Proton Service Center Recommendation
Posted 04 November 2014 - 04:39 PM
Kindly recommend any good and efficient Proton SC around Selangor or KL if there aren't any in Selangor . I'm going for major service soon. I have bad experience with few Proton SC , working speed is dam #$%^&* slow.
Kindly help me out . thankssssssssssssssssssssss
Posted 05 November 2014 - 07:39 AM
I don't know about you, but have tried to Honda SC, Proton, even Chery, all the same. Many trainees, faults and complaints not done, however they are good at changing oil and filters only.....
Posted 06 November 2014 - 09:02 PM
Every service come with time... Don't rush... Technically a lube job can be done in ten minutes... But with all the inspection take place, it should take more than 30 minutes...or 60 mins lah...
Posted 06 November 2014 - 10:10 PM
-Do Not Let Them Puor X-1R Or Any Additive To Your Engine-
it will kill your turbine.
Posted 09 November 2014 - 10:03 AM
A normal service normally took me at least 4 hours, even tho ur appointment is at 8am, but your car wil be driven in to their workshop at a later time, say after 1 hour or more. @_@....
Posted 09 November 2014 - 10:05 AM
Yes mine is cfe engine, hmm isn't that SC should be more knowledgeable than customer?
Posted 09 November 2014 - 01:50 PM
SC hard sell the X1-R mah!.....
Posted 10 November 2014 - 07:24 PM
OK thanks for the info. So what is the recommended products?
Posted 10 November 2014 - 10:24 PM
Never let them add any engine oil additive.
just use engine oil alone.
Posted 11 November 2014 - 08:17 AM
Most SC won't allow you to use your preferred oil bought from outside. If that is the case, just use their oil, and like bro. gunnerzz mention without their additives....
