Autoworld
Autoworld.com.my
> Proton Waja Parts List - revised 2002
mych
post Nov 21 2006, 11:38 PM
Post #1
Group: Members
No Description Part No Price
1 CE0034 [ALL] Alarm Switch Bonnet PW850813 5.11
2 CT0010 [ALL] Bonnet Lock PW831176 31.57
3 CT0209 [ALL] Bonnet Lock Stud Plate PW890030 44.28
4 CT0011 [ALL] Bonnet Pull Cable PW831320 9.47
5 CT0169 [ALL] Bonnet Release Handle MB401484 3.78
6 CT0009 [ALL] Bonnet Stand PW831255 12.53
7 CT0300 [ALL] Bumper Front Cover PW830468 408.50
8 CT0130 [Black] Bumper Frt Lower Grille PW831688 38.46
9 CM0009 [ALL] Bumper Reinforcement Front PW830928 132.91
10 LE0221 [ALL] Bumper Signal Lamp LHF PW850923 393.43
11 RE0221 [ALL] Bumper Signal Lamp RHF PW850924 393.43
12 CT0368-1 [APM] Cooling Fan Cover PW820406 83.20
13 CT0368-2 [Denso] -- as above -- PW890295 70.43
14 CE0113-1 [APM] Cooling Fan Motor PW820407 296.37
15 CE0113-2 [Denso] -- as above -- PW890297 328.57
16 CM0160-1 [APM] Fan Blade PW820408 83.13
17 CM0160-2 [ALL] -- as above -- PW890289 65.72
18 CM0160-3 [Denso] -- as above -- PW890296 52.57
19 CE0270 [LH & RH] Fender Signal Lamp PW850533 39.45
20 CE0127 [ALL] Flasher Relay PW500081 21.30
21 CFP005 [ALL] Front Panel Assembly PW890032 330.28
22 CT0039 [Black] Grille Front PW841388 266.00
23 LE0006 [ALL] Headlamp Assy LH PW850831 368.67
24 RE0006 [ALL] Headlamp Assy RH PW850832 368.67
25 CE0276 [Outer (Low Beam)] Headlamp Bulb PW890762 18.43
26 LHP000 [ALL] Headlamp Panel LH PW890027 99.43
27 RHP000 [ALL] Headlamp Panel RH PW890028 99.43
28 CT0184-1 [Low Pitch] Horn PW851586 70.57
29 CT0184-2 [High Pitch] -- as above -- PW851587 70.57
30 CE0030 [ALL] Horn Alarm PW850812 33.94
31 CM1146 [ALL] Number Plate Bracket MB325163 11.20
32 CE0003-1 [RH] Number Plate Lamp / Lamps PW850534 12.14
33 CE0003-2 [LH] -- as above -- PW850819 12.14
34 CM0003-1 [APM] Radiator PW820399 810.91
35 CM0003-2 [Denso] -- as above -- PW890298 880.14
36 CT0328 [Behind Frt. Bumper] Radiator Air Deflector PW831450 12.94
37 CM5152 [ALL] Radiator Bottom Hose PW820254 6.37
38 CM1143-1 [APM] Radiator Cap PW820414 15.90
39 CM1143-2 [Denso] -- as above -- PW890293 30.50
40 CM0004 [ALL] Radiator Expansion Tank PW820258 27.15
41 CM5052 [ALL] Radiator Top Hose PW820252 4.87
42 CM0139 [ALL] Radiator Top Support Bracket PW820260 7.00
43 CM6057 [ALL] A/C Belt PW850671 49.41
44 CE0052 [Motor (Denso)] A/C Blower Unit PW890272 328.57
45 CM0060 [ALL] A/C Compressor PW890282 1023.12
46 CM1200 [ALL] A/C Compressor Bracket PW850670 96.57
47 CM0055 [ALL] A/C Condenser PW890284 287.50
48 LM0319 [ALL] A/C Fan Motor PW890290 262.86
49 CM0061 [ALL] A/C Receiver Drier PW890285 75.15
50 CM0059 [ALL] A/C Relay PW539912 11.75
51 CM1179 [ALL] Accelerator Cable PW820172 27.20
52 CM0007 [ALL] Air Box / Resonator PW820187 45.00
53 CM0094 [ALL] Air Filter PW510765 35.13
54 CM0093 [ALL] Air Filter Cover PW890727 18.78
55 CM5093 [ALL] Air Filter Lower Case PW890726 56.33
56 CE0011 [ALL] Alternator PW810089 776.89
57 CM1119 [ALL] Alternator Adjusting Bracket MD314092 55.60
58 CM0237 [ALL] Alternator Belt MD338513 91.75
59 CM1118 [ALL] Alternator Pulley PW890543 38.46
60 CE0001 [ALL] Battery PW850776 162.88
61 CBO000 [ALL] Bonnet PW890098 322.72
62 CT0313 [ALL] Bonnet Badge PW840137 23.47
63 LM0043 [ALL] Bonnet Hinge LH PW830401 13.49
64 RM0043 [ALL] Bonnet Hinge RH PW830402 13.49
65 CT0026 [ALL] Bonnet Insulation PW831324 35.20
66 CT1340 [ALL] Bonnet Insulation Clip MU481187 1.96
67 CT0151-1 [Large (Inner)] Bonnet Lndg Cushion PW830663 1.00
68 CT0151-2 [Small (Outer)] -- as above -- PW830664 .28
69 CT0025 [Above Radiator Grille] Bonnet Weatherstrip Centre PW831700
3.34
70 LT0023 [ALL] Bonnet Weatherstrip LH PW830660 5.87
71 RT0023 [ALL] Bonnet Weatherstrip RH PW830665 5.87
72 CM0157 [ALL] Brake Booster PW890085 382.92
73 CM0250 [ALL] Brake Booster Hose PW820150 27.43
74 CM0156 [ALL] Brake Master Cylinder Assy PW820145 298.94
75 CM1194-1 [Pipe, RHF] Brake Pipe / Hose PW821440 8.86
76 CM1194-2 [Pipe, LHF] -- as above -- PW821441 18.28
77 CM5156 [ALL] Brk Master Cyl Container Cap PW890088 19.67
78 CM0159 [ALLt have i[[dS3rs , proton is losing very much , i admit this .
i am just saying at least proton waja improved from the last time batches ,
talk about proton wira , the quality doesn\'t seems to improve and proton is
more likely to just sell it at any price .
yeah , proton car is extremly over-priced ...
