Alza Vs Avanza
Posted 01 December 2009 - 05:49 PM
However,
If you want a less than RM100 oil change, Less than RM200 tyre, parts easily available new or used...
Timing chain drive with near fail proof Toyota engine, gearbox with VVTi feature...
Built quality not as bad as Proton... but priced near a Proton
In summary, If your budget is around 60K, you do not have much choice but Alza... No point bashing it if you can afford better/more expensive make.
Posted 02 December 2009 - 09:20 AM
However,
Yup. I agreed. That's the best you can get with this price.
Posted 08 December 2009 - 09:11 AM
Posted 08 December 2009 - 11:03 AM
Avanza is assembled in Perodua Plant, too... Should have same assembly quality...
Posted 08 December 2009 - 02:07 PM
ya lol the name also almost same lol... Avanza & Alza.... adik and abang also...
Posted 10 December 2009 - 08:23 PM
more local made component inside malaysia quality u know lah.
Posted 10 December 2009 - 10:14 PM
In this case, it is Indonesian components VS Malaysian components... which is better?
Posted 13 December 2009 - 12:43 PM
some ppl just expect too much...
Posted 14 December 2009 - 02:19 AM
Please don't compare MyVi quality with this Alza cause different production line and robotics system. I got confident on the car. Shall be average as good as kelisa with minimal failure rate. Please check on the transmission, is was direct 4-speed automatic transmission without OD, different from Avanza that using OverDrive. It provide better fuel efficiency.
Is just a bit desperate cause even toyota avanza also doesn't equipped with ECT or Super ECT auto transmission.
