Do MYVI have any problem?
Posted 03 October 2008 - 03:22 PM
be a DIN 2 unit which allows you to upgrade to other after market brand.
Posted 06 October 2008 - 08:05 AM
box i don`t feel smooth.. it hard to switch sometimes and always VIBRATE
during drive if i touch.. then i sent to Perodua SC to get 1st service.. i
don`t feel different with my gear box...
on 3rd service period (10,000-11,000) in 17 dis 2007 , i sent my myvi sxi
for service.. i dont know why they replace my spark plug.. then...
4th service ( 15,000)(25 feb 2008), i also sent myvi sxi to this SC
again...BUT before
4TH service, my MYVI got new PROBLEMS.... ALL MY POWER WINDOWS
MALFUNCTION.. ONLY DRIVERS POWER WINDOWS SWITCH WORKS..(3 PASSENGER POWER
WINDOWS switch MALFUNCTION AT CENTRAL/DRIVER SWITCH)....
my brothers forget to tell the SC about this problems...
then i take an action after 2 month from 4th service at perodua SC..i
report at another BIG SC AT JB for this problem
and also for my gear box..they promise me to fix in two weeks later... but
UNTIL NOW 6 OCT 2008 i don`t receive any answers from
PERODUA to FIX my problem...
what i found i MY MYVI NOW, ONE OF 3 SCREW AIR FILTER BOX LOSS!!!!
I EXPECT THE LOSS OF THIS SCREW DUE THE 3RD SERVICE AT PERODUA SERVICE
CENTRE... THEY REPLACE MY 6 MONTH SPARK PLUG ON 3RD SERVICE - SO they MUST
to pull out my AIR FILTER BOX to replace it RIGHT?... how bad sc job...
(PATUT LA air filter ori aku cepat itam jer..) PERODUA SC aku nak balik
screw tu!!!1
Posted 06 October 2008 - 10:06 AM
follow Perodua recommended service schedule. I also kena spark plug
change twice, the 2nd change done after 4500km of the 1st change. Must
be mad to change plugs within 4500km, which is exactly what I told them.
Many items were changed well before listed time in Perodua service
manual. When I question them, all they can say is that it is their
service policy. Asked them why don`t follow Perodua recommendation……
Answer: “cannot follow book blindly”. Told them to go screw themselves. I
now follow Perodua service manual with my trusted mechanic. Next service,
I will change to fully synthetic oil.
Posted 09 October 2008 - 09:05 AM
years it`s been problem free. Now symptoms of problems are beginning to
show. I have the following symptoms:
1. Kok,kok sound from steering when the road is rough or broken
surface.
2. Squeaky sound from auto gearbox during gear change.
3. Fuel fume smell in the cabin if full tank of fuel.
I`ve only done 30k km. Inspite of the low mileage these problems have
appeared. My opinion is that the local content in this car is of poor
quality.
Posted 21 April 2009 - 11:04 PM
hi bro,
u service ur car at p2 original service center? or outside?
have you change ur auto geaar oil?
mine oso 2006 but FEB
so far, got the sound when in non flat/rough road...
i think it is normal for a P2 car..because they design it with "ECONOMY FC" priority...so the chassic r LIGHT...
surface.
quality.
Posted 22 April 2009 - 10:27 AM
1) 2 sets of Rotol disk due to vibrate during braking.
2) 2 sets of power steering pump.
3) 3 sets of power window.
4) 1 set of wheel bearing (front)
other than the above, I would give a good verdict to the VVTI engine that
proven to be very reliable, smooth and powerfull as compared to 1.3 saga.
Cheers.
Problem 1 = is normal
Problem 2 = what? 2 set power steering pump?
Problem 3 = is normal
Problem 4 = how is your driving style? my friend and family that own this car didn't report this problem before.
My friend/family that own Myvi report this few of problems:
1) radio sometimes hang. The CD can't be ejected and sometimes the radio automatically reset the radio station that preset at the radio. have to set again the channel
2) steering vibrate when braking
3) hand brake indicator at the meter faulty
4) power window switch faulty
5) the car got petrol smell after refuel full tank. if refuel half tank, the petrol smell got but not very obvious when put full tank
Cemerlang Gemilang Terbilang dan Terus Hilang
Posted 23 April 2009 - 12:51 PM
I have had my car for 2 years and I am very happy with it.
I drive back Penang- KL very often and thankfully the car has served me well. No plans to change the car anytime soon.
The problems I had:
1) Master power window - replaced 5x since new FOC due to engineering fault.
2) Brake rotor disc brake - sent for skimming and the problem resolved. Also did the wheel balancing to make sure all ok.
3) The petrol smell is normal as I also notice that too.
4) The glass window for front doors are very loose and have had them tightened. If I put half down and drive the glass vibrates and is annoying.
5) The latest problem is a stupid squeeking noise from the co-driver seat during highway trips. I am gonna DIY to have a look at it this weekend.
6) Also, water leaking at my co-driver side back door. Situation still not that bad yet. I am uncertain if it is the rubber or what. I shall test it out and see what I can do about it.
My car is 1.3 Auto so the consumption is a bit high than manual Myvi. But I feel it is still cheap to maintain. Also, a must is to check ur Auto gear oil every 20k.
To make the car comfortable: Install some good sound proofing foam and tint the glass coz Myvi glass very big.
Despite all this one thing I love about the Myvi is that it is fun to drive!!!
Posted 09 May 2009 - 11:05 PM
It is good for what it is supposed to do. But not for racing lah...
Posted 12 May 2009 - 11:12 AM
1) fuel pump defected after 2yr++ (need 1.7k++ to replaced)
2) comfort loss n interior noise after 2yrs (like my 8yrs wira)
3) engine suddenly die off due to temperature sensor.
4) fuel comsuption high (full tank 280-300km)
5) car feel underpower (during highway, hard to overtake car on 110kmh)
6) radio defect after 1yrs
7) temperature sensor socket easily loose when change spark plug
8) ecu replacement
Posted 12 May 2009 - 02:31 PM
==> not happen yet (touch wood) only experiencing when pump full tank, got petrol smell in the cabin. the smell will dissapear after finishing about half tank
==> agree with u. in the 1st-2nd years the car feels good but after 3rd year, the suspension begin to appear abnormal sound esp on uneven road. not sure is related to the nct5 tyres or not
==> not serious as u. so far, only experiencing engine vibrate like hell when idle. it intermittent. mechanic also not sure what happen
==> agree. manual i not sure same or not
==> agree. is like 110kmh is the top speed for the car.
==> i got fren radio always hang.
==> not experience yet
8) ecu replacement
