Autoworld
Autoworld.com.my
> Fog light for Perodua Kelisa
BridgestoneRE711
post Aug 16 2003, 01:30 PM
Post #1
Hot Rod
Group: Members
this came out in my mind yesterday after my neighbour bought and got his
kelisa yesterday . i just realised that the signal light is at the bumper
and the low beam is beside the headlamp .
how about changing the wiring and the bulb of the signal light to the low
beam area , later , connect the low beam to the signal light compartment
and change the fuse/bulb of the fuse to higher voltage one .
is this ok ? just my RM0.02.
Go to the top of the page
+Quote Post
stupe
post Aug 16 2003, 01:36 PM
Post #2
Group: Members
good idea.
but then, the 5w light won't be enough to light up the road but more of
an aesthetic purposes only , isn't it?
i think it is possible as both the side light and the signal light shares
the same wattage. 5 w. or was it 5 for side light and 15 for signal?
+Quote Post
BridgestoneRE711
post Aug 17 2003, 01:02 AM
Post #3
Hot Rod
Group: Members
anyone dare to try ?
+Quote Post
bfs621
post Aug 18 2003, 12:33 PM
Post #4
Group: Members
i did tried the setup with 2 wires it works perfectly Big Smile saw few kancil
old model doing the same trik
+Quote Post
stupe
post Aug 19 2003, 04:04 PM
Post #5
Group: Members
hmm...
now i hand itchy, somemore the 2000 facelift 2 kancil's signal light is
clear type....
+Quote Post
sherwin
post Aug 19 2003, 05:20 PM
Post #6
Group: Members
just spotted a Kelisa with the above setup you mentioned..
the low beam side lamps or clearance lamps were changed to signals while
the lower signals changed to low beam lights
the owner of that car had loads of blue lights around, including one in
the engine bay so from the front view, there is a glow through the front
grill..
+Quote Post
sportivo
post Aug 21 2003, 06:05 PM
Post #7
Driver
Group: Members
Kelisa....not only front fog light....
rear also can install a fog lamp without adding the new component!
+Quote Post
RSS Lo-Fi Version  |  Powered By IP.Board © 2008  IPS, Inc Time is now: 31st January 2015 - 04:31 PM
