Autoworld
Autoworld.com.my
2 Pages V   1 2 >
> Price List Spare Part Proton Waja
ady4455
post Apr 18 2008, 03:05 AM
Post #1
5th Gear
Group: Members
BIL SPARE PART PROTON WAJA HARGA
1 Brake Pad Rear Trestor RM 65
2 Brake Pad Front Trestor RM 53
3 Door Handle Rear Original Black Colour RM 28
4 Door Handle Front Local Silver Colour RM 20
5 Door Handle (Local)- (Without Paint), RM 10
6 Door Handle (With Paint) RM 25
7 Suspension Link Front RM 55
8 Arm Suspension Alignment Rear (Mitsubishi) RM 90
9 Engine Mounting (Brand Locko) Full Set RM 180
10 Original Wiper Blade 19/21 RM 23
11 Bearing Wheel Front (TNT) RM 42
12 Oil Seal RM 12
13 Cover Under Fender Front Original RM 55
14 Cross Member Original RM 150
15 Power Window Switch Rear RM 26
16 Power Window Complete Set Siap Upah RM 280
17 Power Window Assembly RM 180
18 Rear Window Glass RM 68
19 Front Window Glass RM 110
20 Battery GP MF NS60 RM 195
21 Battery Century MF RM 210
22 Clock Spring Original With SRS RM 260
23 Door Latch Driver Side Original (Bought at PESC) RM 234
24 Door Handle RM 50
25 Absorber Kayaba Front And Rear ( Sapura Supplier ) RM 350
26 Absorber Monroe Front 1 pcs RM 175
27 Absorber Front Mounting Original RM 85
28 Sport Spring ( Felix ) RM 200
29 Fuel Pump RM 450
30 Fuel Filter RM 70
31 Water Pump RM 122
32 Drive Belt (Mitsu) RM 34
33 Air Cond Belt (Bando) RM 37
34 Crank Sensor (Mitsu oem) RM 218
35 Auto Oil/Power Steering RM 18
36 Brake Fluid (Dot 4/ 060.5L) RM 30
37 ECU Tuning Service Charge RM 25
38 Brake Pads Front 1 Set RM 80
39 Brake Pads Rear 1 Set RM 48
40 Coolant Radiator (Petronas 0.5 ML) RM 13
41 Coolant Radiator (Shell 0.5 ML) RM 15
42 Coolant Radiator (Shell 1.0 ML) RM 25
43 Coolant Radiator (Caltex 0.5 ML) RM 17
44 Coolant Radiator (Tin 0.5 ML Car Accessories) RM 6
45 Castrol GTX 15W 40 RM 60
46 Castrol Magnetic 10W 40 RM 75
47 Air Filter RM 10
48 Oil Filter RM 8
49 Clutch Plate ( Exedy )Complete Set RM 210
50 Spark Plug (NGK R) RM 25
51 Supplier Timing Belt KL/PJ .CALL 012-2908159
- Gaido 2 years warranty RM 200
- Gates RM 130
- Dayco RM 160
- MMC Local RM 130
- MMC Original RM 190
52 Aligmend 4 Tyre RM 25
53 Adjust Chamber 1 Tyre RM 15
54 Tyre Silvestone M5 215/45/17 1Pcs RM 200
55 Tyre Bridgestone Potenza 215/45/17 1Pcs RM 260
56 Repair Sport Rim 1 Pcs RM 30
Go to the top of the page
+Quote Post
cruiser556
post Apr 18 2008, 09:56 PM
Post #2
Group: Members
Hi ady,
is this your repair costs which u were charged? If yes, pls share location of workshops/parts shop as
prices may vary from locations to locations and we can compare. thhanks.
+Quote Post
ady4455
post Apr 19 2008, 10:02 PM
Post #3
5th Gear
Group: Members
Hi Cruiser556,
20 Battery GP MF NS60 RM 195 Glenmarie
21 Battery Century MF RM 210 Glenmarie
26 Absorber Monroe Front 1 pcs RM 175 Glenmarie
28 Sport Spring ( Felix ) RM 200 Sri Muda Sek 25 shah Alam
46 Castrol Magnetic 10W 40 RM 75 Glenmarie
47 Air Filter RM 10 Glenmarie
49 Clutch Plate ( Exedy )Complete Set RM 210 Glenmarie
52 Aligmend 4 Tyre RM 20 at Sri Muda Sek 25 shah Alam
53 Adjust Chamber 1 Tyre RM 15 at Sri Muda Sek 25 shah Alam
Klang City Tyres & Auto Sdn.Bhd
N0.30,Jln Raja Bot,
41400 Klang,selangor.
Call : Mr Tan Chee Haur
H/P: 017-2750790
+Quote Post
cruiser556
post Apr 20 2008, 07:23 PM
Post #4
Group: Members
thanks for the information !!! very detailed listing of parts and prices !
