SRS Clockspring
Posted 18 November 2008 - 12:35 PM
charged to activate, that’s the main purpose clock springs were designed,
others are just riding and sharing on the same clock spring flex cable
platform of the airbag.
Basically in the clock spring, wire cables are wound in such a way that
would not get entangled when turning the steering wheel. Unplugging the
clock spring socket will disable all systems using the clock spring as
their electrical path.
Airbag should be removed if access to the steering nut is obstructed.
Posted 18 November 2008 - 12:44 PM
etc
Maybe its time to start with f1 technology, can implement on our steer
1st. Less tedious dismantle step
Posted 26 November 2008 - 10:37 AM
back to normal. bought for 185 at spare part.
Posted 28 November 2008 - 12:44 PM
Posted 03 February 2009 - 07:58 PM
What was the main reason for the clock spring to fail? My car horn started to go off by itself when I made a right turn just now.
Where did you fix yours?
I'm using 1.8X
Posted 04 February 2009 - 10:45 AM
I'm using 1.8X
Posted 04 February 2009 - 10:49 AM
Posted 19 September 2010 - 10:18 PM
can u give me the direction/ name of the spare part shop/ fon number
tq in advanced
Posted 11 February 2011 - 05:07 PM
i don't know whether i'm lucky or otherwise...
the mechanic(s) at Proton D'sara Damai is very friendly......
My name is michaelJenn.
I'm the grave digger....
Posted 12 February 2011 - 02:29 PM
Few days b4 CNY, my dad's 1.8 steering will produce noise when the steering is turn.
The sound is like when we crumple hard plastic.
The next day, the horn sound when the steering is turn so confirm its the clockspring.
I took it to the sc and they hav to order the part.
When i was driving out of the sc, the horn is sounding non stop.
So, off goes the fuse. On the way home, SRS light blink so i stop and remove the fuse oso.
It is not convincing at all to drive when every movement of the steering is accompany with the plastic crumpling sound.
U never know when the airbag might suddenly explode in your face. Worst if it happen at traffic light when there is awek cun beside u.
Just got it change today and great part is i get to play with the old SRS clockspring unit.
Here it is.
Such simple device which can save your life
rear pic
auto cruise controller comes in the replacement set. This is the old unit.
I remove the cover and the pic says it all......
