Autoworld
Autoworld.com.my
> Temperature problem
sazizam
post Jun 21 2004, 01:50 AM
Post #1
Group: Members
honda users,
i hav a problem here with my temperature.
whenever i drive my car with the aircond is on while i'm speeding(90-
100++kmph) i found that the temperature level indicator will increase
nearly to H line.when this happened i always switch off the aircond until
the level go down to a safer level.i dont know whether the problem arise
because of the radiator are not functioning well or etc.how to check aaa
whether the radiator "tersumbat" or not?
or is it because of the wiring?
hmmm...pls help me with this.
thank you.
Go to the top of the page
+Quote Post
eg8
post Jun 21 2004, 10:38 PM
Post #2
Group: Members
sazizam
try check
radiator ada leaking tak
hos hos ke radiator ada bocor tak
water pump ko bila last sekali tukar
kipas aircond dan kipas radiator ko ada jalan tak
could be problem on ur termostat too
best thing is, send to ur trusted mechanic
+Quote Post
sazizam
post Jun 22 2004, 12:38 AM
Post #3
Group: Members
eg8,
tq pasal reply thread aku nih.
radiator rasanya tade leaking.
hos2 ke radiator pon rasanya ok lagi.
tapi water pump tu taktau la pulak.huhuhhu...
camne nak tau water pump aku dah kong yer?
kipas2 tu suma jalan.
termostat lak aku tatau mana satu.boleh jadik gak pasal termostat
tuh.camne nak tau rupa bentuk termostat tu yer eg8?
citer sikit.
+Quote Post
kekura
post Jun 22 2004, 12:32 PM
Post #4
Group: Members
Based on the syntoms dat u stated, most likely yor porb. is with the
choked radiator, dats Y yor water level remain the same. Due to poor
coolant circulation ( choked radiator ), the heat transfer is inefficient
thus up'ed yor coolant temp. Try servicing yor radiator 1st, cost U oni
around RM70. No harm trying what ?
+Quote Post
johanbrian
post Jun 27 2004, 04:48 PM
Post #5
Group: Members
DIY la. Beli radiator flush and flush sendiri.
Kalau nak tau water pump bocor ke tak, letak tray kat bawah kereta belah
kiri overnight. Kalau next morning ada air takung kat dalam maknanya pump
bocor la. But if water level tak turun, that means no leak. No leak means
radiator needs flushing.
Check warna air dalam radiator. Kalau karat, then kena flush. Best thing
is use mineral water to top up radiator instead of tap water.
+Quote Post
nickgomez
post Jun 28 2004, 10:04 PM
Post #6
Group: Members
Your water pump might be long overdue for a change too.
+Quote Post
zerocool78
post Jun 30 2004, 10:05 AM
Post #7
Group: Members
hi,
masa kete kau slow dan pasang aircond ok je ke..??? kalu ok.... mungkin
kipas kau tu pusing terbalik kot... mungkin laa... pasal aku penah kena
kalu kipas nie pusing terbalik... temp. akan naik.. tapi tak tau sure lak
kipas mana.. Question
+Quote Post
RSS Lo-Fi Version  |  Powered By IP.Board © 2008  IPS, Inc Time is now: 4th March 2015 - 08:42 PM
