Autoworld
Autoworld.com.my
2 Pages V   1 2 >
> Suzuki authorize service center.
x7e
post Sep 13 2008, 09:48 PM
Post #1
Group: Members
Im driving a Swift CKD, the mileage is nearly 50k km. so, starts frm the
60k km service, I cant enjoy the free service at Suzuki service center
anymore. I just check with the workshop where I always send my car for
service, they said that for normal service, labor fees starts from RM 120-
RM160 (only for labor fees, excluded the spare parts, engine oil, and other
extra charges). I don’t know its Suzuki standard labor charge, or I “kena
ketuk” labor price. This Service center located at Puchong, near Tesco.
SO, I need other owners help, to tell me where else can I send my Suzi for
service. I need an authorize service center, or any workshop which
recognize by Suzuki Msia, with reasonable labor price…and of coz, using
original spare parts (xwant places which give ciplak parts laa.). really
appreciate if any of you can help me.. tq.
(fyi, i live in Subang Jaya).
Go to the top of the page
+Quote Post
maiself
post Sep 17 2008, 02:11 PM
Post #2
3rd Gear
Group: Members
try calling mofaz (sg. penchala near ikea) 03 7728 2120
+Quote Post
urvi88
post Apr 20 2009, 02:54 PM
Post #3
Group: Members
What i would suggest is search in Google, it is best way to find so many option from which you can choose best one for you.
+Quote Post
darreltian
post Apr 20 2009, 03:02 PM
Post #4
Group: Members
just get it from suzuki malaysia website ler...
x 1,000km 1 Month 1 Labour ** (RM) Parts * Total Cost ** (RM)
Items Price ** (RM)
1,000km or 1 mth Engine Oil (4L) 93.00. Total 127.60
Oil Filter Assy 28.70
Drain Plug Gasket 2.90
Battery Water 3.00
5,000km or 3 mths. Engine Oil (4L) 93.00. Total 127.60
Battery Water 3.00
10,000km or 6 mths. Engine Oil (4L) 93.00. Total 127.60
Battery Water 3.00
1 interval (whichever comes first)
* Spare part replacement subject to model specification
** Prices may change without prior notification
This schedule only shows maintenance up to 90,000km. Beyond 90,000km please repeat back the cycle from the 10,000km and subsequent services at the same intervals respectively.
Items Price ** (RM)
10,000km or 6 mths. Labour 55.00. Engine Oil (4L) 93.00. Total 182.60
Battery Water 3.00
20,000km or 12 mths. Labour 55.00. Engine Oil (4L) 93.00. Total 182.60
Battery Water 3.00
30,000km or 18 mths. Labour 115.00. Engine Oil (4L) 93.00. Total 332.60
Battery Water 3.00
Brake Fluid DOT 3 17.40
Spindle Cap (2 units) 31.00
Spindle Nut (2 units) 41.60
40,000km or 24 mths. Labour 65.00. Engine Oil (4L) 93.00. Total 392.70
Battery Water 3.00
Air Cleaner Element 63.00
Radiator Coolant (2L) 47.40
Spark Plugs (4pcs) 39.20
AC Pollen Filter 50.50
50,000km or 30 mths. Labour 55.00. Engine Oil (4L) 93.00. Total 182.60
Battery Water 3.00
60,000km or 36 mths. Labour 130.00. Engine Oil (4L) 93.00. Total 347.60
Battery Water 3.00
70,000km or 42 mths. Labour 55.00. Engine Oil (4L) 93.00. Total 182.60
Battery Water 3.00
80,000km or 48 mths. Labour 70.00. Engine Oil (4L) 93.00. Total 534.50
Battery Water 3.00
Radiotor Coolant (2L) 47.40
Drain Plug Gasket for AT Pan 9.20
Auto Transmission Fluid (4L)
(every 80,000km) 127.60
90,000km or 54 mths. Labour 140.00. Engine Oil (4L) 93.00. Total 532.90
Battery Water 3.00
Spindle Cap (2 units) 41.60
Water Pump Drive Belt
(every 90,000km) 98.10
AC Compressor V Belt
(every 90,000km) 66.60
x 1,000km 1 Month 1 Mandatory Service Inspection
10, 20, 50, 70 6, 12, 30, 42 * Inspect and clean air cleaner.