but then , savvy sounds like another story for me . it is indeed a very
good proton that i ever seen . but then , if u got any complaint on
refinement , please let me know ... i am willing to help \"someone\" . but
then , except the size , this savvy is very refined underneath . i was told
and i went to see for myself , ... many things that is very refined . i was
surprise and thought that it was just a hoax when i was told about it until
i checked it out . but then ... proton still proton , they need to improve
and they shouldn\'t price it that high . cons/sm(
p_p_XS3 alt=\"Shock\">. Imagine 1 power window cost RM200. All 4 units? u do the \ncalculation. Another relative of mine who told me that his iswara power \nwindow just drop on his lap while driving and aircond kong after 1 yr!!. \nHe also told me his 15 yr old Toyota power window still works and never \nbeen repaired. His Aircond never been serviced b4 still works ok.The \nproblem with waja or proton is the assories low quality dont blame the \nrakyat la saying that we want low priced car`s. Local made cars should be \nreasonably priced. Dont think of profit only. The problem with TM and \nproton boards is they want ROI quickly, mana bole. The thing is if you \nsell gud quality product `Do it right the first time` you wont incure \nadditional cost of recalling or replace product on warranty. I regret \nbuying P.Waja.Hearing horror stories from mybb,5 \nyears and living in hell with Waja problems for 5 yrs. Don`t know what to \ndo..........shhyyyyy regret! \"Frown\"','T2waja@1');
cccFa horror stories abt power window suddenly drop off. He
also told me of his friends had change all his power window 4 units at
once \"Shock\". Imagine 1 power window cost RM200. All 4 units? u do the
buying P.Waja.Hearing horror stories from my uncle who owned P.Waja for 5
do..........shhyyyyy regret! \"Frown\"m
BridgestoneRE711,....\n\nPlease read my posting Enhance Waja Poor Quality!! I have horror stories \nabout Proton Waja related to me by my relatives. We are not Proton basher \nbut my family owned P.waja. The thing with proton is the quality, I always \nstress on quality. The vendors they have provide very low quality product. \nMy uncle relate a horror stories abt power window suddenly drop off. He \nalso told me of his friends had change all his power window 4 units at \nonce \"Shock\". Imagine 1 power window cost RM200. All 4 units? u do the \ncalculation. Another relative of mine who told me that his iswara power \nwindow just drop on his lap while driving and aircond kong after 1 yr!!. \nHe also told me his 15 yr old Toyota power window still works and never \nbeen repaired. His Aircond never been serviced b4 still works ok.The \nproblem with waja or proton is the assories low quality dont blame the \nrakyat la saying that we want low priced car`s. Local made cars should be \nreasonably priced. Dont think of profit only. The problem with TM and \nproton boards is they want ROI quickly, mana bole. The thing is if you \nsell gud quality product `Do it right the first time` you wont incure \nadditional cost of recalling or replace product on warranty. I regret \nbuying P.Waja.Hearing horror stories from my uncle who owned P.Waja for 5 \nyears and living in hell with Waja problems for 5 yrs. Don`t know what to \ndo..........shhyyyyy regret! \"Frown\"to [xU(p(pdS3s (pid, edit_time, author_id, author_name, ip_address, post_date, topic_id, post_title, new_topic, edit_name, post_key, post_parent, post, old_UserID) VALUES ('1008089', '1118634000', '48471', 'T2waja', '219.95.219.73','1118633775', '63501', 'proton waja improved ? ', '0', 'T2waja', '5e32d13af761e7df8e32ee2b1b262199', '276143', 'BridgestoneRE711,....\n\nPlease read my posting Enhance Waja Poor Quality!! I have horror stories \nabout Proton Waja related to me by my relatives. We are not Proton basher \nbut my family owned P.waja. The thing with proton is the quality, I always \nstress on quality. The vendors they have provide very low quality product. \nMy uncle relate a horror stories abt power window suddenly drop off. He \nalso told me of his friends had change all his power window 4 units at \nonce \"Shock\". Imagine 1 power window cost RM200. All 4 units? u do the \ncalculation. Another relative of mine who told me that his iswara power \nwindow just drop on his lap while driving and aircond kong after 1 yr!!. \nHe also told me his 15 yr old Toyota power window still works and never \nbeen repaired. His Aircond never been serviced b4 still works ok.The \nproblem with waja or proton is the assories low quality dont blame the \nrakyat la saying that we want low priced car`s. Local made cars should be \nreasonably priced. Dont think of profit only. The problem with TM and \nproton boards is they want ROI quickly, mana bole. The thing is if you \nsell gud quality product `Do it right the first time` you wont incure \nadditional cost of recalling or replace product on warranty. I regret \nbuying P.Waja.Hearing horror stories from my uncle who owned P.Waja for 5 \nyears and living in hell with Waja problems for 5 yrs. Don`t know what to \ndo..........shhyyyyy regret! \"Frown\"','T2waja@1');\nthey xM(x(xdS3 believe they don`t know how to install\nthe bulb!) I tried myself on the left, which is missing, but Not the one on\nthe right. No room to access. Check the manual, too many steps... So one\neye yellow one white! hahah.. Got to see the salegirl tomorrow, Monday.\n\nAlso, a well known good handling car: Honda Accord, Came with misaligned,\nabout 10 degree to the left. Have to spend RM20 plus 90 mins to repair\nthat. I cannot figure out why they have double wishbones rear and front,\nbut cannot do allignment? They might saved RM20, but will have the negative\nimpression. If I am the car maker, I will try hard to impress the owner,\nsee this is what your got...worth the money. My Waja , came with damaged\nsteering bush when it was delivered. All suck!','drjwah@1');ike saPJP{P{dS3 hi quality texture made . I \nlook at the plastic made headlamps , even that it is a plastic made \nheadlamp , but I still confident enough for it this time when I mentioned \nthat it is made by AL a big company which manufacture lamps for Fiats \n Getting inside the car , I was forced to wait ! why ? The left \ndoors are spoilt ! Both door cannot be opened from both side . I went to \nthe driver side and pull the door lock , but it was jammed I think , or \nmaybe it is a safety feature where the driver cannot lock the door when \nthe door is open . \nWhen Im inside the car , can feel that the car is cramped . The costed \ndown seat do not hug the body nicely like a waja but the fabric is holding \nthe body , the adjuster are hard to use , feels weak . when u put down the \nback rest , it is not comfortable as it is too flat . Looking around the \ncabin area , the car is very Italian , the air-cond button are nice to \nfeel ! The car comes with a climate-control air-cond , cool ! the previous \n1.6 entry model have the same function too ! I tried to push the aircond \nblower , it doesnt feel nice to push , there are too many fins inside \nthe blower which I think will provide nice blowing direction compared to \nthe odd 3-fin blower inside the Waja . There are too many useless buttons \non the dashboard , above the HU . the white graphic with the bright button \nmakes it harder to read . Holding the steering , it is shaped so-so only , \nthe buttons are very-very cheap to touch ! when I peek around the \nsteering , I found that they did nice job , they installed a black rubber \nto close the hole for the wiper and signal stalk connector , and it \nimproved the neat look of the whole dashboard ! I look around the unique \nhandbrake level , I found a small knob there , I think it is for the side \nmirror but I dont see any movement when I twist it and pull it (wajas \ncan be adjust when the car is off) , the buttons for window lock is \nperfect but the power window switches are cheap to use ! the wira/perdana \ntype is better .. the gear change doesnt give a solid feel . \nThe driving position , it is not very nice , u will feel funny when \ndriving it . it feels cramped and the low seating position makes u hard \nto judge the front . The A pillar seems quite big to me , but not as \nbulky as Wajas . The side mirror , it is made of low quality mirror , no \nwide angle , no sealing around the mirror that u can see the edge of the \nmirror itself . The rear view mirror , Bad , very bad ! u cant see much \nthing from it ! the C pillar is too big , and the rear windscreen is too \nsmall plus the high boot profile for the car . The pedals are too far for \nme , but when I move front abit , the small stalk which adjust the \nsteering will scratch my lap when I try to get out . the steering seems to \nbe too low ! \nAfter looking inside the car , I get\0t have q\0\0\0\0Proton Gen2 ( 1.6 M ) \n================\n When reaching the showroom , the crowd is still heavy although the \ncar has been launched 8 days . Besides , this is my third time to visit \nProton Gen2 at the same showroom . \n I tried to get near the car , the car is replaced with the 1.6 \nhigher model , last time I only managed to look at a 1.6 entry level model \nwhich has almost nothing ! With the new grey colour car replaced the angel \nblue , it looks much better and classier . From the outside , I dont \nmention any door handle colour chipping off , so I though that they have \nthe new batch here . There was 2 ah bengs around there , one of them push \nthe grill , another push the bumper , the whole bumper shakes ! I tried it \ntoo , same result ! too soft and not solid enough . I mentioned that the \nside mirror is not flipable ! so , if u hit something , it will just fly \noff than flipping ! very stupid feature . The rims are nice and the brake \npads are from bosch. \n Inside the hood , I can see a better looking engine is there . The \nengine cover which is not available for the 1.6 entry can be seen here . \nit feels like sandpaper , but it is hard and hi quality texture made . I \nlook at the plastic made headlamps , even that it is a plastic made \nheadlamp , but I still confident enough for it this time when I mentioned \nthat it is made by AL a big company which manufacture lamps for Fiats \n Getting inside the car , I was forced to wait ! why ? The left \ndoors are spoilt ! Both door cannot be opened from both side . I went to \nthe driver side and pull the door lock , but it was jammed I think , or \nmaybe it is a safety feature where the driver cannot lock the door when \nthe door is open . \nWhen Im inside the car , can feel that the car is cramped . The costed \ndown seat do not hug the body nicely like a waja but the fabric is holding \nthe body , the adjuster are hard to use , feels weak . when u put down the \nback rest , it is not comfortable as it is too flat . Looking around the \ncabin area , the car is very Italian , the air-cond button are nice to \nfeel ! The car comes with a climate-control air-cond , cool ! the previous \n1.6 entry model have the same function too ! I tried to push the aircond \nblower , it doesnt feel nice to push , there are too many fins inside \nthe blower which I think will pro','BridgestoneRE711@1');
e saINSERT INTO ibf_posts (pid, edit_time, author_id, author_name, ip_address, post_date, topic_id, post_title, new_topic, edit_name, post_key, post_parent, post, old_UserID) VALUES ('1007860', '', '15531', 'BridgestoneRE711', '219.92.182.27','1076654121', '63489', 'Proton Waja 2004 : Reviews', '0', 'BridgestoneRE711', '23b947f9378f54a122bf69a389c81476', '206661', 'Proton Gen2 ( 1.6 M ) \n================\n When reaching the showroom , the crowd is still heavy although the \ncar has been launched 8 days . Besides , this is my third time to visit \nProton Gen2 at the same showroom . \n I tried to get near the car , the car is replaced with the 1.6 \nhigher model , last time I only managed to look at a 1.6 entry level model \nwhich has almost nothing ! With the new grey colour car replaced the angel \nblue , it looks much better and classier . From the outside , I dont \nmention any door handle colour chipping off , so I though that they have \nthe new batch here . There was 2 ah bengs around there , one of them push \nthe grill , another push the bumper , the whole bumper shakes ! I tried it \ntoo , same result ! too soft and not solid enough . I mentioned that the \nside mirror is not flipable ! so , if u hit something , it will just fly \noff than flipping ! very stupid feature . The rims are nice and the brake \npads are from bosch. \n Inside the hood , I can see a better looking engine is there . The \nengine cover which is not available for the 1.6 entry can be seen here . \nit feels like sandpaper , but it is hard and hi quality texture made . I \nlook at the plastic made headlamps , even that it is a plastic made \nheadlamp , but I still confident enough for it this time when I mentioned \nthat it is made by AL a big company which manufacture lamps for Fiats \n Getting inside the car , I was forced to wait ! why ? The left \ndoors are spoilt ! Both door cannot be opened from both side . I went to \nthe driver side and pull the door lock , but it was jammed I think , or \nmaybe it is a safety feature where the driver cannot lock the door when \nthe door is open . \nWhen Im inside the car , can feel that the car is cramped . The costed \ndown seat do not hug the body nicely like a waja but the fabric is holding \nthe body , the adjuster are hard to use , feels weak . when u put down the \nback rest , it is not comfortable as it is too flat . Looking around the \ncabin area , the car is very Italian , the air-cond button are nice to \nfeel ! The car comes with a climate-control air-cond , cool ! the previous \n1.6 entry model have the same function too ! I tried to push the aircond \nblower , it doesnt feel nice to push , there are too many fins inside \nthe blower which I think will provide nice blowing direction compared to \nthe odd 3-fin blower inside the Waja . There are too many useless buttons \non the dashboard , above the HU . the white graphic with the bright button \nmakes it harder to read . Holding the steering , it is shaped so-so only , \nthe buttons are very-very cheap to touch ! when I peek around the \nsteering , I found that they did nice job , they installed a black rubber \nto close the hole for the wiper and signal stalk connector , and it \nimproved the neat look of the whole dashboard ! I look around the unique \nhandbrake level , I found a small knob there , I think it is for the side \nmirror but I dont see any movement when I twist it and pull it (wajas \ncan be adjust when the car is off) , the buttons for window lock is \nperfect but the power window switches are cheap to use ! the wira/perdana \ntype is better .. the gear change doesnt give a solid feel . \nThe driving position , it is