+Quote Post
alldisc
post Apr 20 2008, 08:46 PM
Post #5
Group: Members
now, compare this with EON/PESB price list
1 [All] A/C Belt PW850671 74.09
4 [Patco] A/C Compressor PW850663 1,978.07
5 [Denso] -- as above -- PW850753 1,753.12
6 [Denso] A/C Compressor Bracket PW850667 198.46
7 [Patco] -- as above -- PW850670 126.71
8 [Patco] A/C Compressor Clutch PW890130 545.27
9 [Denso] -- as above -- PW890283 456.42
10 [Patco] A/C Condenser PW890124 633.93
11 [Denso] -- as above -- PW890284 N
12 [Denso] -- as above -- PW890284 431.11
17 [Patco] A/C Evaporator PW890143 811.43
18 [Denso] -- as above -- PW890270 456.42
23 [Patco(Condenser)] A/C Fan Cover PW890193 78.54
24 [Denso(Condenser)] -- as above -- PW890288 101.60
25 [Denso(Condenser)] A/C Fan Motor PW536239 289.64
26 [Patco(Condenser)] -- as above -- PW890128 316.22
27 [Patco(Blower unit)] -- as above -- PW890155 431.11
28 [Denso(Blower unit)] -- as above -- PW890272 431.11
29 [Patco(Discharge)] A/C Hose PW850648 205.43
30 [Patco(Suction)] -- as above -- PW850652 180.13
31 [Denso(Suction)] -- as above -- PW850673 88.85
32 [Denso(Discharge)] -- as above -- PW850674 139.45
33 [Patco(Drier to Evap.)] A/C Pipes - Inner Fender LH PW850661 104.03
34 [Denso(Drier to Evap.)] -- as above -- PW850868 62.52
35 [Patco(Suction)] A/C Pipes Front Firewall PW850653 134.39
36 [Denso(Suction)] -- as above -- PW850657 92.62
37 [Denso] A/C Pipes Headlamp Panel LH PW850765 152.21
38 [Patco] A/C Receiver Drier PW890125 152.21
39 [Denso] -- as above -- PW890285 N
40 [Denso] -- as above -- PW890285 98.60
41 [All] A/C Relay PW539912 12.11
42 [All] Accelerator Cable PW820172 38.24
43 [Clarion] Aerial PW850847 308.25
44 [Delloyd] -- as above -- PW850970 201.19
45 [Clarion] Aerial Cable PW850845 126.53
46 [Clarion] Aerial Pole PW890416 101.03
47 [Delloyd] -- as above -- PW890417 101.03
48 [Denso] Air Cond Blower Cover PW890267 91.29
49 [All] Air Filter Air Box / Resonator PW820187 59.04
50 [All] Air Filter Cover PW890727 24.64
51 [Air Filter to Throttle Body] Air Filter Duct PW820188 73.39
52 [All] Air Filter Element PW510765 N
53 [All] -- as above -- PW510765 36.24
54 [All] Air Filter Lower Case PW890726 73.91
55 [All] Air Press Set PE00002Z 70.00
56 [Delloyd] Alarm Horn PW850796 47.71
57 [Multicode] -- as above -- PW850812 47.71
58 [with Key (Delloyd)] Alarm Remote Control PW850827 86.23
59 [with Key (Multicode)] -- as above -- PW850828SK 46.85
60 [Delloyd] Alarm Switch Bonnet PW850797 7.19
61 [Multicode] -- as above -- PW850813 7.19
62 [All] Alternator PW810089 934.76
63 [All] Alternator Adjusting Bracket MD314092 78.16
64 [All] Alternator Belt MD338513 N
65 [All] -- as above -- MD338513 90.14
66 [All] Alternator Pulley PW890543 54.06
67 [Dashboard Panel] Ashtray PW841354 17.25
68 [Ashtray Handle] Ashtray Face Plate PW841297 7.03
69 [1.6 (Fender)] Badge PW841105 8.37
70 [Bootlid] -- as above -- PW841500 32.99
