Saga Flx(a) Engine Can't Start
reendaniel
Posted 07 October 2012 - 08:42 PM
reendaniel
  • 121 posts
hi friend. i'm using saga flx (a) for over 6 months. milleage closed to 16k km. nothing major problem happen.
but i experience 2 times engine can't start . 1st time early morning after heavy rain (during raya puasa), 2nd time its happen today (around 2pm). i start the engine , engine is running but got sound like "semput-semput". got yellow sign at odometer panel( at speed panel,). so i switch off the engine and retry again, engine running but still got sound 'semput-semput" & engine die off after a few second. i try a few time (more than 5 times) and after that engine run smoothly and yellow sign missing.
so u all got any idea what the problem?
thanks a lot.
Gunnerzz
Posted 07 October 2012 - 11:59 PM
Gunnerzz
  • 3,102 posts
QUOTE (reendaniel @ Oct 7 2012, 08:42 PM) <{POST_SNAPBACK}>
thanks a lot
Plug coil.
Service center can detect it as engine light lit up.
Quickly go to a service center.
7777g
Posted 08 January 2013 - 12:38 PM
7777g
  • 50 posts
thanks a lot.
no need check already, it is knock sensor......plug in computer ,u can see the error. To repair under proton....whole engine need to take out from chasis and open up the engine to change it.... my SC already finish done a PREVE. My flx also 3 times already.
gh466
Posted 28 October 2013 - 10:34 AM
gh466
i also have the same problem. cannot start the engine. i did force it to run many times with multiple try of ignition by battery jumping. but now i am tired. Please watch the video. Have any idea what is happening here?
ngom52
Posted 15 December 2013 - 01:49 PM
ngom52
I have also had the problem where the engine can't start, seems to happen around 1-2 times a week since the last 3 months.
Every time this happens, I open the front hood, kibas-kibas sikit and then the engine can start. I don't think it's caused by high engine temperature as it happens even when the engine is cold.
Has anyone found out the actual reason for this problem? What should I tell my mechanic to check for? Each time I go to service my car at proton SC, they told me to use the petrol treatment to prevent this problem but even after using it the problem still occurs.
Nabworld
Posted 15 December 2013 - 02:28 PM
Nabworld
  • 1,399 posts
i had that twice...it wil crank bt as if thrs no enough electrical charge to start...SC said thy tightened and reroute the starter wiring ...its bn ok since thn no problems....
kjlee
Posted 02 March 2014 - 11:11 PM
kjlee
my saga sv (6 months old) is giving same problem since 2 months ago. occassionally (about once a week), it will only start after a few cranks. however it will start after a few attempts (probable 5 mins). i took it to the Damansara Jaya (Petronas) last week and the technician reset the ecu. it has been 2 days, there has not been any starting problem. i read somewhere it could be a faulty sensor. anymore here could offer proton solution to the problem?
Taikoh
Posted 19 July 2014 - 10:07 PM
Taikoh
  • 2,107 posts
My nearly 3 year old FLX has happen twice.
After letting it cool down about 15 minutes it can start, frightening.
As usual, the service center just say they will check whether it is solved or not I don't know.
Taikoh
shahriz
Posted 29 November 2015 - 02:48 PM
shahriz
http://youtu.be/E-ip-pm2ITw
Hello...i have the same situation like yours...Saga Sv..did your problem solved yet? if yes can u share what the is the problem..i been tried to start my car for 2 days. it give me a strees day
Posted 29 November 2015 - 04:27 PM
  • 71,488 posts
Brother, this thread 2 years ago......