not very nice , u will feel funny when \ndriving it . it feels cramped and the low seating position makes u hard \nto judge the front . The A pillar seems quite big to me , but not as \nbulky as Wajas . The side mirror , it is made of low quality mirror , no \nwide angle , no sealing around the mirror that u can see the edge of the \nmirror itself . The rear view mirror , Bad , very bad ! u cant see much \nthing from it ! the C pillar is too big , and the rear windscreen is too \nsmall plus the high boot profile for the car . The pedals are too far for \nme , but when I move front abit , the small stalk which adjust the \nsteering will scratch my lap when I try to get out . the steering seems to \nbe too low ! \nAfter looking inside the car , I get\0t have q\0\0\0\0Proton Gen2 ( 1.6 M ) \n================\n When reaching the showroom , the crowd is still heavy although the \ncar has been launched 8 days . Besides , this is my third time to visit \nProton Gen2 at the same showroom . \n I tried to get near the car , the car is replaced with the 1.6 \nhigher model , last time I only managed to look at a 1.6 entry level model \nwhich has almost nothing ! With the new grey colour car replaced the angel \nblue , it looks much better and classier . From the outside , I dont \nmention any door handle colour chipping off , so I though that they have \nthe new batch here . There was 2 ah bengs around there , one of them push \nthe grill , another push the bumper , the whole bumper shakes ! I tried it \ntoo , same result ! too soft and not solid enough . I mentioned that the \nside mirror is not flipable ! so , if u hit something , it will just fly \noff than flipping ! very stupid feature . The rims are nice and the brake \npads are from bosch. \n Inside the hood , I can see a better looking engine is there . The \nengine cover which is not available for the 1.6 entry can be seen here . \nit feels like sandpaper , but it is hard and hi quality texture made . I \nlook at the plastic made headlamps , even that it is a plastic made \nheadlamp , but I still confident enough for it this time when I mentioned \nthat it is made by AL a big company which manufacture lamps for Fiats \n Getting inside the car , I was forced to wait ! why ? The left \ndoors are spoilt ! Both door cannot be opened from both side . I went to \nthe driver side and pull the door lock , but it was jammed I think , or \nmaybe it is a safety feature where the driver cannot lock the door when \nthe door is open . \nWhen Im inside the car , can feel that the car is cramped . The costed \ndown seat do not hug the body nicely like a waja but the fabric is holding \nthe body , the adjuster are hard to use , feels weak . when u put down the \nback rest , it is not comfortable as it is too flat . Looking around the \ncabin area , the car is very Italian , the air-cond button are nice to \nfeel ! The car comes with a climate-control air-cond , cool ! the previous \n1.6 entry model have the same function too ! I tried to push the aircond \nblower , it doesnt feel nice to push , there are too many fins inside \nthe blower which I think will pro','BridgestoneRE711@1');lf]theXHH0n Im inside the car , can feel that the car is cramped . The costed
be too low !
the door is open .
the blower which I think will proȿȿFd some units for spar','mych@1');_cP). Eventually before I could test it out, I
repaired a few for my mechanic and he reported that the test were
positive, so it never occurred to me to try it out myself, pity the car
too :D
So far, Ive repaired more than 10 pcs, some are the 850R (With TRACS-10
solenoids) and some with 8 solenoids (I think the newer V/S series). Ours
is the 6 solenoids type. Apart from my mechanic here, I have another
customer in Cheras, KL whos sending me the ABS module every alternate
week. So far, my record has been good. In terms of pricing, I charge the
KL guy twice of what I get here in Penang, there are some reasons to it
as
I need to test it and then post it during my working hours, so a bit
inconvenient for me. Moreover, my mechanic has been a great help and he
supplied some units for spar ``Original RM 190
52 Aligmend 4 Tyre RM 25
53 Adjust Chamber 1 Tyre RM 15
54 Tyre Silvestone M5 215/45/17 1Pcs RM 200
55 Tyre Bridgestone Potenza 215/45/17 1Pcs RM 260
56 Repair Sport Rim 1 Pcs RM 30
Dri8LR3
IN-!i`^yih.i can switch it on...after auto off...no stanby/CD/radio mode...the
audio system is totally offhl)yks`!())~(0o1)
|%؂~~Datey19250635', '55446', 'Official July TT 2004', '0', 'waikhei', '4eab02f72ecb7bfda04246a5ebb97472', '76005', 'yy src=\"http://i1.autoworld.com.my/forum/images/emoticons/smile_shock.gif\" border=\"0\" alt=\"Shock\">e.)yP`>H~A)u should make it as a brand name n market it,sell ip.yA@he....jaga2 masa kopek sticker Felio tu..jangan sampai kena tangkap
dgn. tokey kedai potong tu.... ', ')yDH)) `8%!):12.000y!(3058807', '11854', 'accord timing belt putus', '0', 'hermuss', 'fbfbc73898b8ffdccb3d9eb2603f02fd', '61690'9y8  dX~@ ؂SenderIPerbox (9P'0', 'BridgestoneRE711')(2on track carnival update 2X)s (pid, edit_time, author_id, author_name, ip_address, post_date, topic_id, post_title, new_topic, edit_name, post_key, post_parent, post, old_UserID) VALUES ('1008105', '', '15531', 'BridgestoneRE711', '218.208.224.112','1128779196', '63504', 'proton waja new gearbox console !!! ', '1', 'BridgestoneRE711', 'f6a93ddf4ecdbd6f82616a9b5422e15b', '', 'actually i just DIY spraying it into silver colour only ... \nncie kah ? \nsee the link ... my fotopic . ','BridgestoneRE711@1');alt= 4R3'fairman@1');n@9 }3_D
PqEditedNumberyXHks....\"Smile\">(yP443043y(p3269573', '10893', 'Gua Musang - Jeli, route 66', '0', 'cygnus', '1e0405fda70941b349905dab02551ed0', '8071yyh:for the tag
inside got 50...
ldp ...kesas... sri hartamas tol... sprint tol...damansara tol.....
yy32546488', '10805', 'Beware !! Kancil ADD 8609', '0', 'eddievh', '4f90dab4dccb2af27c203d33c1571b94', '6266yS3S3r?...dbkl osso got gip award to me for community service par \nexcellence! Summore I do it everyday....\"Bigile\">,,p66y4 src=\"http://202.157.189.199/forum/images/emoticons/smile_angry.gif\" border=\"0\" alt=\"Angry\">
y:4787739', '63471', 'Proton to recall 2002 Waja 1.6 due to complaints', '0', 'Firhan', '12c30006159afd3ef8db7ab901c629cc', '148419'y src=\"http://i1.autoworld.com.my/forum/images/emoticons/smile_thumbup.gif\" border=\"0\" alt=\"ThumbUp\">u@y\cs (tid, title, description, state, starter_id, starter_name, start_date, forum_id,topic_firstpost, old_UserID, pinned, approved) VALUES ('63504','proton waja new gearbox console !!! ', '', '', '15531', 'BridgestoneRE711', '1128779196', '45','1008105', 'BridgestoneRE711@1', '0', '1');$R3y@P src=\"http://i1.autoworld.com.my/forum/images/emoticons/smile_thumbup.gif\" border=\"0\" alt=\"ThumbUp\">yy00293534', '10893', 'Gua Musang - Jeli, route 66', '0', 'Ardenz', '9af02cff0026f1e99572205400b1169b', '7794yy[7422553', '10928', 'Idiots never learn?', '0', 'Dar', 'a3e173b51698b77105a68faa9f0614b5', '4240', '
181897yy9 src=\"http://i1.autoworld.com.my/forum/images/emoticons/smile_big.gif\" border=\"0\" alt=\"Big Smile\">'yyX8162019', '63501', 'proton waja improved ? ', '0', 'HRGOH', 'ea009df62f4a859a1cbd06382952a652', '276149', ')ye is the gearbox console?h)|R3X) Where is the gearbox console?! )x8qH?yh7224787', '55445', 'Official Jan 2005 Gathering ', '0', '21nchun', '244e641b3a15ad1699f7594429a72044', 'yy 0ks for the replies. will post in the correct forum in the future.
