Autoworld
Autoworld.com.my
2 Pages V   1 2 >
> Diy Throttle Body, clean your own Throttle Body
sepuli82
post Aug 14 2011, 12:38 PM
Post #1
Driver
Group: Members
Hi all,
Just wanna share my experience on cleaning waja throttle body. First, I managed to open the black air duct by loosen 1 screw (used no. 11 wrench). Then I twist the black air duct for easy access to the TB. OMG, it was soo dirty on the butterfly plate & sorrounding hole... no wonder my car RPM's goes crazy (RPM went too low & almost stalled)... Then I sprayed some WD40 (as it can remove oil) & wipe all the dirt clean... I notice that most of the dirt were fine particle of dust mixed with some oil.
Be sure to clean the black duct too & the opening of the TB along with the plate. I did not dare to mess the inner side of the TB affraid to touch the sensor inside.
Now the car RPM steady at 850... acceleration is better too. Feels happy again. Car is no more 'tersumbat'.
Let's share out thoughts together
Go to the top of the page
+Quote Post
kohf1drive
post Aug 14 2011, 01:57 PM
Post #2
Group: Members
QUOTE (sepuli82 @ Aug 14 2011, 12:38 PM) *
Hi all,
+Quote Post
turnip
post Aug 14 2011, 03:13 PM
Post #3
Group: Members
QUOTE (kohf1drive @ Aug 14 2011, 01:57 PM) *
as a human you must seek for the truth
Waja 1.8X
Engine : F4P 771 auto(same as Renault Laguna II)
Spark plug : Should be the default "Champion RFC 87YCL opening 0.9" but using some cheapo spark plugs now =_="
Fuel System : Sagem S2000
Torque (x / o.min) : 170Nm/3750
Top speed (km / h) : 198
0-100 km / h (sec) : 11
Air Filter : Stock(gonna change to K&N as recommended by brother Arazakmy)
+Quote Post
ntc2000
post Aug 14 2011, 03:33 PM
Post #4
Group: Members
Hi all,
try to use TB cleaner to clean it smile_thumbup.gif smile_thumbup.gif ..
ah koh, here is the steps.... saw a mech clean other people wajunk before, not too hard... very easy DIY.
http://www.popularmechanics.com/cars/how-to/repair/1272341
+Quote Post
sepuli82
post Aug 14 2011, 03:46 PM
Post #5
Driver
Group: Members
Pictures.... aiyaa... manyak soriii... my hands already dirty when i should've taken photo. But it's really easy to do, just get the black pipe loose, twist it & take it off, then see the inner side of the TB.... there you should see the butterfly plate all dirty... (after 4 years using the car).... one more thing, when clean the plate twist that black semi semi rounded thing beside the TB, you should get the plate to swivel & clean all sides... need little fingers to do this.
+Quote Post
sepuli82
post Aug 14 2011, 03:48 PM
Post #6
Driver
Group: Members
Ooo yes... remove the small air hoses to the engine first.... aiyaaa forgot oledi, this is the first step.
+Quote Post
sepuli82
post Aug 20 2011, 12:45 PM
Post #7
Driver
Group: Members
Here's some foto i've after i clean TB for 2nd time (gatal tangan)... First remove small air hose
Attached thumbnail(s)
+Quote Post
sepuli82
post Aug 20 2011, 12:46 PM
Post #8
Driver
Group: Members
& another pic to remove hose bracket, quoite tricky as it moves around.
+Quote Post
sepuli82
post Aug 20 2011, 12:48 PM
Post #9
Driver
Group: Members
The inner side of TB... (cheap camera phone quality... soryy maa)... still clean as i just cleaned it last week.
+Quote Post
sepuli82
post Aug 20 2011, 12:57 PM
Post #10
Driver
Group: Members
Open the air filter box & remove the hose... clean also the inner side of the hose... spray some WD40 onto the butterfly plate & sorroundings area.... wipe it with clean cloth... twist the black semi rounded thing to open the plate & clean the inner side... can use earbuds (to clean the two holes), berus gigi (to drag the dirt out) also... cannot upload foto somemore... already max size... haish!
+Quote Post
2 Pages V   1 2 >
RSS Lo-Fi Version  |  Powered By IP.Board © 2008  IPS, Inc Time is now: 1st February 2015 - 06:31 AM
