Falken Ziex 950
w1n
, Jun 28 2014 02:33 AM, 34 replies to this topic
Posted 28 June 2014 - 02:33 AM
Any idea when is coming and pricing?
Good tread-wear, claimed 60% better...rate from 500-600. Which is good.
Falken Ziex 950
500-A-A Load / Item # Meas. Approved OD Section RPM Tread Tread Weight Max PSI Max Sidewall Extra
Size Speed Rim Rims Width Width Depth (lbs) (Cold) Load Load
205/65R15 99W 28953544 6.0 5.5 - 7.5 25.5 8.2 832 6.5 10 22.1 50 1709 BLK XL
205/55R16 94W 28953483 6.5 5.5 - 7.5 24.9 8.4 845 7.1 10 22.7 50 1477 BLK XL
235/60R16 100W 28953655 7.0 6.5 - 8.5 27.1 8.5 783 7.7 10 28.9 51 1764 BLK -
205/40R17 84W 28953740 7.5 7.0 - 8.0 23.5 8.3 886 7.2 10 19.0 50 1102 BLK XL
205/45R17 88W 28953781 7.0 6.5 - 7.5 24.3 8.1 856 7.1 10 21.2 50 1235 BLK XL
205/50R17 93W 28953770 6.5 5.5 - 7.5 25.1 8.4 837 7.3 10 22.5 50 1433 BLK XL
215/45R17 91W 28953792 7.0 7.0 - 8.0 24.6 8.0 842 7.4 10 21.6 50 1356 BLK XL
215/50R17 91W 28953771 7.0 6.0 - 7.5 25.5 8.9 823 7.7 10 23.2 51 1356 BLK -
215/55R17 94W 28953727 7.0 6.0 - 7.5 26.3 8.9 800 7.4 10 23.6 51 1477 BLK -
225/45R17 94W 28953795 7.5 7.0 - 8.5 25 8.9 834 7.8 10 22.5 50 1477 BLK XL
225/50R17 94W 28953772 7.0 6.0 - 8.0 25.9 9.2 811 8.0 10 24.0 51 1477 BLK -
225/55R17 101W 28953762 7.0 6.0 - 8.0 26.8 9.2 788 7.8 10 26.7 50 1819 BLK XL
235/45R17 94W 28953794 7.5 7.5 - 9.0 25.4 9.3 821 9.1 10 23.8 51 1477 BLK -
235/50R17 96W 28953773 7.5 6.5 - 8.5 26.3 9.6 800 8.4 10 25.6 51 1565 BLK -
235/55R17 99W 28953725 7.5 6.5 - 8.5 27.2 9.6 778 8.1 10 26.7 51 1709 BLK -
245/40R17 95W 28953785 8.5 8.0 - 9.5 24.7 9.8 842 8.7 10 23.8 50 1521 BLK XL
245/45R17 99W 28953784 8.0 7.5 - 9.0 25.7 9.6 813 8.5 10 25.6 50 1709 BLK XL
245/50R17 99W 28953776 7.5 7.0 - 8.5 26.7 10.0 790 8.7 10 28.0 51 1709 BLK -
255/40R17 94W 28953796 9.0 8.5 - 10 25.0 10.2 832 9.0 10 25.1 51 1477 BLK -
215/35R18 84W 28953882 7.5 7.0 - 8.5 23.9 8.6 862 7.7 10 20.5 50 1102 BLK XL
215/40R18 89W 28953891 7.5 7.0 - 8.5 24.8 8.6 837 7.6 10 21.2 50 1279 BLK XL
215/45R18 93W 28953899 7.0 7.0 - 8.0 25.6 8.4 811 7.4 10 22.7 50 1433 BLK XL
225/40R18 92W 28953892 8.0 7.5 - 9.0 25.1 9.1 826 8.0 10 22.3 50 1389 BLK XL
225/45R18 95W 28953824 7.5 7.0 - 8.5 25.9 8.9 803 7.8 10 23.8 50 1521 BLK XL
225/50R15 95W 28953805 7.0 6.0 - 8.0 26.9 9.2 781 8.0 10 26.0 51 1521 BLK -
235/40R18 95W 28953893 8.5 8.0 - 9.5 25.4 9.5 818 8.3 10 23.2 50 1521 BLK XL