cheers,
wps 'y6y`! i also wanna see the picture la can u email me the password
n_chun21@yahoo.com ok thanx ... ''yy8566619', '11474', '2006 Civic VS Mazda3', '0', 'Ronk', 'f06da333ceffae76e632a03019bba6e0', '89880', ', 'yyA afternoon everyone...\n\nwah weezy... housekeeping kar....? Anyway, Happy Chinese New Year to \nall...r tyP
yL0784881', '11605', '8th. Gen Honda Civic 2006', '0', 'heaveneart', '14a5fa017fe3c3f48b0465f68ef3abcf', '0Iyto take out the meter panel ?
please advise, thanks IH62503y Jmove. now u can settle summons online with credit card summore. dont
give money to these people.tyyXl6872182', '54958', 'juara k-car?', '0', 'g88', '580e9f52b9fa495934347c4396d5a847', '121962', 'Really ?',,yR3481', '63504', 'proton waja new gearbox console !!! ', '0', 'kenwaja', 'd1bd3700924684fbf1325a847643f762', '286331', 'Quite nice....',E10yeducation prob then what? See ppl in SG and JPN. Do you think parents
there not busy? Why they Q?yHHyably it is in their heads that beating the jam is considered
an \'emergency\' for themselves...'pyxxy8rents house and saw my sister bought WAJA Elite. The
coulour is maroon close to black. The seats were not bad looking man
comparing to my waja. Its all leather coated very nicely done. Feels
great man but no air bag. Just normal one. I like the leather it look
very cun man from out side.
Try and see first guys before talking.ypard my fren there got spycam for speed trap at jalan mahameru to pj
under the kl sentral flyover..yyX8649107', '55446', 'Official July TT 2004', '0', 'sakuragi', '20c16caf47e6b3062a49a575c1bc2fe9', '74378', 'yyk u
how about lowering spring? got eibach or sachs for waja? can fit with oem
waja shock absorbers? 'y?RT INTO ibf_topics (tid, title, description, state, starter_id, starter_name, start_date, forum_id,topic_firstpost, old_UserID, pinned, approved) y9568997', '10889', 'Ghost at South-North Bound', '0', 'Twilight', '77cd7b9268c2a66de26c70291fb13d49', '4469)ypQ@()Wh);', '$R36y(*8217044', '10889', 'Ghost at South-North Bound', '0', 'y2j', 'f4f7c18c76e17d8be2d6b4c39d8a33ee', '4379', 'yy7592781', '62163', 'Membership Renewal for 2004', '1', 'Harold Liew', '8ba9bf0fd93cb4e0eb90fec7987190e0', 'yy7614920', '62163', 'Membership Renewal for 2004', '0', 'Harold Liew', '75de79af084b840667d164c9ec223ab0', 'ye been doing community service work by helping the bandaraya fellas
sweeping the corners with my Waja since day 1 !!!\"Tongue\"yF2839938', '11160', 'speedtrap photo from Sri hartamas', '0', 'tpl', '39a802f06c3a8aa113b069c977f6ca3a', 'nyy src=\"http://203.115.193.189/forum/images/emoticons/smile_approve.gif\" border=\"0\" alt=\"Approve\">,R3yR3R3166', '63504', 'proton waja new gearbox console !!! ', '0', 'luzirahs', 'b29e38715b4e7e24c82c9b484aa2c32e', '286373', 'Pink? That one pinkamy sure will luv it..',.',y5239181', '10891', 'Gold Avanza BHN 2074', '0', 'cygnus', 'a6a8699b2913c6d8ed2d82d7a5379982', '7311', 'Q?(yV
unable to join hcoc yahoo groups la..when can i get my pasword??R3P)y3P$H`1)2 d` (IDey15.. Big Smile928yа4ogliney`mG,
how sure r u abt dis?...i dun think so ler..but d B16A2 is definitely not
a JDM engine..hehehehl tu.pyR3 make it as a brand name n market it,sell ' 0ADR333801125f752a07e01adf60bdd98 'ypx src=\"http://202.157.189.199/forum/images/emoticons/smile_approve.gif\" border=\"0\" alt=\"Approve\">
yy69276527', '55446', 'Official July TT 2004', '0', 'sakuragi', 'd58ce7e423f956b4849531e69289bf96', '76282', ')yxW@ ~9)
$0; Messagey9X5kcivic....
Just curious....do we have b16a engine in our local civic range?
say civic 99 ?
tq
6799)yh` H),R3y src=\"http://203.115.193.189/forum/images/emoticons/smile_shock.gif\" border=\"0\" alt=\"Shock\">
yyз9618490', '11282', '<<< erictck >>>', '0', 'erictck', '0e4e8cdc8203d67ed572997d8f9a9256yy@,
Think you mean petrol mixture too rich. Go for tuning.
hi Harold913620y@@', 'Proton Waja King of post', '0', 'fairman', '3f3533801125f752a07e01adf60bdd98', '216103', 'Really ? I find it is ok ! I like longest woh... don`t u ?\"Big',!$R3Ey0if u want, u can try complaining to one of the MPSJ councilour who
lives in Tmn Equine? Wnna try ur luck?ycs (tid, title, description, state, starter_id, starter_name, start_date, forum_id,topic_firstpost, old_UserID, pinned, approved) VALUES ('63504','proton waja new gearbox console !!! ', '', '', '15531', 'BridgestoneRE711', '1128779196', '45',$R3Hy> sangat berpuas hati. nilai tol yang dikenakan adalah berpatutan
dengan perkhidmatan yang ditawarkan.086dyyonly that..fuel pump will spoil too..that is more important..do u
want to push ar?
