#31
Posted 07 April 2009 - 06:40 PM
hmm...
what about comparing NCT 5, C drive and Conti Comfort Contact 1
how?
i think all about the same right?
I've used NCT 5, and now on Conti CC1...both not to my liking on my vios
Conti CC1 are entry level tyres. NCT 5 are actually their mid level tyres. The lower range are the Ducaro which is their touring tyres and NCT3 also.
C-Drive used to be Yoko Mid level tyres, but not sure of the Philippines made ones....
#32
michael80
Posted 10 April 2009 - 10:58 AM
hmm...
how?
try PP2... trust me... or S drive...
has been using PP2 for my SEG and Vios over 1.5 yrs already... performance... still good...
my Vios wear near the safety bridge (2mm more i think)...
SEG worst... pass the safety bridge... around 1~2mm left before botak... still serve me well...
this is the safety guide by michelin...
http://www.michelin...._tipsAdvice.asp
#33
Posted 10 April 2009 - 02:08 PM
http://www.michelin...._tipsAdvice.aspPP2 and S-Drives are of different class. Both are next to their top range tyres in their respective brands.
Not sure of PP2 sizes as I don't follow much on Michelin's, but for S-Drive they come with 55 series aspect ratio and below, therefore if you are looking for 60 series, then there are no such sizes.....
rdgs,
#34
michael80
Posted 10 April 2009 - 02:38 PM
same PP2 if not mistaken only have 55 and below...
sorry... did not notice that he want 60 tires... try Primacy
#35
Posted 10 April 2009 - 04:42 PM
Bro.
Even if they don't mention the size, sometimes we have to be careful with the recommendations.
And also we have to take their priorities into consideration.
Some just want comfort and lasting and if we ask them to get UHP tyres for grip they will &%!@#....
#36
michael80
Posted 10 April 2009 - 05:06 PM
#37
Posted 10 April 2009 - 06:18 PM
yes taiko... sorry...
Don't call Taikoh lah, like Hug Seah Wui...ha! ha!
Are you from P.J. area?
Can join us for TT mah.....
Posted 13 April 2009 - 12:07 PM
cedax
guys
I'm using 195/55/15 on my vios
highway driving it feels a bit wobbly
was just thinking, is my tyre pressure not right
How much did u guys put in
#39
michael80
Posted 13 April 2009 - 03:01 PM
well recommended pressure... sure your vios got said mah...
for my PP2 i always pump 32~34 PSI lo... depends...
but recommended pressure is around 31~32 PSI... so i put a bit more...
recommended by Michelin that if you drive your car more than 2km already you have to put 2~4 PSI higher...
#40
Posted 14 April 2009 - 10:42 AM
guys
Bro. cedax,
Also depends on your tyres. If soft sidewall tyres like ZE-912, then you need to add another 2 to 3 psi over your original recommended pressure.
Anyway, you can trail and error the air pressure. You can either go up 2psi per time until you find it uncomfortable, then start reducing until you find the setting that suits you the best. No need to follow factory specs.
rdgs,