235/45R18 94W 28953895 8.0 7.5 - 9.0 26.3 9.3 790 8.1 10 24.7 51 1477 BLK -
235/50R18 101W 28953825 7.5 6.5 - 8.5 27.3 9.6 771 8.4 10 29.8 50 1819 BLK XL
245/40R18 97W 28953894 8.5 8.0 - 9.5 25.7 9.8 808 8.7 10 25.1 50 1609 BLK XL
245/45R18 100W 28953865 8.0 7.5 - 9.0 26.7 9.6 783 8.5 10 26.2 50 1764 BLK XL
245/55R18 103W 28953863 7.5 7.0 - 8.5 28.6 10.0 738 8.5 10 31.5 51 1929 BLK -
255/40R18 99W 28953844 9.0 8.5 - 10.0 26.0 10.2 800 9.0 10 27.8 50 1709 BLK XL
255/45R18 103W 28953866 8.5 8.0 - 9.5 27.0 10.0 771 8.9 10 28.0 50 1929 BLK XL
255/55R18 109W 28953845 8.0 7.0 - 9.0 29.0 10.4 727 8.8 10 33.3 50 2271 BLK XL
265/35R18 97W 28953806 9.5 9.0 - 10.5 25.3 10.7 821 9.5 10 25.8 50 1609 BLK XL
275/35R18 99W 28953807 9.5 9.0 - 11.0 25.6 10.9 816 9.9 10 26.9 50 1709 BLK XL
225/40R19 93W 28953971 8.0 7.5 - 9.0 26.1 9.1 793 8.0 10 23.6 50 1433 BLK XL
225/55R19 99W 28953955 7.0 6.0 - 8.0 28.8 9.2 730 7.8 10 27.6 51 1709 BLK -
235/55R19 105W 28953970 7.5 6.5 - 8.5 29.2 9.6 721 8.1 10 31.1 50 2039 BLK XL
245/40R19 94W 28953974 8.5 8.0 - 9.5 26.7 9.8 776 8.7 10 26.0 51 1477 BLK -
245/45R19 98W 28953904 8.0 7.0 - 9.5 27.7 9.6 753 8.5 10 27.1 51 1653 BLK -
255/35R19 96W 28953973 9.0 8.5 - 10.0 26.0 10.2 798 9.2 10 24.7 50 1565 BLK XL
255/40R19 100W 28953996 9.0 8.5 - 10 27 10.2 769 9.0 10 28.0 50 1764 BLK XL
275/40R19 101W 28953903 9.5 9.0 - 11.0 27.7 10.9 753 9.7 10 30.2 51 1819 BLK -
245/40R20 99W 28953002 8.5 8.0 - 9.5 27.7 9.8 749 8.7 10 28.0 50 1709 BLK XL
245/45R20 103W 28953023 8.0 7.5 - 9.0 28.7 9.6 725 8.5 10 28.9 50 1929 BLK XL
255/35R20 97W 28953001 9.0 8.5 - 10.0 27.0 10.2 767 9.2 10 27.1 50 1606 BLK XL
255/45R20 105W 28953013 8.5 8.0 - 9.5 29.1 10.0 717 8.9 10 29.5 50 2039 BLK XL
275/35R20 102W 28953005 9.5 9.0 - 11.0 27.6 10.9 753 9.9 10 29.1 50 1874 BLK XL
275/40R20 106W 28953947 9.5 9.0 - 11.0 28.7 10.9 725 9.7 10 31.3 50 2094 BLK XL
600-A-A Load / Item # Meas. Approved OD Section RPM Tread Tread Weight Max PSI Max Sidewall Extra
175/65R15 84H 28951563 5.0 5.0 - 6.0 24.0 7.0 880 5.6 10 17.2 51 1102 BLK -
185/65R15 88H 28951542 5.5 5.0 - 6.5 24.4 7.4 865 5.9 10 18.3 51 1235 BLK -
195/50R15 82H 28951571 6.0 5.5 - 7.0 22.8 7.9 925 7.0 10 17.6 51 1047 BLK -
195/55R15 85V 28952561 6.0 5.5 - 7.0 23.4 7.9 898 6.7 10 19.2 51 1135 BLK -
195/60R15 88H 28951551 6.0 5.5 - 7.0 24.3 7.9 871 6.4 10 19.6 51 1235 BLK -
195/65R15 91H 28951543 6.0 5.5 - 7.0 25.0 7.9 848 6.2 10 19.6 51 1356 BLK -
