| Autoworld.com.my |
Mar 19 2008, 09:31 PM
Post
Veteran ![]() ![]() Group: Banned Posts: 168 Joined: 11-April 07 Member No.: 65,149 |
Hi all,
Offering the following NEW items when u service ur Perdana V6. Timing Belt Kit Set Dayco(USA)rm300, local MMC rm220, Gates- out of stock Air-con belt rm20, Fan belt rm24 Bosch Double Platinum Spark Plugs for V6 rm32 per piece. Mkt price rm45+/- Plugs long-lasting will go up to 100,000km no problem Perdana V6 Pro-Rallye plug wire From USA& together with grounding cable already. rm220. Plug wire is 10mm. Good performance Perdana Black Based Cyrstal Headlamp rm480 for a pair. Perdana V6 ATF filter & gasket-rm87 Original Proton Mitsubishi ATF oil SP111-rm25 per litre ---For this item, better uses back original and not cheap product cos it is ur gearbox we talking about. Expensive to replace. Perdana V6 water pump rm105 Bosch Perdana Wiperblades-rm27 Bosch Perdana Brake Pads front rm41, rear rm45 Absorbers front rm80per side (oil), back rm80 (gas)per side. outside selling rm100++ Proton ATF oil rm19 per bottle (use 4 bottles) Local Perdana Air Filter-rm13 Bosch Alternator for V6-rm195 Front wheel bearing-rm122 per side made Japan Rear wheel bearing-rm145 per side made Japan Lower arm- go see ur mechanic first Driveshaft head rm195 per side Perdana outer door handle front-rm160 Original Proton per side Buy any of the above from me, sell u the following at Hella twin-tone Horn rm39 per box( with relay) Bosch twin-tone horn rm35(without relay) Osram H4 60/55w rm9 each Osram Cool Blue 60/55W rm49 a pair Bardahl oil treatment,1 can- rm12 Ate Brake Fluid DOT 350ml -rm12 Castrol TQ-D 4L-rm40 Bosch Dot4 Brake Fluid 1 litre-rm19 Other parts will be updated time to time Please contact: 012-2908159 Location:KL/PJ Discounts available |
Apr 30 2008, 04:35 PM
Post
4th Gear Group: Members Posts: 4 Joined: 30-April 08 Member No.: 72,880 |
hi airline05, how about body parts...
May 6 2008, 06:40 AM
Post
what kind of body parts friend?
Lo-Fi Version | Powered By IP.Board © 2008 IPS, Inc | Time is now: 23rd May 2013 - 04:21 AM |
