Bridgestone Ecopia Ep200
Posted 29 January 2014 - 09:19 AM
  • 71,444 posts
QUOTE (flee @ Jan 28 2014, 03:28 PM) <{POST_SNAPBACK}>
Yes this is the first time I encountered a FWD car (any brand/model) where the rear tyres wear out faster. And the same goes for the brake pads. Normally one would see the front wheels covered in brake dust. But this car has rear wheel brake dust!
SDAC cannot explain the reasons why tyre wear is so high... As for brake dust, they just said it is different brake pad material. My own car's tyres also last 40K but I usually change at 35K due to hardening rubber - I am a low mileage user...
My wife's SUV brake pads also wear faster in the rear and more brake dust also. As well as my friend's Odyssey, but seems is like that but not sure.... smile_question.gif
Gunnerzz
Posted 02 February 2014 - 01:01 PM
Gunnerzz
  • 3,102 posts
i just rotated my ep200.
its started to get a bit more noisy up front when its 20% wore out.
now front set also wore out nearly the same as rear so its noisy all around. the roaring sound is pretty loud.
griplevel is the same in dry but a bit lesser in wet during cornering.could be due to the small sipe wearing out.
braking in wet is the same.
Gunnerzz
Posted 09 February 2014 - 11:57 AM
Gunnerzz
  • 3,102 posts
i went for a downhill drive last friday at bukit putus.
it was an all out assault to see if my old n faithful is still up to the job
along the way to the hill i notice that the sound is getting louder.
loud enough to make me increase the radio's volume by 2 points.
whats it like downhill?
i was skeptical on the first few corner but from then on i was braking super late
and carrying more and more speed on the corner.
the waja character helps making manouvering the sedan easier.
it wont beat a performance tyre but it peform well beyong its category.
i can feel the sidewall flexes but i guess the 1psi increase in pressure
helps a little.
Posted 09 February 2014 - 10:16 PM
  • 71,444 posts
Dry usually okay, when it comes to wet then the difference will be there. Even traction rating is wet tested rating in straight line grip...
Gunnerzz
Posted 10 February 2014 - 02:11 PM
Gunnerzz
  • 3,102 posts
QUOTE (vr2turbo @ Feb 9 2014, 10:16 PM) <{POST_SNAPBACK}>
its lousy on wet cornering.xm2 is way better.
Posted 10 February 2014 - 02:17 PM
  • 71,444 posts
QUOTE (Gunnerzz @ Feb 10 2014, 02:11 PM) <{POST_SNAPBACK}>
That bad ah? XM2 already Michelin entry level only...
Gunnerzz
Posted 10 February 2014 - 07:05 PM
Gunnerzz
  • 3,102 posts
QUOTE (vr2turbo @ Feb 10 2014, 02:17 PM) <{POST_SNAPBACK}>
the surefooted feeling is not there.
then again i am not going that slow.maybe asking too much for its range though.
Posted 10 February 2014 - 07:47 PM
  • 71,444 posts
QUOTE (Gunnerzz @ Feb 10 2014, 07:05 PM) <{POST_SNAPBACK}>
flee
Posted 20 October 2014 - 12:40 PM
flee
  • 7,018 posts
I have just received some feedback from my friend driving on these tyres (fitted to the rear) during the current rainy season. It seems like wet grip is not good - car unstable especially when driving over the painted road markings of the roads.
Seems like there is a momentary loss of grip as the tyres are running over the painted lines....
Regards,
Flee
Posted 21 October 2014 - 08:55 AM
  • 71,444 posts
QUOTE (flee @ Oct 20 2014, 12:40 PM) <{POST_SNAPBACK}>