71 [All] Badge Bonnet PW840137 32.99
72 [LH & RH] Badge Door Rear PW831703 9.64
73 [All] Battery PW850776 175.00
74 [All] Battery Tray PW831453 15.40
75 [All] Bonnet PW890098 N
76 [All] -- as above -- PW890098 332.70
77 [All] Bonnet Hinge LH PW830401 18.97
78 [All] Bonnet Hinge RH PW830402 18.97
79 [All] Bonnet Insulation PW831324 49.48
80 [All] Bonnet Insulation Clip MU481187 2.58
81 [All] Bonnet Latch Stud Plate PW890030 58.10
82 [All] Bonnet Lock PW831176 41.42
83 [All] Bonnet Pull Cable PW831320 13.31
84 [All] Bonnet Release Handle MB401484 5.32
85 [All] Bonnet Stand PW831255 17.62
86 [Above Radiator Grille] Bonnet Weatherstrip Centre PW831700 4.69
87 [All] Bonnet Weatherstrip LH PW830660 8.25
88 [All] Bonnet Weatherstrip Rear PW830666 8.25
89 [All] Bonnet Weatherstrip RH PW830665 8.25
90 [All] Boot Extractor Vent PW850618 27.37
91 [All] Boot Floor PW890016 563.64
92 [All] Boot Floor Front Extension PW890012 354.82
93 [All] Boot have i[[dS3s (pid, edit_time, author_id, author_name, ip_address, post_date, topic_id, post_title, new_topic, edit_name, post_key, post_parent, post, old_UserID) VALUES ('1005353', '', '69347', 'ady4455', '202.75.45.1','1208459143', '63366', 'Price List Spare Part Proton Waja', '1', 'ady4455', 'e616f38346081fd4648c46d6b7cc1cdf', '', 'BIL SPARE PART PROTON WAJA HARGA\n\n1 Brake Pad Rear Trestor RM 65\n2 Brake Pad Front Trestor RM 53\n3 Door Handle Rear Original Black Colour RM 28\n4 Door Handle Front Local Silver Colour RM 20\n5 Door Handle (Local)- (Without Paint), RM 10\n6 Door Handle (With Paint) RM 25\n7 Suspension Link Front RM 55\n8 Arm Suspension Alignment Rear (Mitsubishi) RM 90\n9 Engine Mounting (Brand Locko) Full Set RM 180\n10 Original Wiper Blade 19/21 RM 23\n11 Bearing Wheel Front (TNT) RM 42\n12 Oil Seal RM 12 \n13 Cover Under Fender Front Original RM 55 \n14 Cross Member Original RM 150\n15 Power Window Switch Rear RM 26\n16 Power Window Complete Set Siap Upah RM 280\n17 Power Window Assembly RM 180\n18 Rear Window Glass RM 68\n19 Front Window Glass RM 110 \n20 Battery GP MF NS60 RM 195\n21 Battery Century MF RM 210\n22 Clock Spring Original With SRS RM 260\n23 Door Latch Driver Side Original (Bought at PESC) RM 234\n24 Door Handle RM 50\n25 Absorber Kayaba Front And Rear ( Sapura Supplier ) RM 350\n26 Absorber Monroe Front 1 pcs RM 175\n27 Absorber Front Mounting Original RM 85\n28 Sport Spring ( Felix ) RM 200\n29 Fuel Pump RM 450\n30 Fuel Filter RM 70\n31 Water Pump RM 122\n32 Drive Belt (Mitsu) RM 34\n33 Air Cond Belt (Bando) RM 37\n34 Crank Sensor (Mitsu oem) RM 218\n35 Auto Oil/Power Steering RM 18\n36 Brake Fluid (Dot 4/ 060.5L) RM 30\n37 ECU Tuning Service Charge RM 25\n38 Brake Pads Front 1 Set RM 80\n39 Brake Pads Rear 1 Set RM 48 \n40 Coolant Radiator (Petronas 0.5 ML) RM 13\n41 Coolant Radiator (Shell 0.5 ML) RM 15\n42 Coolant Radiator (Shell 1.0 ML) RM 25\n43 Coolant Radiator (Caltex 0.5 ML) RM 17\n44 Coolant Radiator (Tin 0.5 ML Car Accessories) RM 6\n45 Castrol GTX 15W 40 RM 60\n46 Castrol Magnetic 10W 40 RM 75\n47 Air Filter RM 10\n48 Oil Filter RM 8\n49 Clutch Plate ( Exedy )Complete Set RM 210\n50 Spark Plug (NGK R) RM 25\n51 Supplier Timing Belt KL/PJ .CALL 012-2908159 \n - Gaido 2 years warranty RM 200\n - Gates RM 130\n - Dayco RM 160\n - MMC Local RM 130\n - MMC Original RM 190\n52 Aligmend 4 Tyre RM 25\n53 Adjust Chamber 1 Tyre RM 15\n54 Tyre Silvestone M5 215/45/17 1Pcs RM 200\n55 Tyre Bridgestone Potenza 215/45/17 1Pcs RM 260\n56 Repair Sport Rim 1 Pcs RM 30\n','ady4455@1');0[awxZA(k(kdS3int) RM 25
12 Oil Seal RM 12
29 Fuel Pump RM 450
47 Air Filter RM 10
48 Oil Filter RM 8
- Gates RM 130
- Dayco RM 160
- MMC Local RM 130
n L
(BIL SPARE PART PROTON WAJA HARGA\n\n1 Brake Pad Rear Trestor RM 65\n2 Brake Pad Front Trestor RM 53\n3 Door Handle Rear Original Black Colour RM 28\n4 Door Handle Front Local Silver Colour RM 20\n5 Door Handle (Local)- (Without Paint), RM 10\n6 Door Handle (With Paint) RM 25\n7 Suspension Link Front RM 55\n8 Arm Suspension Alignment Rear (Mitsubishi) RM 90\n9 Engine Mounting (Brand Locko) Full Set RM 180\n10 Original Wiper Blade 19/21 RM 23\n11 Bearing Wheel Front (TNT) RM 42\n12 Oil Seal RM 12 \n13 Cover Under Fender Front Original RM 55 \n14 Cross Member Original RM 150\n15 Power Window Switch Rear RM 26\n16 Power Window Complete Set Siap Upah RM 280\n17 Power Window Assembly RM 180\n18 Rear Window Glass RM 68\n19 Front Window Glass RM 110 \n20 Battery GP MF NS60 RM 195\n21 Battery Century MF RM 210\n22 Clock Spring Original With SRS RM 260\n23 Door Latch Driver Side Original (Bought at PESC) RM 234\n24 Door Handle RM 50\n25 Absorber Kayaba Front And Rear ( Sapura Supplier ) RM 350\n26 Absorber Monroe Front 1 pcs RM 175\n27 Absorber Front Mounting Original RM 85\n28 Sport Spring ( Felix ) RM 200\n29 Fuel Pump RM 450\n30 Fuel Filter RM 70\n31 Water Pump RM 122\n32 Drive Belt (Mitsu) RM 34\n33 Air Cond Belt (Bando) RM 37\n34 Crank Sensor (Mitsu oem) RM 218\n35 Auto Oil/Power Steering RM 18\n36 Brake Fluid (Dot 4/ 060.5L) RM 30\n37 ECU Tuning Service Charge RM 25\n38 Brake Pads Front 1 Set RM 80\n39 Brake Pads Rear 1 Set RM 48 \n40 Coolant Radiator (Petronas 0.5 ML) RM 13\n41 Coolant Radiator (Shell 0.5 ML) RM 15\n42 Coolant Radiator (Shell 1.0 ML) RM 25\n43 Coolant Radiator (Caltex 0.5 ML) RM 17\n44 Coolant Radiator (Tin 0.5 ML Car Accessories) RM 6\n45 Castrol GTX 15W 40 RM 60\n46 Castrol Magnetic 10W 40 RM 75\n47 Air Filter RM 10\n48 Oil Filter RM 8\n49 Clutch Plate ( Exedy )Complete Set RM 210\n50 Spark Plug (NGK R) RM 25\n51 Supplier Timing Belt KL/PJ .CALL 012-2908159 \n - Gaido 2 years warranty RM 200\n - Gates RM 130\n - Dayco RM 160\n - MMC Local RM 130\n - MMC Original RM 190\n52 Aligmend 4 Tyre RM 25\n53 Adjust Chamber 1 Tyre RM 15\n54 Tyre Silvestone M5 215/45/17 1Pcs RM 200\n55 Tyre Bridgestone Potenza 215/45/17 1Pcs RM 260\n56 Repair Sport Rim 1 Pcs RM 30\n ofx>
