here are price list for spare parts i bought recently...
1. engine mounting locko full set RM170
2. original air filter PW510765 RM24
3. panel cross member local mali RM100, original RM150
4. original single switch power window RM23
5. wiper blade 19/21 denso RM23
6. original door regulator rear (with metal enforcement) RM160
7. bosch brake disc front RM160 (both side)
8. bendix titanium brake pad front RM110
hope this help for your shopping
Price List Spare Part Proton Waja
ady4455
, Apr 18 2008 03:05 AM, 14 replies to this topic
Posted 02 April 2009 - 01:28 AM
9. Lucas brake master pump 1.6/1.8 ABS RM285
10 master brake pump repair kit 1.6/1.8 RM65
11 brake fluid resevoir RM60
12 ori oil filter 1.8 RM22 (used to be cheaper)
updated
updated
Posted 11 August 2009 - 06:23 PM
QUOTE (ady4455 @ Apr 18 2008, 03:05 AM) <{POST_SNAPBACK}>
BIL SPARE PART PROTON WAJA HARGA
1 Brake Pad Rear Trestor RM 65
2 Brake Pad Front Trestor RM 53
3 Door Handle Rear Original Black Colour RM 28
4 Door Handle Front Local Silver Colour RM 20
5 Door Handle (Local)- (Without Paint), RM 10
6 Door Handle (With Paint) RM 25
7 Suspension Link Front RM 55
8 Arm Suspension Alignment Rear (Mitsubishi) RM 90
9 Engine Mounting (Brand Locko) Full Set RM 180
10 Original Wiper Blade 19/21 RM 23
11 Bearing Wheel Front (TNT) RM 42
12 Oil Seal RM 12
13 Cover Under Fender Front Original RM 55
14 Cross Member Original RM 150
15 Power Window Switch Rear RM 26
16 Power Window Complete Set Siap Upah RM 280
17 Power Window Assembly RM 180
18 Rear Window Glass RM 68
19 Front Window Glass RM 110
20 Battery GP MF NS60 RM 195
21 Battery Century MF RM 210
22 Clock Spring Original With SRS RM 260
23 Door Latch Driver Side Original (Bought at PESC) RM 234
24 Door Handle RM 50
25 Absorber Kayaba Front And Rear ( Sapura Supplier ) RM 350
26 Absorber Monroe Front 1 pcs RM 175
27 Absorber Front Mounting Original RM 85
28 Sport Spring ( Felix ) RM 200
29 Fuel Pump RM 450
30 Fuel Filter RM 70
31 Water Pump RM 122
32 Drive Belt (Mitsu) RM 34
33 Air Cond Belt (Bando) RM 37
34 Crank Sensor (Mitsu oem) RM 218
35 Auto Oil/Power Steering RM 18
36 Brake Fluid (Dot 4/ 060.5L) RM 30
37 ECU Tuning Service Charge RM 25
38 Brake Pads Front 1 Set RM 80
39 Brake Pads Rear 1 Set RM 48
40 Coolant Radiator (Petronas 0.5 ML) RM 13
41 Coolant Radiator (Shell 0.5 ML) RM 15
42 Coolant Radiator (Shell 1.0 ML) RM 25
43 Coolant Radiator (Caltex 0.5 ML) RM 17
44 Coolant Radiator (Tin 0.5 ML Car Accessories) RM 6
45 Castrol GTX 15W 40 RM 60
46 Castrol Magnetic 10W 40 RM 75
47 Air Filter RM 10
48 Oil Filter RM 8
49 Clutch Plate ( Exedy )Complete Set RM 210
50 Spark Plug (NGK R) RM 25
51 Supplier Timing Belt KL/PJ .CALL 012-2908159
- Gaido 2 years warranty RM 200
- Gates RM 130
- Dayco RM 160
- MMC Local RM 130
- MMC Original RM 190
52 Aligmend 4 Tyre RM 25
53 Adjust Chamber 1 Tyre RM 15
54 Tyre Silvestone M5 215/45/17 1Pcs RM 200
55 Tyre Bridgestone Potenza 215/45/17 1Pcs RM 260
56 Repair Sport Rim 1 Pcs RM 30
12 Oil Seal RM 12
29 Fuel Pump RM 450
47 Air Filter RM 10
48 Oil Filter RM 8
- Gates RM 130
- Dayco RM 160
- MMC Local RM 130
Any updated price for 2009 ?
Posted 14 March 2012 - 10:28 PM
12 Oil Seal RM 12
29 Fuel Pump RM 450
47 Air Filter RM 10
48 Oil Filter RM 8
- Gates RM 130
- Dayco RM 160
- MMC Local RM 130
12 Oil Seal RM 12
29 Fuel Pump RM 450
47 Air Filter RM 10
48 Oil Filter RM 8
- Gates RM 130
- Dayco RM 160
- MMC Local RM 130
what is your contact number?
Posted 13 June 2012 - 11:53 AM
QUOTE (jeffrychow @ Mar 14 2012, 10:28 PM) <{POST_SNAPBACK}>
hello ... ini thread tahun 2008 punya la. Harga pun sudah tak sama la saya ingat ...
willi