205/60R15 91H 28951552 6.0 5.5 - 7.5 24.7 8.2 856 6.7 10 20.1 51 1356 BLK -
215/60R15 94H 28951553 6.5 6.0 - 7.5 25.2 8.7 840 7.0 10 22.5 51 1477 BLK -
215/65R15 96H 28951545 6.5 6.0 - 7.5 26.0 8.7 816 6.9 10 22.3 51 1565 BLK -
185/55R16 83H 28951677 6.0 5.0 - 6.5 24.0 7.6 874 6.4 10 19.2 51 1074 BLK -
195/50R16 84V 28952660 6.0 5.5 - 7.0 23.7 7.9 883 7.0 10 19.2 51 1102 BLK -
195/55R16 87V 28952615 6.0 5.5 - 7.0 24.4 7.9 862 6.7 10 19.6 51 1201 BLK -
205/45R16 87V 28952690 7.0 6.5 - 7.5 23.3 8.1 895 7.1 10 20.3 50 1201 BLK XL
205/50R16 87V 28952671 6.5 5.5 - 7.5 24.1 8.4 871 7.3 10 20.5 51 1201 BLK -
205/60R16 92V 28952652 6.0 5.5 - 7.5 25.7 8.2 821 6.7 10 21.6 51 1389 BLK -
205/65R16 95V 28952626 6.0 5.5 - 7.5 26.5 8.2 800 6.5 10 22.3 51 1521 BLK -
215/55R16 97V 28952662 7.0 6.0 - 7.5 25.3 8.9 834 7.4 10 23.8 50 1609 BLK XL
215/60R16 95H 28951479 6.5 6.0 - 7.5 26.2 8.7 808 7.0 11 24.3 51 1521 BLK -
215/65R16 98H 28951681 6.5 6.0 - 7.5 27.0 8.7 786 6.9 10 23.4 51 1653 BLK -
225/50R16 96V 28952672 7.0 6.0 - 8.0 24.9 9.2 845 8.0 10 24.5 50 1565 BLK -
225/55R16 95V 28952670 7.0 6.0 - 8.0 25.7 9.2 821 7.8 10 23.8 51 1521 BLK -
225/60R16 98V 28952480 6.5 6.0 - 8.0 26.7 9.0 795 7.3 10 25.8 51 1653 BLK -
225/65R16 100H 28951673 6.5 6.0 - 8.0 27.5 9.0 771 7.2 10 26.7 51 1764 BLK -
235/65R16 103H 28951629 7.0 6.5 - 8.5 28.0 9.4 760 7.5 10 26.7 51 1929 BLK -
245/50R16 97H 28951674 7.5 7.0 - 8.5 25.7 10.0 821 8.7 10 25.6 51 1609 BLK -
215/60R17 96H 28951729 6.5 6.0 - 7.5 27.2 8.7 776 7.0 10 25.1 51 1565 BLK -
215/65R17 99H 28951782 6.5 6.0 - 7.5 28.0 8.7 755 6.9 10 25.6 51 1709 BLK -
225/60R17 99V 28952728 6.5 6.0 - 8.0 27.7 9.0 764 7.3 10 26.2 51 1709 BLK -
225/65R17 102H 28951775 6.5 6.0 - 8.0 28.5 9.0 742 7.2 10 28.2 51 1874 BLK -
235/60R17 102H 28951717 7.0 6.5 - 8.5 28.5 9.4 751 7.7 10 30.9 51 1874 BLK -
235/65R17 108V 28952790 7.0 6.5 - 8.5 29.1 9.4 732 7.5 10 31.5 50 2205 BLK XL
215/55R18 95H 28951900 7.0 6.0 - 7.5 27.3 8.9 771 7.4 10 23.8 51 1521 BLK -
225/55R18 98V 28952889 7.0 6.0 - 8.0 27.8 9.2 758 7.8 10 27.1 51 1653 BLK -
225/60R18 100V 28952826 6.5 6.0 - 8.0 28.7 9.0 738 7.3 10 27.6 51 1764 BLK -
235/55R18 104V 28952817 7.5 6.5 - 8.5 28.1 9.6 749 8.1 10 30.6 50 1984 BLK XL
235/60R18 107V 28952816 7.0 6.5 - 8.5 29.1 9.4 725 7.7 10 34.0 50 2149 BLK XL
235/65R18 106H 28951815 7.0 6.5 - 8.5 30.0 9.4 705 7.5 10 33.5 51 2094 BLK -
