Gen2 Steering Rack Noses
markrenesh
Posted 31 October 2014 - 08:34 PM
markrenesh
    3rd Gear
  • 3 posts
Hi i need a little help on this issue...I've been trying everyday to detect a certain knocking noise under front and more to the right of my 05 high line gen2. Changed calliper pins engine mount,absorber link and i still here knocking noise on uneven roads.
Found out the,rod to the steering rack is noisy..can that be the problem?
No steering freeplay, no wobbling.can i change any bush to make this better.
Fed up!
The other issue is the gear downshift downhill
..is there anyway proton can adjust this?
Posted 01 November 2014 - 09:08 AM
  • 71,466 posts
QUOTE (markrenesh @ Oct 31 2014, 08:34 PM) <{POST_SNAPBACK}>
Fed up!
This is noise from mechanical problem, not for sound proofing thread. Will shift you to Proton thread also... smile_tongue.gif
mosh
Posted 03 November 2014 - 01:15 PM
mosh
  • 3,557 posts
Fed up!
have you changed your steering rack bush ? 2005 - 2014 is a very long years of wear and tear.
go google and search for gen2 steering rack bush. silicon bush is great.
what is the problem with downshift ? you driving an auto ?
you prefer going downhill with the final gear izzit ? rather than the lower gear to reduce speed ? ( engine braking )
