Fog light for Perodua Kelisa
BridgestoneRE711
Posted 16 August 2003 - 01:30 PM
BridgestoneRE711
    Hot Rod
  • PipPipPipPip
  • 12,174 posts
this came out in my mind yesterday after my neighbour bought and got his
kelisa yesterday . i just realised that the signal light is at the bumper
and the low beam is beside the headlamp .
how about changing the wiring and the bulb of the signal light to the low
beam area , later , connect the low beam to the signal light compartment
and change the fuse/bulb of the fuse to higher voltage one .
is this ok ? just my RM0.02.
stupe
Posted 16 August 2003 - 01:36 PM
stupe
  • 5,434 posts
good idea.
but then, the 5w light won't be enough to light up the road but more of
an aesthetic purposes only , isn't it?
i think it is possible as both the side light and the signal light shares
the same wattage. 5 w. or was it 5 for side light and 15 for signal?
BridgestoneRE711
Posted 17 August 2003 - 01:02 AM
BridgestoneRE711
    Hot Rod
  • PipPipPipPip
  • 12,174 posts
anyone dare to try ?
bfs621
Posted 18 August 2003 - 12:33 PM
bfs621
  • 488 posts
i did tried the setup with 2 wires it works perfectly Big Smile saw few kancil
old model doing the same trik
stupe
Posted 19 August 2003 - 04:04 PM
stupe
  • 5,434 posts
hmm...
now i hand itchy, somemore the 2000 facelift 2 kancil's signal light is
clear type....
sherwin
Posted 19 August 2003 - 05:20 PM
sherwin
  • 1,015 posts
just spotted a Kelisa with the above setup you mentioned..
the low beam side lamps or clearance lamps were changed to signals while
the lower signals changed to low beam lights
the owner of that car had loads of blue lights around, including one in
the engine bay so from the front view, there is a glow through the front
grill..
sportivo
Posted 21 August 2003 - 06:05 PM
sportivo
  • 41 posts
Kelisa....not only front fog light....
rear also can install a fog lamp without adding the new component!
