Shell Petrol
Posted 16 April 2014 - 11:43 AM
Posted 16 April 2014 - 05:34 PM
any change in driving style?
any change in tyre pressure?
any change in route to work?
any change in car servicing?
any change in petrol station?
any change in the number of passengers in car?
if the answer is "no" for all of the above, then maybe there is something wrong with the batch of fuel you pumped.
also, were you calculating it the same way before you notice the change?
what was your consumption before and after?
Posted 16 April 2014 - 06:51 PM
Posted 16 April 2014 - 10:16 PM
The super 4 can last to like 40,000km on a healthy engine.. probably you outrun it?
Posted 16 April 2014 - 11:56 PM
most likely outrun.. close to 80k km.. changed only after noticing higher than usual fuel consumption..
Posted 17 April 2014 - 09:53 AM
Now still on super 4 or the iridium fusion?
Posted 17 April 2014 - 08:51 PM
Still on the older super 4. Rm48 per set of 4 bought from ph auto..
Posted 18 April 2014 - 10:05 AM
Since the former set served you well already might as well carry on using....Iridium fusion is like RM160 up, I think....
Posted 22 April 2014 - 11:59 AM
now drop d bro..
rm120+- shouldn't be a problem but it is like really way too over mileage with the current super 4, 80,000km..
Posted 23 April 2014 - 08:01 AM
Oh! gone down? I used Denso Iridium before after that back to NGK Platinum, good enough. So much cheaper....