((`S3s (pid, edit_time, author_id, author_name, ip_address, post_date, topic_id, post_title, new_topic, edit_name, post_key, post_parent, post, old_UserID) VALUES ('1005353', '', '69347', 'ady4455', '202.75.45.1','1208459143', '63366', 'Price List Spare Part Proton Waja', '1', 'ady4455', 'e616f38346081fd4648c46d6b7cc1cdf', '', 'BIL SPARE PART PROTON WAJA HARGA\n\n1 Brake Pad Rear Trestor RM 65\n2 Brake Pad Front Trestor RM 53\n3 Door Handle Rear Original Black Colour RM 28\n4 Door Handle Front Local Silver Colour RM 20\n5 Door Handle (Local)- (Without Paint), RM 10\n6 Door Handle (With Paint) RM 25\n7 Suspension Link Front RM 55\n8 Arm Suspension Alignment Rear (Mitsubishi) RM 90\n9 Engine Mounting (Brand Locko) Full Set RM 180\n10 Original Wiper Blade 19/21 RM 23\n11 Bearing Wheel Front (TNT) RM 42\n12 Oil Seal RM 12 \n13 Cover Under Fender Front Original RM 55 \n14 Cross Member Original RM 150\n15 Power Window Switch Rear RM 26\n16 Power Window Complete Set Siap Upah RM 280\n17 Power Window Assembly RM 180\n18 Rear Window Glass RM 68\n19 Front Window Glass RM 110 \n20 Battery GP MF NS60 RM 195\n21 Battery Century MF RM 210\n22 Clock Spring Original With SRS RM 260\n23 Door Latch Driver Side Original (Bought at PESC) RM 234\n24 Door Handle RM 50\n25 Absorber Kayaba Front And Rear ( Sapura Supplier ) RM 350\n26 Absorber Monroe Front 1 pcs RM 175\n27 Absorber Front Mounting Original RM 85\n28 Sport Spring ( Felix ) RM 200\n29 Fuel Pump RM 450\n30 Fuel Filter RM 70\n31 Water Pump RM 122\n32 Drive Belt (Mitsu) RM 34\n33 Air Cond Belt (Bando) RM 37\n34 Crank Sensor (Mitsu oem) RM 218\n35 Auto Oil/Power Steering RM 18\n36 Brake Fluid (Dot 4/ 060.5L) RM 30\n37 ECU Tuning Service Charge RM 25\n38 Brake Pads Front 1 Set RM 80\n39 Brake Pads Rear 1 Set RM 48 \n40 Coolant Radiator (Petronas 0.5 ML) RM 13\n41 Coolant Radiator (Shell 0.5 ML) RM 15\n42 Coolant Radiator (Shell 1.0 ML) RM 25\n43 Coolant Radiator (Caltex 0.5 ML) RM 17\n44 Coolant Radiator (Tin 0.5 ML Car Accessories) RM 6\n45 Castrol GTX 15W 40 RM 60\n46 Castrol Magnetic 10W 40 RM 75\n47 Air Filter RM 10\n48 Oil Filter RM 8\n49 Clutch Plate ( Exedy )Complete Set RM 210\n50 Spark Plug (NGK R) RM 25\n51 Supplier Timing Belt KL/PJ .CALL 012-2908159 \n - Gaido 2 years warranty RM 200\n - Gates RM 130\n - Dayco RM 160\n - MMC Local RM 130\n - MMC Original RM 190\n52 Aligmend 4 Tyre RM 25\n53 Adjust Chamber 1 Tyre RM 15\n54 Tyre Silvestone M5 215/45/17 1Pcs RM 200\n55 Tyre Bridgestone Potenza 215/45/17 1Pcs RM 260\n56 Repair Sport Rim 1 Pcs RM 30\n','ady4455@1');
