya Member No.: 41,856 |
normal tyres.....
rdgs, |
Oct 18 2007, 01:24 AM
Post
Veteran ![]() ![]() Group: Members Posts: 150 Joined: 14-October 07 Member No.: 68,886 |
I`m using 195/55, quite ok overall for me, as it is cheaper compare to
other tires I was looking. (got mine for RM157/pc @ Sg. Petani, Kedah.) Pros: thick thread, can last long mileage, not bad for wet performance. Cons: loud, compare to previous tire Goodfyear NCT5. |
Oct 18 2007, 10:47 AM
Post
![]() Tokyo Drifter ![]() ![]() ![]() Group: Advertiser Posts: 4,385 Joined: 18-April 07 From: KL Member No.: 65,292 |
Hi benny,
Thanks for the input and can I assumed your review is based on the comparison between D01 and NCT5 (when both are new if you can recall)? |
Oct 18 2007, 12:03 PM
Post
Traction A tyres... Treadwear 400 plus, if not mistaken 480
rdgs, |
Oct 18 2007, 02:57 PM
Post
hehe walking dictionary can remember by heard ..not me definitely.
Oct 18 2007, 03:26 PM
Post
Hot Rod ![]() ![]() ![]() ![]() Group: Members Posts: 10,595 Joined: 14-August 01 Member No.: 14,971 |
that's quite a long lasting tyre |
Oct 18 2007, 03:35 PM
Post
Ya, I compare it base on previous experience on NCT5... Just got the D01
about a month only, as vr2turbo mentioned above, good treadwear and good traction rated A, quite satisfy with it until now. But need to mention again here, it rolls louder on highway than NCT5s. For dry and wet grip, I think it`s better too as I drive my car quite aggressive and frequent (traveling around 100km per day for work). |
Oct 19 2007, 09:35 AM
Post
mubull,
No lah, happen to see the D01 quite recently...ha! ha! benny, Your D01 are unidirection tyres, therefore cutting through water is not an issue, but traction A tyres are better for dry and not wet in straight line braking. As mentioned in another post, aquaplaning is due to tread design, and grip is base on rubber compound. They work hand in hand. rdgs, |
Oct 19 2007, 01:50 PM
Post
Taxi Driver ![]() ![]() Group: Members Posts: 437 Joined: 5-April 02 Member No.: 19,479 |
Hi vr2turbo..
I'm back again for tyre..my D01 almost get botak within 1 year..:) My comment on D01 -it serve better then NCT GY because it is soft compound..am i right vr2turbo ? It run very good in dry but not able to provide adequate aquapla for middle wet water. |
Lo-Fi Version | Powered By IP.Board © 2008 IPS, Inc | Time is now: 24th May 2013 - 12:12 AM |
