QUOTE (pciericagp @ Dec 14 2009, 02:19 AM) <{POST_SNAPBACK}>
The choices is yours. I can just said toyota avanza and perodua alza was same quality as both are manufactured in the same plant and production line. Confirm! Sources was from people working inside perodua. Perodua already got facility to built K3-VE and 3SZ-VE engine, gearbox only source from japan. Even avanza was 90% local content since facelifted.
Please don't compare MyVi quality with this Alza cause different production line and robotics system. I got confident on the car. Shall be average as good as kelisa with minimal failure rate. Please check on the transmission, is was direct 4-speed automatic transmission without OD, different from Avanza that using OverDrive. It provide better fuel efficiency.
Is just a bit desperate cause even toyota avanza also doesn't equipped with ECT or Super ECT auto transmission.
i tot that OD is just a switch, u can also disable the OD by engaging D3 in the alza, that is also just another switch to tell the GB what not to do
