| Autoworld.com.my |
May 13 2008, 03:50 PM
Post
3rd Gear Group: Members Posts: 3 Joined: 13-May 08 Member No.: 73,130 |
hi
saya amat perlukan pendapat dari anda... Sy memiliki perodua kelisa sejak 2002. Sejak tahun ini ada mengalami masalah di mana aircondnya tetap berfungsi walaupun tidak "on" dan lampu amaran untuk enjin menyala. P2 SC telah 'menasihatkan' saya untuk menukarkan semua wire yang ada dengan menyatakan bahawa mereka tidak tahu wire yang mana satu yang bermasalah - kos RM 1200. Walaubagaimanapun, apabila sy bertanyakan kepada pendapat lain @ mekanik lain, mereka menyatakan masalah dengan computer box. Harganya di perodua adalah RM4000.00. Kalau RM400 xdak masalah sangat. Ada tak sesiapa yang pernah mengalami masalah yang sama atau ada tak cadangan yang boleh diberikan untuk mengatasi masalah ini. T. Kasih. |
May 13 2008, 05:48 PM
Post
![]() Veteran ![]() ![]() Group: Members Posts: 215 Joined: 27-December 06 Member No.: 63,150 |
wiring problem.
its not computer box problem. it just effect yur aircond and engine check light problem... if computer box, u will facing more problem than this 2... dont go to PSC, sometime they dont know anything... ask yur friend or neighbour that know the best mechanic at yur area espacially on car electrical and electronic. that will solve yur problem and it will cost u less then RM1200... mybe around RM300 - RM400 only... |
May 13 2008, 07:42 PM
Post
Tokyo Drifter ![]() ![]() ![]() Group: Members Posts: 3,304 Joined: 3-April 07 From: Dungun,Melaka,KB,Siam Member No.: 64,985 |
this is the time where community helps..u should be in the kelisa's
community or club and i'll sure there's someone willing to lend their parts for troubleshooting.. just a suggestion tho...as i'm very pleasant with the community i'm with now..very helpful.u should try.. |
May 14 2008, 03:33 AM
Post
![]() Fast & Furious ![]() ![]() ![]() Group: Members Posts: 1,199 Joined: 9-September 07 From: Yokosuka, Kanagawa Member No.: 68,238 |
agreed with iwae405.
but why SC not recommending u a resetting the ECU? no need replacement laa. go to chop shop...lot of used ECU there. |
May 14 2008, 10:10 AM
Post
White Lightning ![]() ![]() ![]() Group: Members Posts: 6,135 Joined: 9-April 02 Member No.: 19,559 |
used ECU from japan much cheaper and i heard is more powerful cos it's
designed for ron100 petrol in japan but before change ECU, check if there is any bad connector at those sensors, sometime disconnection can happen due to engine vibration causing the 'check engine' warning light on but if it's the wiring that is disconnected, then hv to really change the wiring cos it's not easy to locate which wire and where it's disconnected and i dun think u can get used wiring loom at chop shop |
May 14 2008, 01:47 PM
Post
thekop555
dah 2x sy p check kt tempat berbeza, guna comptr..1 kat SC dan 1 lg kt mekanik khusus bahagian wiring tapi keduanya x dpt mengenalpasti punca. Dua tiga hari lepas pomen lain pulak, dia cuma repair dan nasihatkan untuk tukar. Biasanya dia akan jadi lepas tu hilang untuk beberapa lama dan jadi balik. Masalah paling besar apabila jadi adalah bahagian enjin akan jd mcm peti ais dipenuhi dengan ais sebab aircond berfungsi dgn tahap maksima dan x boleh nak cntrol..dan dalam kereta tidak sejuk.. Kedai aircond pun sy p tp xdak masalah aircond.. Try survey 2nd hand kt kedai potong pun xjumpa lg... Pening ni... |
May 14 2008, 03:34 PM
Post
wahh, suprise... quite complicated
i hav no idea right now mybe u need to join the kelisa club or kelisa club forum as mention by other forumer... sure they can help... |
May 14 2008, 05:44 PM
Post
akan jd mcm peti ais dipenuhi dengan ais sebab aircond berfungsi dgn tahap maksima dan x boleh nak cntrol....... .................................................................... from this description la,most likely it's ur blower at fault..u see,compressor keeps pumping the gas and the cooling coil always working..it's just your blower didn't blow air to produce 'air' cond and then cooling keeps happening without distribution..how do i say this...seems confusing la.. ok,macam ni..blower tak jalan,sbb tu ais tu terbentuk kat high pressure pipe.. |
May 14 2008, 08:04 PM
Post
Advanced ![]() Group: Members Posts: 90 Joined: 28-September 04 Member No.: 40,320 |
kepada comel.i also have the same problem with my kenari.same engine with
the kelisa.problem with my car is the radiator fan not working.so change fan motor n wiring also not working.dead end.so sent to acond+wiring shop after one day they said confirm computer box.blur. sent to per2 second opnion.after one week they call n confirm computer box.i asked how much?rm4000 pengsan.new kenari/kelisa computer box cheaper but not the same.the only way is to find somebody is willing to repair the computer box.i did that and syukur it work without a hiccup until 2day per2 good car bad service from service center and can die on the spare part price. take care comel n good luck.......... |
May 15 2008, 09:16 AM
Post
kunir
kat mane tu awak repair..? kot2 la dekat dgn tpt sy... |
Lo-Fi Version | Powered By IP.Board © 2008 IPS, Inc | Time is now: 21st May 2013 - 08:53 PM |