245/60R18 105H 28951811 7.0 7.0 - 8.5 29.6 9.8 713 8.0 10 34.0 51 2039 BLK -
255/65R18 111H 28951862 7.5 7.0 - 9.0 31.1 10.2 683 8.1 10 36.4 51 2403 BLK -
265/60R18 110V 28952854 8.0 7.5 - 9.5 30.6 10.7 694 8.7 10 37.3 51 2337 BLK -
245/55R19 103H 28951814 7.5 7.0 - 8.5 29.6 10.0 711 8.5 10 33.1 51 1929 BLK -
255/60R19 109H 28951813 7.5 7.0 - 9.0 31.1 10.2 681 8.3 10 35.7 51 2271 BLK -
245/50R20 102V 28952026 7.5 7.0 - 8.5 29.7 10.0 705 8.7 10 33.3 51 1874 BLK -
Falken Ziex 950
Posted 28 June 2014 - 09:36 AM
There is a ZE-914 also, that was suppose to be 912 replacement....
http://www.4wheelsne...nd-better-grip/
Oh! the older 912 are rated 360 but still wears very fast. Wonder how the 600 will fare?
Posted 29 June 2014 - 12:01 AM
I wonder if this would come..it seems we always get lower specs....I guess is marketing strategy. Why give better wear tires.
Hopefully it would...as I see it is really good. If priced like 912...will sell like hot cakes. Is AS and 500-600 Wow!...nice..but is A A.
QUOTE (vr2turbo @ Jun 28 2014, 09:36 AM) <{POST_SNAPBACK}>
Posted 29 June 2014 - 11:37 AM
QUOTE (w1n @ Jun 29 2014, 12:01 AM) <{POST_SNAPBACK}>
The ZE-912 was pretty good when launched and with AA traction rating. Later when rating was changed to A the quality went down....
Posted 01 July 2014 - 10:34 AM
this is All-Season tire.. so most likely won't make it to malaysia
unless they change the compound and rename the model.
Posted 01 July 2014 - 04:42 PM
QUOTE (irony @ Jul 1 2014, 10:34 AM) <{POST_SNAPBACK}>
But ZE-912 also called A/S tyre woh!
Hankook V2 concept 2 made it here and they too are A/S tyres....
Posted 02 July 2014 - 08:46 AM
Interesting thread pattern for an asymmetric design - two big central longkangs and two smaller outside longlangs. http://www.4wheelsne...nd-better-grip/
Regards,
Flee
Flee
Posted 03 July 2014 - 09:11 AM
QUOTE (flee @ Jul 2 2014, 08:46 AM) <{POST_SNAPBACK}>
Middle only one big longkang mah?
Usually for Asy pattern more rubber on outside, this one more rubber on inside.....
Posted 03 July 2014 - 02:48 PM
QUOTE (vr2turbo @ Jul 3 2014, 09:11 AM) <{POST_SNAPBACK}>
I was actually referring to the ZE-914.Usually for Asy pattern more rubber on outside, this one more rubber on inside.....
The ZE-950 looks more like a tyre for colder climates - it is like an "intermediate" tyre for damp conditions. Our monsoon weather needs bigger longkangs.
Regards,
Flee
Flee
