| Autoworld.com.my |
Oct 5 2005, 06:59 AM
Post
Probation ![]() Group: Members Posts: 31 Joined: 29-October 03 Member No.: 13,330 |
Hi all vios owners. I'm planning to get a vios soon. just want to know if
Vios is running on timimng chain or timing belt. And is it true that cars running on timing chain are relatively noisier? |
Oct 5 2005, 08:43 AM
Post
Tokyo Drifter ![]() ![]() ![]() Group: Members Posts: 3,333 Joined: 10-March 04 Member No.: 34,793 |
its on chain
noisier? very much depends on how d chain is constructed anyway, if ur car's nvh is good, u wont b able to hear anything |
Oct 5 2005, 08:46 AM
Post
![]() Hot Rod ![]() ![]() ![]() ![]() Group: Members Posts: 13,742 Joined: 7-May 01 Member No.: 13,432 |
liew,
Yes, the 1NZ-FE is running on timing chains. The Vios engine is noisier, but I'm not sure if that can be solely attributed to the application of timing chains. |
Oct 5 2005, 10:11 AM
Post
thanks to all of u. one of my criteria for choosing this car is also the
durability of the parts. Chains required less servicing or even replacing. |
Oct 5 2005, 11:50 AM
Post
Advanced ![]() Group: Members Posts: 63 Joined: 7-September 05 Member No.: 51,933 |
Vios run on timing. In fact all toyota vvt-i engine run on timing chain
more reliable. All mine cars now use timing chain. Noisy or no depend on car sound proofing.Mine N16 engine noise consider quiet. |
Oct 5 2005, 12:14 PM
Post
Tokyo Drifter ![]() ![]() ![]() Group: Members Posts: 3,309 Joined: 13-April 03 Member No.: 26,282 |
Yes, Vios is on chain. However, I am surprise on how quiet and stable the
engine is. The sound of the air cond is louder than the engine. At times, with the CD playing, I almost forgot the engine is running |
Oct 5 2005, 01:06 PM
Post
Road Warrior ![]() ![]() Group: Members Posts: 806 Joined: 21-July 05 Member No.: 50,400 |
Due to the need of higher accuracy of valve system and complex
construction, most manufacturers nowadays uses back the chain for valve timing system. All new model= vios, sentra N16, myvi etc uses chain. But these chain is now properly engineered with lower drag/abbrasion, more eficient to compare than those used in 60s and 70s. They accurate, strong and can move a complex VVTi, VTC, or whatever system u called it. More extra, higher durability, replacement only after a few hundred thousands km. Rubber/fibre/composite timing belt have the properties of 'elongation', they became slightly longer (talked about micron measurement) on stress absorption. lower quality composite elongate even further, which is why some of local magma engine 'knocking' or 'loose the cam' on ascending move (climb hill, engine resistance increased). The advantage of rubber belt is cheap, silent. |
Oct 5 2005, 11:46 PM
Post
White Lightning ![]() ![]() ![]() Group: Members Posts: 6,799 Joined: 6-August 03 Member No.: 29,077 |
my wira is on belt...but dem 9 noisy.....
Oct 6 2005, 12:56 AM
Post
Knight Rider ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 16,280 Joined: 1-March 05 Member No.: 45,452 |
ranii..... wira I believe the belts you refering to are the accessory belts
not the cam belts... that are noisy... |
Oct 6 2005, 09:16 AM
Post
Tokyo Drifter ![]() ![]() ![]() Group: Members Posts: 2,734 Joined: 9-August 04 Member No.: 38,757 |
As far as I know, belts only make noise when kena water.
Lo-Fi Version | Powered By IP.Board © 2008 IPS, Inc | Time is now: 24th May 2013 - 10:37 PM |
