Autoworld
Autoworld.com.my
2 Pages V   1 2 >
> Kancil Fuel Filter
armanio
post Dec 9 2003, 02:14 PM
Post #1
Group: Members
Hi Guys,
I want to replace the fuel filter for my new second hand Kancil 660M. I
plan to DIY laa, but the problem is I can't find the fuel filter. Can
anybody give me a hint where can I find the fuel filter !
PLEASE HEEELLP !!!
Go to the top of the page
+Quote Post
Spasm
post Dec 9 2003, 04:00 PM
Post #2
Group: Members
Below the fuel pump inlet..left side.
+Quote Post
stupe
post Dec 9 2003, 04:22 PM
Post #3
Group: Members
yeap, u can see it if u jack up the car, look at the left side, below the
petrol pump inlet, inside the back tyre side. kenot miss it one la...
if u want to DIY, make sure the fuel filter is at the correct arrow
postion.
+Quote Post
Madhusher
post Dec 9 2003, 08:07 PM
Post #4
Group: Members
i always thought it at the engine bay like other car, but after searching
for a while, my mechanic told me its at the back. somewhere near where you
pump the petrol in.
+Quote Post
monster111
post Dec 9 2003, 08:55 PM
Post #5
Group: Banned
see ur kancil from it a$$, it is on ur left hand side, beside ur tire
but can DIY meh?
the petrol will spray out if u cabut the hose i think...
+Quote Post
Spasm
post Dec 10 2003, 10:26 AM
Post #6
Group: Members
Hrmm...
Ehh..since you dont know the location of the fuel pump before thisWink..i
suggest u dont DIY la...send to shop first... see them change few
times...then u try after that..
+Quote Post
stupe
post Dec 10 2003, 10:36 AM
Post #7
Group: Members
nola, don't worry, the petrol won't shoot out like some arteries cut.
there will be trickles, more like pipe leaking at home(the washer gone
type)...
so no worries, jsut make sure that the position of the arrow(ie fuel flow)
for the filter is correct, look out for the arrow.
and before u buy them, make sure u check with the car spare part seller
for the kancil 660 or 850(whichever u own) fuel filter, original cost
about rm20(from P2, made by Cycle and Carriage) or rm30(Ori -Japan,
daihatsu) or even the local type, ie cap-mark at rm8 only.
take your pic, but personally, i've been using the ori P2 type, usually
get it at rm16-18 at the spare part shop that most of us know situated at
seapark.
+Quote Post
armanio
post Dec 10 2003, 11:20 AM
Post #8
Group: Members
Stupe,
Thanks a lot man, spent a lot of time looking for it at the engine bay. I
think can DIY laa coz I have seen those guys changing it for my wira
before. Should be the same I think. Thanks a lot guys for you help !
+Quote Post
stupe
post Dec 10 2003, 01:00 PM
Post #9
Group: Members
no worries.
as long as it is carb, ther eis no issue of the fuel filter having high
pressure, thus setting the fuel in streams of fuels.
Petrol loss is minimal, but do take care for naked flames around teh
working area.
injection car fuel system are normally pressurised, hence, leave it to the
mech, they know what to do better.
+Quote Post
armanio
post Dec 10 2003, 02:05 PM
Post #10
Group: Members
The injection car fuel sytem also isn't much complicated laa. My wira,
fuel injection, they changed it quite easy. The rule is that you need to
open the petrol tank cap to release the pressure before replacing the fuel
filter.
The fuel filter for fuel injection car is made of steel compared to the
carb engines which is a plastic make.
PS -> Why waste money for the service / labour when it can be replaced by
yourself within minutes (provided you can find it) ^
+Quote Post
2 Pages V   1 2 >
RSS Lo-Fi Version  |  Powered By IP.Board © 2008  IPS, Inc Time is now: 28th February 2015 - 09:56 AM
