masalah 'computer box' KELISA
comel76
Posted 13 May 2008 - 03:50 PM
comel76
    3rd Gear
  • 3 posts
hi
saya amat perlukan pendapat dari anda...
Sy memiliki perodua kelisa sejak 2002. Sejak tahun ini ada mengalami
masalah di mana aircondnya tetap berfungsi walaupun tidak "on" dan lampu
amaran untuk enjin menyala. P2 SC telah 'menasihatkan' saya untuk
menukarkan semua wire yang ada dengan menyatakan bahawa mereka tidak tahu
wire yang mana satu yang bermasalah - kos RM 1200. Walaubagaimanapun,
apabila sy bertanyakan kepada pendapat lain @ mekanik lain, mereka
menyatakan masalah dengan computer box. Harganya di perodua adalah
RM4000.00. Kalau RM400 xdak masalah sangat.
Ada tak sesiapa yang pernah mengalami masalah yang sama atau ada tak
cadangan yang boleh diberikan untuk mengatasi masalah ini. T. Kasih.Crying
MyProps
Posted 13 May 2008 - 05:48 PM
MyProps
  • 215 posts
wiring problem.
its not computer box problem.
it just effect yur aircond and engine check light problem... if computer
box, u will facing more problem than this 2...
dont go to PSC, sometime they dont know anything... ask yur friend or
neighbour that know the best mechanic at yur area espacially on car
electrical and electronic.
that will solve yur problem and it will cost u less then RM1200... mybe
around RM300 - RM400 only...
iwae405
Posted 13 May 2008 - 07:42 PM
iwae405
  • 3,320 posts
this is the time where community helps..u should be in the kelisa's
community or club and i'll sure there's someone willing to lend their parts
for troubleshooting..
just a suggestion tho...as i'm very pleasant with the community i'm with
now..very helpful.u should try..
thekop555
Posted 14 May 2008 - 03:33 AM
thekop555
  • 1,199 posts
agreed with iwae405.
but why SC not recommending u a resetting the ECU? no need replacement laa.
go to chop shop...lot of used ECU there.
cucuk
Posted 14 May 2008 - 10:10 AM
cucuk
  • 6,140 posts
used ECU from japan much cheaper and i heard is more powerful cos it's
designed for ron100 petrol in japan but before change ECU, check if there
is any bad connector at those sensors, sometime disconnection can happen
due to engine vibration causing the 'check engine' warning light on but
if it's the wiring that is disconnected, then hv to really change the
wiring cos it's not easy to locate which wire and where it's disconnected
and i dun think u can get used wiring loom at chop shop
comel76
Posted 14 May 2008 - 01:47 PM
comel76
    3rd Gear
  • 3 posts
thekop555
dah 2x sy p check kt tempat berbeza, guna comptr..1 kat SC dan 1 lg kt
mekanik khusus bahagian wiring tapi keduanya x dpt mengenalpasti punca.
Dua tiga hari lepas pomen lain pulak, dia cuma repair dan nasihatkan
untuk tukar. Biasanya dia akan jadi lepas tu hilang untuk beberapa lama
dan jadi balik. Masalah paling besar apabila jadi adalah bahagian enjin
akan jd mcm peti ais dipenuhi dengan ais sebab aircond berfungsi dgn
tahap maksima dan x boleh nak cntrol..dan dalam kereta tidak sejuk..
Kedai aircond pun sy p tp xdak masalah aircond..
Try survey 2nd hand kt kedai potong pun xjumpa lg...
Pening ni...Frown
MyProps
Posted 14 May 2008 - 03:34 PM
MyProps
  • 215 posts
wahh, suprise... quite complicated
i hav no idea right now
mybe u need to join the kelisa club or kelisa club forum as mention by
other forumer...
sure they can help...
iwae405
Posted 14 May 2008 - 05:44 PM
iwae405
  • 3,320 posts
tahap maksima dan x boleh nak cntrol.......
from this description la,most likely it's ur blower at fault..u
see,compressor keeps pumping the gas and the cooling coil always
working..it's just your blower didn't blow air to produce 'air' cond and
then cooling keeps happening without distribution..how do i say
this...seems confusing la..
ok,macam ni..blower tak jalan,sbb tu ais tu terbentuk kat high pressure pipe..
kunir
Posted 14 May 2008 - 08:04 PM
kunir
  • 90 posts
kepada comel.i also have the same problem with my kenari.same engine with
the kelisa.problem with my car is the radiator fan not working.so change
fan motor n wiring also not working.dead end.so sent to acond+wiring shop
after one day they said confirm computer box.blur.
sent to per2 second opnion.after one week they call n confirm computer
box.i asked how much?rm4000 pengsan.new kenari/kelisa computer box cheaper
but not the same.the only way is to find somebody is willing to repair the
computer box.i did that and syukur it work without a hiccup until 2day
per2 good car bad service from service center and can die on the spare
part price.
take care comel n good luck..........
comel76
Posted 15 May 2008 - 09:16 AM
comel76
    3rd Gear
  • 3 posts
kunir
kat mane tu awak repair..? kot2 la dekat dgn tpt sy...