hehel.yProton Waja Parts List - revised 2002t?th 1.6 ?ate, starter_id, starter_name, start_date, forum_id,topic_firstpost, old_UserID, pinned, approved)0P
QPS8hHq@ (:1tHypB9039763', '10896', 'Gua Tempurung stretch OK?', '0', 'manfred', '05955aa71aa43d46d833a87f848a76cd', '5836 'yyȺs a waste of rice to have ppl like this on earth. I heck care they
live or die, don\'t dent my caryyC8991686', '12217', 'B16A - DA6 or EF9?', '0', 'mADmAN', 'adf0e05547bd0661fc52c3e623b17299', '54117', '''yyPO .... when ru coming down to penang??
if wan to come to penang. i wan u to buy me something.
can arr? '0yhWopic: 63504 - Post: 1008114
y0@?egee\'s car can rev 9.5k, thats not basically, actually and stockedly,
stock eh?
ha ha ha ha ha
f]yyy \"Smile\"r.k)ys%9)ܹ/(Subjectte, 'y9PQ8954457', '62889', 'Northern WPC Forum', '0', 'Techtic', '12f7f5bcd19ef78e49aca5fbe902d290', '160698', '!y@1omy!9075996', '11401', '1st view of City ZX', '0', 'ytlim', '479ad8c85d3bd2e07bf3d5f009900bf3', '85337', ' 'byyZ2978629', '59152', 'Bodykit....skirting', '0', 'Rukia', 'c479ae432bc7681e461bff196a47626c', '323729', 'en PyyG4825151', '59157', 'BOLT ON TEBO KIT !!!!', '0', 'snakes', '8e84f8c0f877522355e0cef37af1e755', '272182', 'yy`K src=\"http://203.115.193.189/forum/images/emoticons/smile_approve.gif\" border=\"0\" alt=\"Approve\"> '
yyX0083638', '55446', 'Official July TT 2004', '0', 'g88', 'ca10396a0984de83eccaedb060c1d7d6', '79502', '', ')y@ ))xk B~!):53.000y!`engine not designed for turbo. sure cannot last long term. better off
do engine conversion.49 )yд%(@)P$$ymaybe it could have been a fake gun but, only an idiot will take the
risk of confirming that suspicion. yy,
hi Harold, 'Yy81230', '63504', 'proton waja new gearbox console !!! ', '0', 'NabworldYX:p)(:s0)\x`UIDy0 so sick that i\'m freezing to death in my room, altho the temp shows
more than 30 celcius...hyy7917058', '11817', 'accord\' s club', '0', 'Justice01', 'a50665636d792787707fd94f6f3a9194', '58811', '$R3yyp.. \"Big(y`$R3y(2669167', '10893', 'Gua Musang - Jeli, route 66', '0', 'tissue', '88e2d030a7d3be75a6c6d95c64e5c212', '6760)y(xHp~9)p(DepthorIP9(yPhere any hotel in kuala krai ? planning my trip there, so donno to
stop at kuala krai or kota bahru. thnxyI$y3ably it is in their heads that beating the jam is considered
an \'emergency\' for themselves...rlfyynow I know otherwise lor \"Shy\"g.gnhys (pid, edit_time, author_id, author_name, ip_address, post_date, topic_id, post_title, new_topic, edit_name, post_key, post_parent, post, old_UserID) VALUES ('1008101', '', '36800', 'kcfu', '210.19.48.71','1161920911', '63502', 'proton waja improves your driving ? ', '0', 'kcfu', '0594ce483598264b33c5c28ce26890ed', '313118', 'izzit har?...dbkl osso got gip award to me for community service par \nexcellence! Summore I do it everyday....\"Big','kcfu@1');\"Q,R3$R3>yhP&, I was one of them but not now after getting
explanations from other forumers two years ago.!!ttyyHBli sekala pi kL keje tu , NAIK LA MOTorsikal.
tgk aku lecturer pun naik kapchai je.
PI ****pro**gov**yyewlim8,
where did you change it? anyone else know of other types of absorbers for
SV4? cheers....... y%HINo Description Part No Price
3.34
be too low !
the door is open .
too :D
as
Dri8LR3
inside got 50...
cheers,
Go to the top of the page
+Quote Post
fcbgaX
post Nov 21 2006, 11:42 PM
Post #2
Group: Members
wow...too long a part list
+Quote Post
lonelyape
post Nov 22 2006, 09:44 AM
Post #3
Group: Members
try add up the parts list cost and see how much difference with a new car
+Quote Post
choosl76
post Nov 23 2006, 08:22 AM
Post #4
Group: Members
mych -- are you selling these parts? can order the parts from you?
+Quote Post
mych
post Nov 23 2006, 12:07 PM
Post #5
Group: Members
Can order form PE. If WPC member there should be further discount. Just
post for reference. Suggest you copy & paste to excel or word doc for
future reference.
+Quote Post
shda
post Dec 19 2006, 05:09 PM
Post #6
Group: Members
can help me to get the dash panel for waja or not....i need it for some
research.
+Quote Post
awie1001
post Dec 20 2006, 04:54 PM
Post #7
Driver
Group: Members
good job!!!