A@INSERT INTO ibf_posts (pid, edit_time, author_id, author_name, ip_address, post_date, topic_id, post_title, new_topic, edit_name, post_key, post_parent, post, old_UserID) VALUES ('1005353', '', '69347', 'ady4455', '202.75.45.1','1208459143', '63366', 'Price List Spare Part Proton Waja', '1', 'ady4455', 'e616f38346081fd4648c46d6b7cc1cdf', '', 'BIL SPARE PART PROTON WAJA HARGA\n\n1 Brake Pad Rear Trestor RM 65\n2 Brake Pad Front Trestor RM 53\n3 Door Handle Rear Original Black Colour RM 28\n4 Door Handle Front Local Silver Colour RM 20\n5 Door Handle (Local)- (Without Paint), RM 10\n6 Door Handle (With Paint) RM 25\n7 Suspension Link Front RM 55\n8 Arm Suspension Alignment Rear (Mitsubishi) RM 90\n9 Engine Mounting (Brand Locko) Full Set RM 180\n10 Original Wiper Blade 19/21 RM 23\n11 Bearing Wheel Front (TNT) RM 42\n12 Oil Seal RM 12 \n13 Cover Under Fender Front Original RM 55 \n14 Cross Member Original RM 150\n15 Power Window Switch Rear RM 26\n16 Power Window Complete Set Siap Upah RM 280\n17 Power Window Assembly RM 180\n18 Rear Window Glass RM 68\n19 Front Window Glass RM 110 \n20 Battery GP MF NS60 RM 195\n21 Battery Century MF RM 210\n22 Clock Spring Original With SRS RM 260\n23 Door Latch Driver Side Original (Bought at PESC) RM 234\n24 Door Handle RM 50\n25 Absorber Kayaba Front And Rear ( Sapura Supplier ) RM 350\n26 Absorber Monroe Front 1 pcs RM 175\n27 Absorber Front Mounting Original RM 85\n28 Sport Spring ( Felix ) RM 200\n29 Fuel Pump RM 450\n30 Fuel Filter RM 70\n31 Water Pump RM 122\n32 Drive Belt (Mitsu) RM 34\n33 Air Cond Belt (Bando) RM 37\n34 Crank Sensor (Mitsu oem) RM 218\n35 Auto Oil/Power Steering RM 18\n36 Brake Fluid (Dot 4/ 060.5L) RM 30\n37 ECU Tuning Service Charge RM 25\n38 Brake Pads Front 1 Set RM 80\n39 Brake Pads Rear 1 Set RM 48 \n40 Coolant Radiator (Petronas 0.5 ML) RM 13\n41 Coolant Radiator (Shell 0.5 ML) RM 15\n42 Coolant Radiator (Shell 1.0 ML) RM 25\n43 Coolant Radiator (Caltex 0.5 ML) RM 17\n44 Coolant Radiator (Tin 0.5 ML Car Accessories) RM 6\n45 Castrol GTX 15W 40 RM 60\n46 Castrol Magnetic 10W 40 RM 75\n47 Air Filter RM 10\n48 Oil Filter RM 8\n49 Clutch Plate ( Exedy )Complete Set RM 210\n50 Spark Plug (NGK R) RM 25\n51 Supplier Timing Belt KL/PJ .CALL 012-2908159 \n - Gaido 2 years warranty RM 200\n - Gates RM 130\n - Dayco RM 160\n - MMC Local RM 130\n - MMC Original RM 190\n52 Aligmend 4 Tyre RM 25\n53 Adjust Chamber 1 Tyre RM 15\n54 Tyre Silvestone M5 215/45/17 1Pcs RM 200\n55 Tyre Bridgestone Potenza 215/45/17 1Pcs RM 260\n56 Repair Sport Rim 1 Pcs RM 30\n','ady4455@1'); A\S3Bridgestone Potenza 215/45/17 1Pcs RM 260
hauHHXS3N WAJA HARGA
12 Oil Seal RM 12
29 Fuel Pump RM 450
47 Air Filter RM 10
48 Oil Filter RM 8
- Gates RM 130
- Dayco RM 160
- MMC Local RM 130
ake.BIL SPARE PART PROTON WAJA HARGA
12 Oil Seal RM 12
29 Fuel Pump RM 450
47 Air Filter RM 10
48 Oil Filter RM 8
- Gates RM 130
- Dayco RM 160
- MMC Local RM 130
Dri8LR3
IN-!i`^yih.i can switch it on...after auto off...no stanby/CD/radio mode...the
