Autoworld
Autoworld.com.my
> waja 1.6 manual gear box
nicky8559
post Apr 3 2008, 09:45 PM
Post #1
Group: Members
hey everybody, i am facing a big big problem now...
recently my waja gear box seem like got some problem. every time when
shifting gear 2 to 3 or 3 to 4 will got a klok klok sound coming out from
engine bay. and quite hard to shift gear. i dunno what happen then i go to
proton service centre trying to solve the problem. the foreman there also
trying to help me solve it, but finally they tell me the sound come inside
gear box,tell me what maybe gear shaft problem(maybe). then cant help me.
but he advise me to buy a gear box easier..Dead
may i know how much cost a recon waja 1.6 manual gear box at those kedai
potong?? or any place in JB can help me solve this type problem??
i try changing the whole clutch kits, gear oil but all no uses....
thanks u!
Go to the top of the page
+Quote Post
YSW
post Apr 4 2008, 10:58 AM
Post #2
Group: Members
Try to check the engine mounting and gear shift cable (got 2).
+Quote Post
nicky8559
post Apr 4 2008, 08:53 PM
Post #3
Group: Members
I hav change the engine mounting.
If gear shift cable will make this kind problem?? got a klok klok klik
klik sound when shifting gear.
my car really make me headache....keep facing problem with it!!
should i change a car better?? anyway,any people know how much a gear box
will be??
+Quote Post
RM1ONE
post Apr 4 2008, 11:46 PM
Post #4
Group: Members
Go to a old experience mechanic, the one whose shop is very untidy and
black with dirt. These guys can strip your gearbox, check every part and
fix if fixable.
I've seen a gearbox being taken apart and it's not easy and very time
consuming. Is there a opening (covered by a rubber boot) somewhere on the
box? Usually, spraying some lube into it helps sort out the noise.
But before doing that, when was the last time u had your gear oil drained
and changed? Try changing the oil and add in some gear additive such as
WYNN Gear Treatment. This thing will smoothen your gear change.
+Quote Post
nicky8559
post Apr 5 2008, 08:30 PM
Post #5
Group: Members
this problem happen half year before, in this period i had keep changing
the oil for more than 4 times already. and also add in the gear additive
alrady. but no use with that.
the sc people tell me waja hardly got this kind gear box problem. dunno
why i am so lucky...
i really gonna give up my waja already! keep problem here, problem there.
+Quote Post
kuripot101
post Apr 12 2008, 11:41 PM
Post #6
Group: Members
My only problem i had was the clutch plate springs gave way and disloged
from the plate. The gears shifting was quite difficult. As mentioned i
went to dirty foreman and dismantled gearbox. Finally changed to original
Mits. clutch set i.e. Clutch plate, Pressure plate & bearings. All ok
till now almost 300k km. this happened at about 65K km. Hope this would
give you a possible cause for dismantling the clutch set. Mine installed
originally by Proton was Exedy.... i never trust exedy again.
+Quote Post
ferarri
post Apr 16 2008, 07:35 PM
Post #7
Group: Members
My 05 manual waja reaching 60k km. Hopefully the gear box behaves. Need
to change timing belt soon.
+Quote Post
RSS Lo-Fi Version  |  Powered By IP.Board © 2008  IPS, Inc Time is now: 30th January 2015 - 02:19 AM
