Autoworld
Autoworld.com.my
2 Pages V   1 2 >
> kancil 850 m
ManU
post Aug 24 2008, 08:12 PM
Post #1
Group: Members
hi, my kancil 850 M now clocked 61+++ km ... i dun know whats the reason
now it become quite high FC, this happened since last year sept service
outside ... i only changed mineral oi n oil filter that time ... then
last may, i changed denso spark plug, air filter, shell mineral oil, oil
filter .. i tot can improve .. but then also the same till now .. now i
only get aroung 13km/l ... last time i used to get around 16km/l ... what
could be the reason ? i dun know what need to change on my coming
service .. almost due .. is it some parts of engine need to be tuned ? or
any other reason ??? .... what;s gasket ? i never changed gasket and fuel
filter for quite long, is it the reason?
Go to the top of the page
+Quote Post
magicity
post Aug 26 2008, 12:10 AM
Post #2
Group: Members
Im facing the same problem as well, the FC really make me mad, a small car
with small cc but the FC like big car... nowday even the big car have
saver FC than my kancil though... hope some1 can give some oppinion or
solution...
+Quote Post
kilogram
post Aug 26 2008, 10:37 AM
Post #3
Group: Members
gotta be realistic. no way an older car can still perform and give you FC
like on its first year. Worn Parts, carbon build ups, driving habit,
inefficient fuel and air combustion etc...all these add up.
So even if you changed all the necessary parts without overhauling,your
pistons, valves, valve seals, conrods etc...are also no more in pristine
condition like in its 1st year.
You can try your best to improve it, but there's a limit.
+Quote Post
ManU
post Aug 27 2008, 06:29 PM
Post #4
Group: Members
kilogram
but this car has only clocked 61+++ km, and 3 years plus only .. how come
the FC can be affected within such a short period? if u said those car
more than 5 , 7 years, FC getting worse, then i may understand ....
hmm ... hope someone can know wat to do ?
+Quote Post
kilogram
post Aug 27 2008, 08:16 PM
Post #5
Group: Members
3 years ago, are your working in the same place? Do you travel the same
route with the same traffic condition? If you have changed job and travel
to a different route and traffic condition is bad,then you got the answer
d.
+Quote Post
ltcw
post Aug 28 2008, 04:42 PM
Post #6
Group: Members
I am driving a kancil 850ex manual 1999 until now, fuel consumption around
14-15km/ltr. This is driving soft and hard. No problems.
Perhaps you could check for any leak in the fuel system. it may not be
serious but try to smell whether there is any fuel smell in the engine bay
and fuel inlet bay. could be due to leakage at the fuel pump diaframg or
others. Also check your idle rpm with air cond on and off, check whether
it is still within the spec as per manual.
+Quote Post
shiv1228
post Sep 17 2008, 08:53 PM
Post #7
Group: Members
Hi... I'm driving Kancil 850 EZ Auto 2001 & it gives me almost 13-15
km/liter which I think is reasonable with an auto car. I get the max when
driving with optimum speed without much acceleration where as the min is
fast driving... acceleration & city.
+Quote Post
LordGuyver
post Oct 6 2008, 05:00 PM
Post #8
Group: Members
Rather than spending lots of rm....try to survey on mira s engine...
+Quote Post
MyProps
post Oct 10 2008, 03:04 PM
Post #9
Group: Members
Hi ManU
i think it is normal...
must consider
i) Fuel price
ii) tyre wear n tear
iii) traffic condition
iv) driving behavior
v) etc
never change the gasket n fuel filter is not the reason why your kancil
get high FC. but fuel filter need to be change after 60K km. check with
your manual or SC.
+Quote Post
jawerians
post Oct 16 2008, 11:57 AM
Post #10
Group: Members
from my experience castrol 10w-30 will give you better fc than shell 10w-
30.
+Quote Post
2 Pages V   1 2 >
RSS Lo-Fi Version  |  Powered By IP.Board © 2008  IPS, Inc Time is now: 1st February 2015 - 03:06 PM
