Autoworld
Autoworld.com.my
> My Naza Ria Engine Wanna To Convert To Cefiro Engine, Please advise me..........
danish09
post Aug 3 2011, 11:31 PM
Post #1
Group: Members
smile_angry.gif Raya just around the corner..............i planned to install new Naza engine but the costing look like same convert to Cefiro engine...what do you think?
Go to the top of the page
+Quote Post
byebye2u
post Aug 3 2011, 11:53 PM
Post #2
Group: Members
QUOTE (danish09 @ Aug 3 2011, 11:31 PM) *
so many cefiro spec, if 3.0 then will probably have enough hp and torque to pull heavy Naza Ria around unless if the mechanic know how to use the same naza gearbox...kasi kawin enjin dengan gearbox.
it is more easier if donor engine come from a car that has almost same weight.........gear ratio problem.
+Quote Post
ajoiauto
post Aug 8 2011, 11:51 AM
Post #3
Driver
Group: Members
hi danish09...
what happen to your old naza ria engine????
+Quote Post
APEK
post May 26 2012, 10:38 AM
Post #4
Group: Members
anyone here made the conversion?
i've converted my kia karnival engine with cefiro2.5 last year. timing chain. better fuel consumption. everything is perfect except for dryshaft issues. anyone face similar problem?
+Quote Post
4798
post Jun 20 2012, 01:23 AM
Post #5
Group: Members
done a lot of this convertion ..no problem at all. Depand the material you use for the driveshaft. plz feel free to call us 0122375631 : (under 3 garage) yr nazaria solution.
+Quote Post
jason81
post Jul 4 2012, 10:33 PM
Post #6
Group: Members
QUOTE (APEK @ May 26 2012, 10:38 AM) *
most converted ria will have the drive shaft problem , because the level is different , the engine is higher than the wheel , so the driveshift is "sengek" when rotating.. try cut the spring to lower the car ..this is what my friend said
but i saw some workshop claim they have a custom made driveshaft ..
+Quote Post
RSS Lo-Fi Version  |  Powered By IP.Board © 2008  IPS, Inc Time is now: 4th March 2015 - 10:48 AM
