Modenas Elegan experience(Part 2)
#61
Posted 06 January 2007 - 10:44 PM
Need to dismentle the front cover & dismentle the head lamp from the front
cover then you will see 1 small screw...from there you adjust lah.
Note : Dont adjust too high, you will end up with faded light.
I adjusted already & with new philip bulb & I took out the diamond.
Result....better than stock condition.
#62
Posted 07 January 2007 - 12:28 AM
affect the headlight cover (temperature?)
#63
Posted 07 January 2007 - 12:40 AM
Issue 1,2,4 & 6 - the best suggestion is to either send ur elegan back to
the dealer where u bought it or nearest SC to rectify it.
issue 3 - I have the same situation and maybe it is design flaw etc..
issue 6 - I think u can upgrade the bulb and remove the diamond cover as
what a few eleganeers here did.
#64
Posted 08 January 2007 - 09:16 AM
bike for 9 months with
the mileage of 8300km. Fun driving this bike but recently it has some
kind of sliping gear feeling when i go through uneven road, anyone over
here experience it ?
I share my experience with the workshop where i normally did my service,
he suspect that the spark plug need to be change which i am still using
the original spark plug till now. He said the spark plug is recommended
to change every 5000km interval, is it true ?
__________________________________________________________________
bro.. i think the problem caused by the roller.. not come from the plug..
that roller sudah haus ma.. so sudah tak bulat.. so at low speed u will
experience kind of sliping gear feelin.. geg geg geg..
#65
Posted 08 January 2007 - 05:18 PM
thanks a lot guys..
will update with this kind of machine :)
new finding today.. radiator fan activated.. nice!
the exhaust hot air blower at both side is really good
for night riding.. esp. when temp. < 23 cel.
#66
Posted 08 January 2007 - 11:15 PM
I'd like to share a tip for those who would like to replace their oem HL
bulb and also for those intending to make do without the diamond cover.
There IS an issue with extreme heat that can damage the headlamp cover and
also the reflector if u change to higher watt bulb and removing the diamond
cover. So, the best way to minimise it is by only switching on the
secondary light only during daytime i.e leave ur main headlight off.
Safety/visibility wise...don't worry it is still bright enough for other
motorist to see.
#67
Posted 09 January 2007 - 09:21 AM
Do you mean i need to change the roller ? i thought its require to change
after 10,000km or more ? Anyway, I will find out with the SC or to
replace it.
Thanks again.
#68
Posted 09 January 2007 - 01:46 PM
i am new here, thanks for all the elegan info, i've booked it and cant
wait to see this baby. will let all of you know the condition after i got
it.
i am 30+, have used suzuki gsx250, suzuki 125 scramble, cupchai (honda and
suzuki), kawasaki el250 even kawasaki gto many years ago, now planning to
ride on bike again, due to inflation-lah, bye.
#69
Posted 09 January 2007 - 05:51 PM
I admire your capability to do something to address the rising inflation
and chocking cost of living...
CONGRATULATIONS! Here's wishing you smooth journeys and best of luck on the
roads!
Really need to look at my finances to look for a place to "afford" my Elegan
regards,
Lance
#70
Posted 09 January 2007 - 07:53 PM
Cheers