+Quote Post
chinteng
post Dec 22 2006, 06:45 PM
Post #8
Group: Members
I've gone thru the list, 100% outdated, no wonder some users complaint PE
slaughtering them. Here's the updated one, don't get conned by PE again :)
PW850813 OLD-05.11 NEW-07.19
PW831176 OLD-31.57 NEW-41.42
PW890030 OLD-44.28 NEW-58.10
PW831320 OLD-09.47 NEW-13.31
MB401484 OLD-03.78 NEW-05.32
PW831255 OLD-12.53 NEW-17.62
PW830468 OLD-408.50 NEW-574.28
PW831688 OLD-38.46 NEW-54.06
PW830928 OLD-132.91 NEW-186.85
PW850923 OLD-393.43 NEW-405.60
PW850924 OLD-393.43 NEW-405.60
PW820406 OLD-83.20 NEW-109.16
PW890295 OLD-70.43 NEW-92.41
PW820407 OLD-296.37 NEW-388.87
PW890297 OLD-328.57 NEW-431.11
PW820408 OLD-83.13 NEW-109.07
PW890289 OLD-65.72 NEW-86.23
PW890296 OLD-52.57 NEW-68.98
PW850533 OLD-39.45 NEW-40.67
PW500081 OLD-21.30 NEW-21.96
PW890032 OLD-330.28 NEW-338.14
PW841388 OLD-266.00 NEW-300.05
PW850831 OLD-368.67 NEW-434.36
PW850832 OLD-368.67 NEW-434.36
PW890762 OLD-18.43 NEW-24.18
PW890027 OLD-99.43 NEW-130.46
PW890028 OLD-99.43 NEW-130.46
PW851586 OLD-70.57 NEW-53.61
PW851587 OLD-70.57 NEW-92.60
PW850812 OLD-33.94 NEW-47.71
MB325163 SAME
PW850534 OLD-12.14 NEW-17.06
PW850819 OLD-12.14 NEW-17.06
PW820399 OLD-810.91 NEW-1063.99
PW890298 OLD-880.14 NEW-920.99
PW831450 OLD-12.94 NEW-18.19
PW820254 OLD-06.37 NEW-10.35
PW820414 OLD-15.90 NEW-21.91
PW890293 OLD-30.50 NEW-40.21
PW820258 OLD-27.15 NEW-35.62
PW820252 OLD-04.87 NEW-07.79
PW820260 OLD-07.00 NEW-09.19
PW850671 OLD-49.41 NEW-74.09
PW890272 OLD-328.57 NEW-431.11
PW890282 OLD-1023.12 NEW-1534.21
PW850670 OLD-96.57 NEW-126.71
PW890284 OLD-287.50 NEW-431.11
PW890290 OLD-262.86 NEW-344.90
PW890285 OLD-75.15 NEW-98.60
PW539912 OLD-11.75 NEW-12.11
PW820172 OLD-27.20 NEW-38.24
PW820187 OLD-45.00 NEW-59.04
PW510765 OLD-35.13 NEW-36.24
PW890727 OLD-18.78 NEW-24.64
PW890726 OLD-56.33 NEW-73.91
PW810089 OLD-776.89 NEW-732.99
MD314092 OLD-55.60 NEW-78.16
MD338513 OLD-91.75 NEW-90.14
PW890543 OLD-38.46 NEW-54.06
PW850776 OLD-162.88 NEW-192.38
PW890098 OLD-322.72 NEW-332.70
PW840137 OLD-23.47 NEW-32.99
PW830401 OLD-13.49 NEW-18.97
PW830402 OLD-13.49 NEW-18.97
PW831324 OLD-35.20 NEW-49.48
MU481187 OLD-01.96 NEW-02.58
PW830663 OLD-01.00 NEW-01.31
PW830664 OLD-00.28 NEW-00.37
PW831700 OLD-03.34 NEW-04.69
PW830660 OLD-05.87 NEW-08.25
PW830665 OLD-05.87 NEW-08.25
PW890085 OLD-382.92 NEW-538.32
PW820150 OLD-27.43 NEW-38.57
PW820145 OLD-298.94 NEW-420.25
PW821440 OLD-08.86 NEW-11.62
PW821441 OLD-18.28 NEW-23.99
PW890088 OLD-19.67 NEW-27.65
PW890086 OLD-60.78 NEW-85.44
PW890338 OLD-04.66 NEW-06.56
MD350270 OLD-724.34 NEW-1221.94
PW550249 OLD-196.10 NEW-202.16
PW550245 OLD-193.40 NEW-185.57
MD748300 OLD-1609.86 NEW-2112.28
PW820042 OLD-86.94 NEW-122.22
PW820377 OLD-37.72 NEW-53.03
PW820039 OLD-09.86 NEW-12.94
MD749998 OLD-113.25 NEW-75.42
MD770676 OLD-224.94 NEW-316.22
MD312667 OLD-358.85 NEW-369.95
MD370354 OLD-25.46 NEW-40.26
PW890052 OLD-418.86 NEW-549.58
PW840101 OLD-66.47 NEW-87.22
MS470075 OLD-01.70 NEW-01.75
MD352125 OLD-1996.80 NEW-2807.12
PW841310 OLD-823.63 NEW-1080.67
MB402060 OLD-07.40 NEW-07.63
MD344154 OLD-2389.16 NEW-3358.71
MD978242 OLD-14269.44 NEW-16207.35
MD373091 OLD-7386.35 NEW-11270.08
MD345602 OLD-68.80 NEW-96.72
MD368160 OLD-2902.62 NEW-5363.74
PW810126 OLD-20.45 NEW-28.74
PW810127 OLD-122.66 NEW-172.44
PW810046 OLD-07.79 NEW-10.22
MD978140 OLD-412.73 NEW-580.22
MR420844 OLD-1182.02 NEW-1550.92
MR420441 OLD-19.60 NEW-27.56
MR185648 OLD-94.50 NEW-132.86
PW820070 OLD-31.59 NEW-41.45
PW820071 OLD-29.83 NEW-39.13
PW820064 OLD-118.13 NEW-166.07
MD371776 OLD-256.31 NEW-417.27
MD978141 OLD-470.25 NEW-661.08
PW890024 OLD-312.57 NEW-410.12
MD356151 OLD-332.43 NEW-436.18
PW890029 OLD-102.43 NEW-134.39
PW821513 OLD-63.19 NEW-65.76
MD322720 OLD-469.33 NEW-659.79
PW821376 OLD-28.99 NEW-37.58
MD319791 OLD-303.60 NEW-426.80
MD341633 OLD-270.86 NEW-355.39
PW820203 OLD-456.28 NEW-641.44
PW820998 OLD-43.60 NEW-57.21
PW821000 OLD-61.92 NEW-81.25
MD342397 OLD-123.43 NEW-173.52
MD342281 OLD-29.38 NEW-45.43
PW850812 OLD-33.94 NEt have i[[dS3rs , proton is losing very much , i admit this .
be too low !
the door is open .
too :D
as
Dri8LR3
audio system is totally offhl)yks`!())~(0o0)H$|`QnRety09250635', '55446', 'Official July TT 2004', '0', 'waikhei', '4eab02f72ecb7bfda04246a5ebb97472', '76005', 'yy src=\"http://i1.autoworld.com.my/forum/images/emoticons/smile_shock.gif\" border=\"0\" alt=\"Shock\">e.)yP`>H~@)0TR3U1FileIDrPostCount188',y@@he....jaga2 masa kopek sticker Felio tu..jangan sampai kena tangkap
dgn. tokey kedai potong tu.... ', ')yDH)) `8%!):12.000y!(3058807', '11854', 'accord timing belt putus', '0', 'hermuss', 'fbfbc73898b8ffdccb3d9eb2603f02fd', '61690'`ytR3dP~@ sMsgNotifyrbox (9'0', 'BridgestoneRE711')`2on track carnival update 2X)s (pid, edit_time, author_id, author_name, ip_address, post_date, topic_id, post_title, new_topic, edit_name, post_key, post_parent, post, old_UserID) VALUES ('1008121', '', '44304', 'mych', '202.188.162.24','1164254832', '63505', 'Proton Waja Parts List - revised 2002', '0', 'mych', 'e5e23fddb903fde6f458be0824badb6e', '314161', 'Can order form PE. If WPC member there should be further discount. Just \npost for reference. Suggest you copy & paste to excel or word doc for \nfuture reference. ','mych@1');1');n@8!LR3 PqEditedNumberyXHks....\"Smile\">(y'443043y(p3269573', '10893', 'Gua Musang - Jeli, route 66', '0', 'cygnus', '1e0405fda70941b349905dab02551ed0', '8071yyh:for the tag
inside got 50...
