New Nisan Serena Fuel consumption
sengthee
Posted 19 April 2005 - 12:48 PM
sengthee
  • 1,609 posts
selfmech,
My method for calculating FC:
1) Fill up to full tank until the nozzle automatically stops;
2) Use the car until the tank is empty again;
3) Go back to the same petrol kiosk and the same pump (if possible). This
is to ensure the same level of sensitivity for the pump to stop
automatically again.
4) Fill up the tank until the pump nozzle automatically stops again.
5) Repeat the process as many times as you wish. Since it is the same
brand of petrol, the same kiosk and the same pump, the level of fuel
at "full tank" condition should be the same.
6) After a few trials, you should have some reasonably accurate figures
to work out the average FC of your car.
This is what I called controlled experiment. Cheers.
Zulkutty
Posted 19 April 2005 - 01:19 PM
Zulkutty
  • 28 posts
ctzen,
Durian season on the way now arround end of May,this time durian price
should be high like Unser Auto FC,i have durian orchard here but not
belong to me...lar.....If you want a durian no problem I can belanja
not a big deal
selfmech
Posted 19 April 2005 - 03:14 PM
selfmech
  • 22 posts
Dear Zulkutty,
Fuel calculation is okay. Just to share my experience on monitoring of
fuel, I have done it for years and over several cars. I experience a lot
of unexplainable figures as there are also some variable everytime. You
have eliminate quite a number of variables by using the same pump etc.
which is good. However unexplainable variable like delivery speed,
viscosity, ??? by petrol station owner, etc is something beyond our
control.
My suggestion will be to monitor consumption over at least 10 tanks of
usage and take an average and keep repeating the process.
Sorry for raising the doubt as I have heard too many claims that my
consumption is high, my is low on the basis of feel esp when you quantify
RM 50.
Hopefully my contribution here can get me some free durian.
Rgds.
ctzen
Posted 19 April 2005 - 03:37 PM
ctzen
  • 290 posts
Zulkutty,
Not enough rain,hor. No bumper crop. Actually, i don't eat a lot-lah.
Very choosy. My favourites - Ang Bak Kia, Siao Hoong, Tek Kha.
Dunno their Malay names.
ThumbUp
Zulkutty
Posted 19 April 2005 - 09:44 PM
Zulkutty
  • 28 posts
selfmech,
Thanks for your advise......No problem you would get durian reward from
me FOC.....but you need to come down here la to Balik Pulau or I just
send you a Durian picture + smell..ok ka
willow2003
Posted 24 April 2005 - 01:33 PM
willow2003
  • 177 posts
Just to share my experience with all driver
I consistencely monitor my car petrol, and lately I found
everytime I go to that particular petrol station, I lost
4KM/L (Normally for my car is 10KM/L +/-0.5KM/L in any petrol
station except this one - Shxll in Relau besides Petrona).
Few on my friends saw the same effect. We strongly believe that
something wrong with this Shxll in Relau, I don't want to comments
to much, you should know what I means here.
Zulkutty
Posted 26 April 2005 - 10:03 PM
Zulkutty
  • 28 posts
willow2003 ,
I agree with U,not only you facing this problem at Shell relau,a lot of my
friend also advised me not to go to this patrol station.I saw at this
forum last time a lot of forum member complain about shell petrol...less km
compare with others.For me I only use Petronas or ESSO/MOBIL.My previous
experiance with ALFA 155 ESSO and MOBIL is the best for power.Petronas
also not bad.
k027332
Posted 27 September 2017 - 10:47 PM
k027332
    5th Gear
  • 5 posts
May I suggest you try Caltex Techron95, gives better mileage than other brands.
Check your tire pressure and adjust to correct pressure. Serena comes with Bridgestone Ecopia, give good mileage on top of techron95.
May I also suggest you give your Serena a good paint protective coating and waxing. Smooth surface reduces drag and improve fuel consumption.
Does your Serena have a spoiler? Spoiler reduces drag behind, hence, fuel saving.
Posted 03 October 2017 - 01:26 PM
  • 71,443 posts
Actually spoiler increases drag because spoilers create down force for stability. Look at Bugatti Veyron high speed test, to do top speed they bring lower the spoiler.....
k027332
Posted 07 October 2017 - 11:25 AM
k027332
    5th Gear
  • 5 posts
Thanks for your response. I agree that spoiler increases drag, hence increases grip and fuel consumption. That I think applies to spoilers with inverted Aerodynamic design. There are spoilers that curve down like aircraft wings. This type smoother the air flow further behind the car and hence reduces drag and improves fuel consumption.
