| Autoworld.com.my |
Jul 31 2004, 11:01 AM
Post
Member ![]() Group: Members Posts: 16 Joined: 8-January 04 Member No.: 32,893 |
i want to change my iswara ori brake to a better one. any sifu here can
give me some suggestion on which mitsu model n what modification that i need to do???? |
Jul 31 2004, 02:15 PM
Post
White Lightning ![]() ![]() ![]() Group: Members Posts: 5,232 Joined: 3-March 04 Member No.: 34,570 |
iswara's braking system is quite weak as my experience....
by the way...u need to tell me ur driving behaviour.. my old iswara was using evo 3's brake pump system which cost me RM150 . braking power is quite but use it for long under heavy breaking...smokes will come out....so i recommend u to change ur brake pads and also disc if possible...iswara's front disc are solid..thats the bad side.. |
Jul 31 2004, 04:21 PM
Post
normaly is for normal driving but some went kena cucuk u ppl know
lar....... i want to change my front brake 1st, any model from mitsu can feed it???? how about the vr4 1??? any modify needed?? |
Jul 31 2004, 04:42 PM
Post
can also ..but b4 that upgrade ur brake pump....
my suggestion is upgrade the brake pump first...if u wanna use for normal driving..but one consequence is these powerfull brakes are very dangerous when driving in rains....it gets locks up easily ....the choice is urs... |
Jul 31 2004, 06:35 PM
Post
Hot Rod ![]() ![]() ![]() ![]() Group: Members Posts: 10,218 Joined: 9-May 04 Member No.: 36,334 |
and u will bang the car like jeremy
Aug 1 2004, 10:32 AM
Post
i saw my using a pajero pamp, it's that good?
Aug 1 2004, 11:14 PM
Post
chang ...i dont get u..
Aug 2 2004, 12:10 AM
Post
pajero brake pump at the iswara?
Aug 2 2004, 01:01 AM
Post
![]() Duke of Hazzard ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 48,236 Joined: 12-May 01 Member No.: 2,654 |
changkp,
What you can do are the follow. 1. Upgrade your brake servo to Wira, Honda or even Pajero. 2. Change your rear hub to Mirage disc 3. Upgrade your stock brake pad to Bendix or EBC IMHO, option one is more then enug liao. |
Lo-Fi Version | Powered By IP.Board © 2008 IPS, Inc | Time is now: 19th May 2013 - 04:38 AM |
