isc servo kit (throttle)
#32
Posted 12 October 2006 - 08:09 PM
could u show me the pic of the "IC" of the TB?? i catch no ball lah.
the one i showed in previous post is throttle position sensor adjustment (TPS).
#33
Posted 16 October 2006 - 09:25 AM
Hi, I am new here. To share my experience, I changed my T.B.
TWICE within a span of one week. Anyone break my record?
#34
Posted 17 October 2006 - 12:11 PM
care to share how this could happen?? This sounds crazy!!
#35
Posted 17 October 2006 - 03:01 PM
After Ist changed & tuned(at SA), the timing was unsatisfactory.Then
after 3rd attempt, it was worse, RPM rev unstable. So I claimed the TB
from the spare parts shop & installed at their workshop minus the tuning.
While I drove back home the RPM was very low. Luckily after I reached home
it became normal until now. That was about one month ago & still
monitoring it. All those involved said this was the first time they
encountered it & I hope it was the last for me after spending > RM 800.
May be it is not advisable to tune the TB after installation since
it was tuned before packing ?
#36
Posted 17 October 2006 - 04:50 PM
What would be your best advise? Get it straight from EON SC? Is it ok if
i purchased it otside? After listening to this story, i'm a bit worried.
Guys..need your advise urgently
#37
Posted 03 December 2006 - 05:47 AM
the IC cover on my old 1997 perdana sei TB also melted, diagnostic shows
the TB kicks in when the A/C is on. So mechanic says since the readings
and the gears inside the TB are ok then melted I/C plastic is not a
problem.but sometimes i do get jerky idling problem,
and engine dies off suddenly while waiting at traffic light and during
idling. all i do is replace the spark plugs and the problem solves for
about after 2000km and then the same symptom appears till i make another
spark plug job. looking at the the old spark plug it doesn't look wet or
oil on it and looks fine...something mysteriously going on here..
#38
Posted 15 December 2006 - 04:11 PM
soli for the late reply , quite bz lately,
i shall try to upload some photos (if i succeed).
got back the whole unit of my old TB
but one thing...i will not recommend anyone to the SC where i went..!
(subang 2, coner lot , yellow colour tire shop-dame blood ######)
#39
Posted 16 December 2006 - 08:50 AM
thanx you for ur patient.
i appreciate that
best regards
jigc
#40
Posted 15 August 2014 - 02:55 PM
Ming Ghee auto in Kallang sells original Mitsu 1.6 throttle body for
SGD250, +6562951382
hi bro samyvellu, sorry to wake up this old thread..
is this mitsu 1.6 throttle body exactly same as wira 1.6 xli (4G92p) throttle body? just plug and play?
for SGD 250 you get the full set or the bottom (halfset) only? many thanks.