audio system is totally offhl9yD-,!`XnClosedID)9HQ N~ )>hH}y 9250635', '55446', 'Official July TT 2004', '0', 'waikhei', '4eab02f72ecb7bfda04246a5ebb97472', '76005', 'yy src=\"http://i1.autoworld.com.my/forum/images/emoticons/smile_shock.gif\" border=\"0\" alt=\"Shock\">e.9yJ
A2Moderator', '9!y@he....jaga2 masa kopek sticker Felio tu..jangan sampai kena tangkap
dgn. tokey kedai potong tu.... ', ')yQ8>XPT))h3H(U N: )!19 22:02:15.000y (3058807', '11854', 'accord timing belt putus', '0', 'hermuss', 'fbfbc73898b8ffdccb3d9eb2603f02fd', '61690'yPPpvs (pid, edit_time, author_id, author_name, ip_address, post_date, topic_id, post_title, new_topic, edit_name, post_key, post_parent, post, old_UserID) VALUES ('1005351', '', '40236', 'wajaX4288', '219.95.109.138','1102056595', '63365', 'Price for side mirror spray paint', '0', 'wajaX4288', '0546c7c9a316a3c3de063d0f6113919e', '252819', 'ok, will buzz u again when i got mine change...tx','wajaX4288@1');
frm ( Jln Balakong, near to Brothers \nBalakong. Wider choice can be found at another shop near Connought, but \nthe price quite expensive.','AbahWafi@1');to thpqR3R3 buzz u again when i got mine change...txhin 1 0ADR3completed the job. ',or$R3yHks....\"Smile\">(yb@$R3y(p3269573', '10893', 'Gua Musang - Jeli, route 66', '0', 'cygnus', '1e0405fda70941b349905dab02551ed0', '8071yyh:for the tag
inside got 50...
ldp ...kesas... sri hartamas tol... sprint tol...damansara tol.....
yy32546488', '10805', 'Beware !! Kancil ADD 8609', '0', 'eddievh', '4f90dab4dccb2af27c203d33c1571b94', '6266yst changed my steering pump few days ago at Eon service centre, cost
me about Rm596.
Steering pump = Rm 531
fluid = Rm 20
Labour charge = Rm 45
Is this a reasonable price ?
Bon bon 0.,y4 src=\"http://202.157.189.199/forum/images/emoticons/smile_angry.gif\" border=\"0\" alt=\"Angry\">
ydard maaa....this is WAJA\"Clown\"y src=\"http://i1.autoworld.com.my/forum/images/emoticons/smile_thumbup.gif\" border=\"0\" alt=\"ThumbUp\">u yRT INTO ibf_topics (tid, title, description, state, starter_id, starter_name, start_date, forum_id,topic_firstpost, old_UserID, pinned, approved) VALUES ('63366','Price List Spare Part Proton Waja', '', '', '69347', 'ady4455', '1208459143', '45',',i9 kV @~ModeratorIP'y9P src=\"http://i1.autoworld.com.my/forum/images/emoticons/smile_thumbup.gif\" border=\"0\" alt=\"ThumbUp\">yy00293534', '10893', 'Gua Musang - Jeli, route 66', '0', 'Ardenz', '9af02cff0026f1e99572205400b1169b', '7794yy[7422553', '10928', 'Idiots never learn?', '0', 'Dar', 'a3e173b51698b77105a68faa9f0614b5', '4240', '
181897yy9 src=\"http://i1.autoworld.com.my/forum/images/emoticons/smile_big.gif\" border=\"0\" alt=\"Big Smile\">'yyo secret dungeon and PM him directly...
I need to visit the paintshop too... sms me har?y\ hardworking i c....\"Big
y7224787', '55445', 'Official Jan 2005 Gathering ', '0', '21nchun', '244e641b3a15ad1699f7594429a72044', 'yy 0ks for the replies. will post in the correct forum in the future.
