Bi-xenon Headlights For Waja
ntc2000
Posted 29 December 2009 - 01:10 PM
ntc2000
  • 19,286 posts
i tot is ballast control its temp ??
is bulb meh? If I use 4300k ballast + 6000k bulb, wat is the outcome ah?
cmpong
Posted 30 December 2009 - 12:14 PM
cmpong
  • 481 posts
QUOTE (ntc2000 @ Dec 29 2009, 01:10 PM) <{POST_SNAPBACK}>
Ballast control the voltage supply -not the "bulb" temp, put it in simple term like our fluorescent light at home.
You can change the temp from 6500k (normal white) to warm white 4000+k like those used in restaurant., but the ballast still the same
Changing to 6000k bulb will not help as the optimum lumen output is at 4350k, that's why xenon manufacturer choose that. However, 6000k will increase the glare, one will assume the brightness has increased based on how glaring it is, but not in actual fact.
glare is not equal to brightness.
Fyi, as the xenon 'bulb' ages, it will become whither (increase in color temp). It is common after few year usage it turns to 5000k from original 4350k.
baldwin
Posted 30 December 2009 - 01:15 PM
baldwin
  • 2,093 posts
mine went from 6000k to about 5000k with 3 years of usage.
cmpong
Posted 30 December 2009 - 02:14 PM
cmpong
  • 481 posts
happy.gif , may not be OEM
ntc2000
Posted 30 December 2009 - 02:16 PM
ntc2000
  • 19,286 posts
QUOTE (baldwin @ Dec 30 2009, 01:15 PM) <{POST_SNAPBACK}>
fooh... how come ur temp will decrease 1?? I tot only increasing...
daifuku
Posted 30 December 2009 - 02:53 PM
daifuku
  • 781 posts
aiya so susah for wht
pasang this ,pasang that
na beh..i already straight away pasang 1 pair of 4300k HID liao
now terang terang malam masuk hutan shoot babi hutan also no problem lah smile_big.gif sterb324.gif
cfa
Posted 30 December 2009 - 02:57 PM
cfa
  • 833 posts
QUOTE (daifuku @ Dec 30 2009, 02:53 PM) <{POST_SNAPBACK}>
Meaning, it replace your ori HID bulp??? Sorry, I very perlahan.
ntc2000
Posted 30 December 2009 - 03:18 PM
ntc2000
  • 19,286 posts
QUOTE (cfa @ Dec 30 2009, 02:57 PM) <{POST_SNAPBACK}>
i guess he change halogen to after market HID... not the OEM HID BULB for CPS
shahie
Posted 25 June 2011 - 02:09 PM
shahie
    Driver
  • 37 posts
Currently my brother using CPS Model, but not a premium model & Not using Xenon headlamp. say he want to buy the original xenon headlight from proton, how it works ? did just plug & play including the levelling switch ? or the wiring system for premium & non premium model is totally different ? meaning say the additional wiring is required if you mod to Xenon headlight.
Anyone does it ?
Regards
