Autoworld
Autoworld.com.my
3 Pages V   1 2 3 >
> which oil grade 20W50 or 15W40
rahmane21
post Jun 14 2004, 08:26 PM
Post #1
Group: Members
Hi all,
So far i am using 20W50 oil grade, and now looking into
less "friction" by using 15W40 so will reduce some "pressure" on the
engine at high RPM with normal running temp, probably will prolong
life of oil seals, reduce engine stress etc. Of course, it's still
mineral based either way.
Does this make sense with what i am trying to achieve, or it's the other
way round?
rahman
Go to the top of the page
+Quote Post
BktRokan
post Jun 15 2004, 09:28 AM
Post #2
Group: Members
friction...with higher viscosity...less friction...
but too high viscosity...make you engine work harder...so...i think you
mean this "friction"...
But generally ...higher viscosity for longer life of the engine...and
lower viscosity for higher fuel economy...
+Quote Post
rahmane21
post Jun 15 2004, 11:16 AM
Post #3
Group: Members
boss,
so do you know 15W40 viscosity compared to 20W50? Is it too much
difference that i should use 20W50 for longer life, would 15W40 give
balance of fuel economy/longer life.
rahman
+Quote Post
sillyman
post Jun 15 2004, 11:24 AM
Post #4
Group: Members
if your car is not too old or noisy . . . use 15w/40. If u can afford use
semi syn.
+Quote Post
BktRokan
post Jun 16 2004, 01:25 PM
Post #5
Group: Members
both are okay...
go ahead and change to 15W40...but dont expect big saving on fuel
economy...more like 2-3%...or 5% max...
+Quote Post
tpl
post Jun 16 2004, 10:29 PM
Post #6
N20 Soul
Group: Members
ive been using 20-50 multigrade since new car for abt 3yrs n just recently
changed to 15-50 semi-syn. n honestly no diff. at all.
+Quote Post
BktRokan
post Jun 17 2004, 08:58 AM
Post #7
Group: Members
but note that he is changing to 15W40...40 indicates viscosity at
operating temperature...which is lower than 50...lower viscosity means
less force required for the engine part to move...which should result in
better FC...at least on paper it should...
+Quote Post
CarOnly
post Jun 17 2004, 01:27 PM
Post #8
Group: Members
But if you engage in traffic jam under extremely hot afternoon, protection
to the engine is less if using 15W40 compare with 20W50
+Quote Post
Art806
post Jun 18 2004, 09:28 PM
Post #9
Group: Members
for a 1.3 car, you can feel the difference between 20/50 and 15/40
viscocity, the load is lighter for the engine when revved hard, according
to my experience
+Quote Post
robinsonz
post Jun 19 2004, 09:58 AM
Post #10
Driver
Group: Members
base on all sifu experience, for wira 1.3, which spec is good?
+Quote Post
3 Pages V   1 2 3 >
RSS Lo-Fi Version  |  Powered By IP.Board © 2008  IPS, Inc Time is now: 25th May 2013 - 04:24 PM