cheers,
wps 'y6>1y`! i also wanna see the picture la can u email me the password
n_chun21@yahoo.com ok thanx ... ''yy8566619', '11474', '2006 Civic VS Mazda3', '0', 'Ronk', 'f06da333ceffae76e632a03019bba6e0', '89880', ', 'yyA afternoon everyone...\n\nwah weezy... housekeeping kar....? Anyway, Happy Chinese New Year to \nall...r tyH!yL0784881', '11605', '8th. Gen Honda Civic 2006', '0', 'heaveneart', '14a5fa017fe3c3f48b0465f68ef3abcf', '09yBa0MhMsgTypeD109H$ `ReplyToIDy0Jmove. now u can settle summons online with credit card summore. dont
give money to these people.tyyXl6872182', '54958', 'juara k-car?', '0', 'g88', '580e9f52b9fa495934347c4396d5a847', '121962', 'Really ?',,yXP` B~s;`!TpXn:$ (Mp?kcfu@1yeducation prob then what? See ppl in SG and JPN. Do you think parents
there not busy? Why they Q?(y`4oglinexCy(ably it is in their heads that beating the jam is considered
an \'emergency\' for themselves...'py', 'Price for side mirror spray paint', '0', 'wajaX4288', '0546c7c9a316a3c3de063d0f6113919e', '252819', 'ok, will buzz u again when i got mine change...tx',ng.curPj
If frm Cheras Perdana....u turn left (Telekom Building on your left)!e stillPadR3dR3.
. Keep drivintil 300 KM(end of gearbox life time).
ypard my fren there got spycam for speed trap at jalan mahameru to pj
under the kl sentral flyover..yyX8649107', '55446', 'Official July TT 2004', '0', 'sakuragi', '20c16caf47e6b3062a49a575c1bc2fe9', '74378', 'yyk u
how about lowering spring? got eibach or sachs for waja? can fit with oem
waja shock absorbers? 'yhRT INTO ibf_topics (tid, title, description, state, starter_id, starter_name, start_date, forum_id,topic_firstpost, old_UserID, pinned, approved) y9568997', '10889', 'Ghost at South-North Bound', '0', 'Twilight', '77cd7b9268c2a66de26c70291fb13d49', '4469)y
X(/H()hX,N~y(*8217044', '10889', 'Ghost at South-North Bound', '0', 'y2j', 'f4f7c18c76e17d8be2d6b4c39d8a33ee', '4379', 'yy7592781', '62163', 'Membership Renewal for 2004', '1', 'Harold Liew', '8ba9bf0fd93cb4e0eb90fec7987190e0', 'yy7614920', '62163', 'Membership Renewal for 2004', '0', 'Harold Liew', '75de79af084b840667d164c9ec223ab0', '9yW6: QDateLast', 'a99Ewx  `:SubDisplay'9Hnyaak2 x payah keringkan poket la....
Ada member2 tau ko, lagu mano nok buka ECU pastu kering sendiri.y432063yF2839938', '11160', 'speedtrap photo from Sri hartamas', '0', 'tpl', '39a802f06c3a8aa113b069c977f6ca3a', 'nyy src=\"http://203.115.193.189/forum/images/emoticons/smile_approve.gif\" border=\"0\" alt=\"Approve\">,R3y`]R3x 1.8 A8Check modular connector if loose or masuk air. I a, 'ab@A $(  MsgNotifyqx(y5239181', '10891', 'Gold Avanza BHN 2074', '0', 'cygnus', 'a6a8699b2913c6d8ed2d82d7a5379982', '7311', 'Q?(yPtXI(\R3\R3XnModeratorIPare835$R3yIH1528002', '10814', 'BFH 9917 accident !!!', '0', 'yokomo', '52be0a8c6c3356daa01c9efc834e0770', '2033', '6yyPond n or anybody..
unable to join hcoc yahoo groups la..when can i get my pasword??R3P)y(~p>0)(hd N8Datey05.. Big Smile928y
y`mG,
+Quote Post
kohf1drive
post Mar 25 2009, 09:03 PM
Post #6
Group: Members
anyone can repair this thread?
thank you
+Quote Post
post Mar 25 2009, 10:21 PM
Post #7
Group: Members
QUOTE (kohf1drive @ Mar 25 2009, 09:03 PM) *
thank you
*Point at Ah Koh & shout*
+Quote Post
darreltian
post Mar 26 2009, 12:38 PM
Post #8
Group: Members
QUOTE (SplitFire @ Mar 25 2009, 10:21 PM) *
Kak Jaime, did u manage to find Ah Koh didi?
+Quote Post
kohf1drive
post Mar 26 2009, 01:31 PM
Post #9
Group: Members
QUOTE (darreltian @ Mar 26 2009, 12:38 PM) *
WOI!
+Quote Post
post Mar 26 2009, 11:10 PM
Post #10
Group: Members
+Quote Post
2 Pages V   1 2 >
RSS Lo-Fi Version  |  Powered By IP.Board © 2008  IPS, Inc Time is now: 22nd May 2013 - 04:03 AM