* Check disc brake pads and discs for excessive wear, damage and deflection.
* Rotate tires and wheels.
30, 60, 90 18, 36, 54 Inspect acc. drive belt for cracks, cuts, deformation, wear and cleanliness. Check belt for tension.
Inspect intake and exhaust valve clearance and adjust as necessary.
Inspect exhaust system rubber mountings, leakage, loose connection, dent damage, and clearance.
Visually inspect fuel lines and connections for evidence of fuel leakage, hose cracking and damage.
Check fuel tank damage, cracks, fuel leakage, corrosion and tank bolts looseness.
Inspect and service disc brake pads and discs for excessive wear, damage and deflection.
Check rear brake drums and brake linings for excessive wear and damage. (Applicable models only).
Check brake hoses and pipes for proper hookup leaks, cracks, chafing and other damage.
Inspect brake cable for damage and smooth movement.
Check tires for uneven or excessive wear, or damage. Adjust tire pressure and rotate wheels.
Check drive shaft boots (wheel side and diff. side) for leaks, detachment, tear or other damage.
Inspect suspension system for tightness, damage, rattle and breakage.
Inspect transaxle case for evidence of fluid leakage. Check ATF level (Applicable models only).
Check differential for evidence of oil leakage. Repair leaky point if any (Applicable models only).
Check ATF cooler hose for fluid leakage, cracks, damage and deterioration. (Applicable models only).
Check each door of front, rear & back doors opens and closes smoothly and locks securely when closed.
Check A/C pollen filter for dirt and damage (Applicable models only).
Inspect transfer case for oil level, leakage and damage. (Applicable models only).
40, 80 24, 48 * Inspect and clean air cleaner.
* This Schedule shows maintenance up to 90,000km. Beyond 90,000 km, repeat back from the 10,000km and subsequent services at the same intervals respectively.
* Prices may change without prior notification.
+Quote Post
kho51
post Aug 17 2009, 09:41 PM
Post #5
Group: Members
Just wanna check with your, any recommended suzuki service center? i see from the service manual, most of it is authorize service center, that means so call franchise one right? Can I know is there any suzuki service center, i mean like service center that operate by suzuki malaysia? Thanks...
+Quote Post
Puntonian
post Aug 18 2009, 11:09 AM
Post #6
Group: Members
QUOTE (x7e @ Sep 13 2008, 09:48 PM) *
extra charges). I don�t know its Suzuki standard labor charge, or I �kena
ketuk� labor price. This Service center located at Puchong, near Tesco.
recognize by Suzuki Msia, with reasonable labor price�and of coz, using
Try the service Centre in Connaught. It's located behind the Giant Hypermart, those shoplots with the blue roof. Don't know the address. I just know how to go there. smile.gif
This is a good service centre. My Suzie is serviced by them from day 1.
+Quote Post
darreltian
post Aug 18 2009, 11:35 AM
Post #7
Group: Members
QUOTE (Puntonian @ Aug 18 2009, 11:09 AM) *
Good SC smile_thumbup.gif Look for Mr. Chan, the manager in charge who also has vast experience and knowledge
+Quote Post
archebald3
post Jun 25 2010, 09:50 AM
Post #8
Group: Members
with regards to the schedule, was it derived from the suzuki manual? cause my manual states different figures. Like the air cleaner assembly, my Mr Gasket Air Cleaner Assembly give out different readings.
tHe gReat arcHebALd!
watch me here: How To Replace a Muffler
+Quote Post
lspnkwy
post Jun 27 2010, 06:52 PM
Post #9
Group: Members
Does any 1 sent cars to Jln 222 service center ?
any idea the service technician there is good attitude?
Please advice!
@.@ Naruto-kun @.@
+Quote Post
HCman
post Jun 28 2010, 02:23 PM
Post #10
Group: Members
QUOTE (lspnkwy @ Jun 27 2010, 06:52 PM) *
Please advice!
I sent my SGV to the service centre near Tesco Puchong as I trust the 2 senior mechanics there, How and Lim. I have been sending my Honda to them for normal service and major repair for the past years.
+Quote Post
2 Pages V   1 2 >
RSS Lo-Fi Version  |  Powered By IP.Board © 2008  IPS, Inc Time is now: 30th January 2015 - 04:20 AM
