Tyre Wear
Posted 07 September 2014 - 06:27 PM
It looks kinda strange that the rear tyres got all the "scratches" on the outside.
Something is not right?
Posted 08 September 2014 - 08:38 AM
Both tyres, left and right side? Any scrubbing on the wheel arch fender?
How is the tyre wear on the pattern?
Posted 08 September 2014 - 12:23 PM
Yup, both side. It is original size, no scrubbing wor...
The wear at the pattern is normal, no scratches like on the side.
Only happened to the rear, front ok...
Possible due to the chamber adjustment?
Coz I did chamber adjustment in last wheel alignment...
Posted 08 September 2014 - 06:44 PM
either wrong alignment done or improper air pressure
Posted 08 September 2014 - 10:51 PM
If camber out the pattern wear on the shoulder pattern will be uneven. If alignment out pattern wear will also be like being shave off.
Another question, did you do on wheel balancing for the rear tyres? or were they rotated from the front?
Posted 08 September 2014 - 10:52 PM
If improper air pressure then the inside should have wear too.
Looks more like hard cornering or did on wheel balancing...
Posted 09 September 2014 - 06:28 PM
wrong see..i think he mention 2 side is inner & outer
than should be alignment
Posted 10 September 2014 - 08:09 AM
But usually alignment wears the pattern, this one is edge of sidewall?
Posted 10 September 2014 - 10:55 PM
ia am guessing the car is a hatch and he frequently carry passenger in the rear?
Posted 10 September 2014 - 11:27 PM
I guess it could be my negligence and more aggressive driving recenly.
Wanna quickly use up the tyre and change before GST
