| Autoworld.com.my |
Sep 25 2008, 09:49 AM
Post
Member ![]() Group: Members Posts: 11 Joined: 30-May 06 Member No.: 58,924 |
i owned kia spectra novus 2005. There is no pick up whenever going uphill
especially in karak highway or overtaking, the pick is very slow. kancil and buses are faster than my car. even with the OD off, there is no difference. i don't feel the foward jerk whenever OD is off. Its like the car refuse to accelarate even when I have pressed the pedal till the end. anyone has any idea what is wrong with the car? |
Sep 26 2008, 12:43 PM
Post
Heart Like a Wheel ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 23,878 Joined: 25-November 02 From: Johor Bahru Member No.: 23,852 |
Kia Spectra was never a powerful car in the 1st place. Its being like
that since day 1 of owning the car or just recently it behave like that? |
Sep 30 2008, 10:44 AM
Post
![]() Tokyo Drifter ![]() ![]() ![]() Group: Members Posts: 2,685 Joined: 8-August 07 Member No.: 67,618 |
my experience working with NazaKia workshop can be of 2 things
1. spark plug cable (very common problem) 2. exhaust pipe leak at centre saloon (weld back at RM20-30.). other than that, normally Kia Spectra has good performance and reliability. |
Oct 14 2008, 08:56 AM
Post
Probation ![]() Group: Members Posts: 24 Joined: 14-October 08 Member No.: 75,918 |
spectra 06 aku pun rasa macam tu juga...tapi bila dah remove cat-
con...install bullet...terasa ringan&pick-up.....kau cuba lah... |
Nov 5 2008, 05:58 PM
Post
Fast & Furious ![]() ![]() ![]() Group: Members Posts: 1,574 Joined: 13-November 07 From: Cheras Member No.: 69,564 |
yeah it's true, just double check what alldisc has mentioned and get
NAZAKIA to remove the cat-converter.. I experienced drove in LPT Karak hiway during rainy times. After hit the water, got funny sound..I din press the accelerator and let the car stops by itself.. For me this car not fun to drive if you expect good performance. It's better you get waja. No offence, I owned a 2004 before and finally let go with RM19K lost and I happy with my toyota.. |
Nov 10 2008, 11:34 PM
Post
Tokyo Drifter ![]() ![]() ![]() Group: Members Posts: 3,262 Joined: 8-May 02 Member No.: 20,224 |
I agree with the observation by alldisc & wanida.
The size & location of the cat con of the Spectra seems to be a problem, and if it is splashed by rain or puddles after a long drive, it can actually constrict the exhaust flow causing loud noise, vibration and loss of power. As for your 2005 model, the cat con would probably also be clogged with soot. Normal replacement of cat con is 2 years use but here in bole-land, it is usually replaced with a stright flow bullet due to costs etc. Another thing that is worth looking into is a lightened pulley, fitted with damper would be a better bet although the original pulley is just a solid cast steel one. But don't forget that the weight of the spectra is on the high side to start with. But it was most likely designed to face the numerous threats to bole-land drivers from suicidial motorbikers/mat rempits & could-not-care-less hantu lorry drivers. |
Nov 11 2008, 12:56 PM
Post
6th Gear Group: Members Posts: 6 Joined: 7-November 07 Member No.: 69,439 |
can anybody explain to me what is the cat-con is...?? :) and also the
ORIGINAL function of this parts |
Nov 11 2008, 09:36 PM
Post
cat con = catalytic converter. The function is to act as catalyst to
promote the chemical reaction of the components in the exhaust gas to reduce harmful gases being released by the vehicle. This process requires the catalyst element within the cat con to be heated up to very high temp for the chemical reaction to occur. |
Nov 12 2008, 05:05 PM
Post
4th Gear Group: Members Posts: 4 Joined: 11-April 07 Member No.: 65,137 |
yeah.....if i byk duit like u, i will put it in ASB lor......luckily i
not byk duit......so keep this car la....... |
Nov 18 2008, 04:41 PM
Post
its been like that since I bought the car. I have changed the cat con to
bullet as well. there is no change in the performance. and yeah, i got the knocking sound as well whenever water splash on the bullet. |
Lo-Fi Version | Powered By IP.Board © 2008 IPS, Inc | Time is now: 19th June 2013 - 08:32 PM |
