Aircond Not Cool
jammae
Posted 14 February 2012 - 06:43 PM
jammae
  • 11 posts
Hi all,
Need expert advise about aircond problem,when drive at afternoon like sit on free sauna...better open the window.
Last month I'm already go to aircond shop then
the mechanic suggest change the compressor & I change...400 fly....
Problem not solve, then I go after 1 week...he said my radiator fan problem...
I change it...also the problem not solve....now I need to share if anybody have case like me.
Regards...
Jammae
kohf1drive
Posted 14 February 2012 - 09:30 PM
kohf1drive
  • 3,077 posts
QUOTE (jammae @ Feb 14 2012, 06:43 PM) <{POST_SNAPBACK}>
Hi all,
Regards...
That workshop need to blacklist
As last time also had similar experience, every time give excuse that 1 spoil, this 1 spoil, bla bla change change
Go to your reliable workshop for the repair, troubleshoot
If no leak (rotten egg smell) then just need to vacuum n pump the gas n change dehumidifier
Posted 19 February 2012 - 12:52 AM
  • 23,878 posts
QUOTE (kohf1drive @ Feb 14 2012, 09:30 PM) <{POST_SNAPBACK}>
On top of that, if gas too much also will not cold.
Gunnerzz
Posted 19 February 2012 - 11:07 AM
Gunnerzz
  • 3,102 posts
Hi all,
Regards...
Could be the expansion valve.
Simple and cheap replacement.
Better still, go to authorized dealer either APM or Denso. Its worth the money paid.
I will try to avoid all those normal aircond shop.
avionics
Posted 21 February 2012 - 12:13 PM
avionics
  • 376 posts
Hi all,
Regards...
U can check the aircon hose..maybe leakage..my hose kena bakar by the 4-2-1..or might be the drier...radiator fan juz change the motor la..rm80 lidat...when u on the air con,make sure the 2 fan is running..if not running,check the aircon host got gas anot.
Hai m so naive.
justdoit
Posted 21 February 2012 - 08:08 PM
justdoit
  • 227 posts
QUOTE (avionics @ Feb 21 2012, 12:13 PM) <{POST_SNAPBACK}>
Blow off the trapped excecess contaminated compressor oil(not at the compressor). The change the drier and expansion valve. I think it will do.
moon
shamsul74
Posted 30 November 2012 - 12:13 PM
shamsul74
    3rd Gear
  • 3 posts
QUOTE (justdoit @ Feb 21 2012, 08:08 PM) <{POST_SNAPBACK}>
Try change the filter inside aircond blower.
gtmaniac
Posted 04 December 2012 - 09:50 AM
gtmaniac
  • 374 posts
When u went for the compressor change, did you serviced the whole a/c unit as well?
I have changed my compressor too (I paid even more than u did!). Now it's too cold - i have to switch it off a few times while driving, especially at night!
tantk58
Posted 20 May 2013 - 12:52 AM
tantk58
    3rd Gear
  • 3 posts
Hi all,
Regards...
Hi,
I am driving a 2003 waja, despite many trips (repairs) to my air-con shop, my air-con is barely
bearable for almost a year.
Finally I went to a recommended air-con shop. He suspected its the compressor and then
he decided to check my air-con gas. He found that it was a mixed of the old type and the new
type gas. He has a briefcase size instrument to check. He showed me it was a mixed of 30% and
70% of old and new type.
So he drained off the gas and pump in new gas. The effect was immediate. Now my air-con is
super cold even in the current heatwave we are in.
Hope this helps!
mych
Posted 04 February 2014 - 03:17 PM
mych
  • 7,789 posts
It could be a radiator issue if it is leaking...
Mych