181897yy9 src=\"http://i1.autoworld.com.my/forum/images/emoticons/smile_big.gif\" border=\"0\" alt=\"Big Smile\">'yyX8162019', '63501', 'proton waja improved ? ', '0', 'HRGOH', 'ea009df62f4a859a1cbd06382952a652', '276149', 'y`6604884', '63505', 'Proton Waja Parts List - revised 2002', '0', 'awie1001', '1c360ff25add216dc14dacc5ca7f2e99', '314112', 'R3y7224787', '55445', 'Official Jan 2005 Gathering ', '0', '21nchun', '244e641b3a15ad1699f7594429a72044', 'yy 0ks for the replies. will post in the correct forum in the future.
cheers,
wps 'yy`! i also wanna see the picture la can u email me the password
n_chun21@yahoo.com ok thanx ... ''yy8566619', '11474', '2006 Civic VS Mazda3', '0', 'Ronk', 'f06da333ceffae76e632a03019bba6e0', '89880', ', 'yyA afternoon everyone...\n\nwah weezy... housekeeping kar....? Anyway, Happy Chinese New Year to \nall...r tyyL0784881', '11605', '8th. Gen Honda Civic 2006', '0', 'heaveneart', '14a5fa017fe3c3f48b0465f68ef3abcf', '0Iyescription Part No Price
1 CE0034 [ALL] Alarhanks!I62503y!Jmove. now u can settle summons online with credit card summore. dont
there not busy? Why they Q?(ycy(ably it is in their heads that beating the jam is considered
waja shock absorbers? 'yM@up the parts list cost and see how much difference with a new carr_nameHY\R3rum_id,topic_firstpost, old_UserID, pinned, approved) y9568997', '10889', 'Ghost at South-North Bound', '0', 'Twilight', '77cd7b9268c2a66de26c70291fb13d49', '4469)ypQ@)PX:y*8217044', '10889', 'Ghost at South-North Bound', '0', 'y2j', 'f4f7c18c76e17d8be2d6b4c39d8a33ee', '4379', 'yy7592781', '62163', 'Membership Renewal for 2004', '1', 'Harold Liew', '8ba9bf0fd93cb4e0eb90fec7987190e0', 'yy7614920', '62163', 'Membership Renewal for 2004', '0', 'Harold Liew', '75de79af084b840667d164c9ec223ab0', 'ye been doing community service work by helping the bandaraya fellas
sweeping the corners with my Waja since day 1 !!!\"Tongue\"314967yF2839938', '11160', 'speedtrap photo from Sri hartamas', '0', 'tpl', '39a802f06c3a8aa113b069c977f6ca3a', 'nyy src=\"http://203.115.193.189/forum/images/emoticons/smile_approve.gif\" border=\"0\" alt=\"Approve\">,R3yRT INTO ibf_posts (pid, edit_time, author_id, author_name, ip_address, post_date, topic_id, post_title, new_topic, edit_name, post_key, post_parent, post, old_UserID) .',y5239181', '10891', 'Gold Avanza BHN 2074', '0', 'cygnus', 'a6a8699b2913c6d8ed2d82d7a5379982', '7311', 'Q?yP$R3I\R3\R3XnModeratorIPare835$R3yIH1528002', '10814', 'BFH 9917 accident !!!', '0', 'yokomo', '52be0a8c6c3356daa01c9efc834e0770', '2033', '6yyPond n or anybody..
d8P
8Linky15.. Big Smile928yy`mG,
a JDM engine..hehehehl tu.Ay1help me to get the dash panel for waja or not.002',0Ah, 'mych', '1164123539', '45','y0x src=\"http://202.157.189.199/forum/images/emoticons/smile_approve.gif\" border=\"0\" alt=\"Approve\">
yy69276527', '55446', 'Official July TT 2004', '0', 'sakuragi', 'd58ce7e423f956b4849531e69289bf96', '76282', ')yxW@ ~9)$P
; BDepth01', 'y9X5kcivic....
say civic 99 ?
tq
6799)yh` H)py src=\"http://203.115.193.189/forum/images/emoticons/smile_shock.gif\" border=\"0\" alt=\"Shock\">
hi Harold913620y@@', 'Proton Waja Parts List - revised 2002', '0', 'mych', 'e5e23fddb903fde6f458be0824badb6e', '314161', 'Can order form PE. If WPC member there should be further discount. Just \npost for reference. Suggest you copy & paste to excel or word doc for \nfuture reference. ',Ey0if u want, u can try complaining to one of the MPSJ councilour who
lives in Tmn Equine? Wnna try ur luck?ycs (tid, title, description, state, starter_id, starter_name, start_date, forum_id,topic_firstpost, old_UserID, pinned, approved) VALUES ('63505','Proton Waja Parts List - revised 2002', '', '', '44304', 'mych', '1164123539', '45',96', $R3Hy> sangat berpuas hati. nilai tol yang dikenakan adalah berpatutan
want to push ar?
hehel.yProton Waja Parts List - revised 2002t?th 1.6 ?ate, starter_id, starter_name, start_date, forum_id,topic_firstpost, old_UserID, pinned, approved)6604884', '63505', 'Proton Waja Parts List - revised 2002', '0', 'awie1001', '1c360ff25add216dc14dacc5ca7f2e99', '314112314112ypB9039763', '10896', 'Gua Tempurung stretch OK?', '0', 'manfred', '05955aa71aa43d46d833a87f848a76cd', '5836 'yyȺs a waste of rice to have ppl like this on earth. I heck care they
can arr? '1y
D XXDatey1@?egee\'s car can rev 9.5k, thats not basically, actually and stockedly,
stock eh?
ha ha ha ha ha
f]yyy \"Smile\"r.k)ys%9)ܹ/,؂~Subject6', 'y9PQ8954457', '62889', 'Northern WPC Forum', '0', 'Techtic', '12f7f5bcd19ef78e49aca5fbe902d290', '160698', '!y0:02.000y!9075996', '11401', '1st view of City ZX', '0', 'ytlim', '479ad8c85d3bd2e07bf3d5f009900bf3', '85337', ' 'byyZ2978629', '59152', 'Bodykit....skirting', '0', 'Rukia', 'c479ae432bc7681e461bff196a47626c', '323729', 'en PyyG4825151', '59157', 'BOLT ON TEBO KIT !!!!', '0', 'snakes', '8e84f8c0f877522355e0cef37af1e755', '272182', 'yy`K src=\"http://203.115.193.189/forum/images/emoticons/smile_approve.gif\" border=\"0\" alt=\"Approve\"> '
do engine conversion.49 )yд%(@)y
+Quote Post
RSS Lo-Fi Version  |  Powered By IP.Board © 2008  IPS, Inc Time is now: 31st January 2015 - 02:59 PM
