Automatic Transmission Fluid (atf)
fkmfkm
Posted 20 March 2012 - 05:31 PM
fkmfkm
  • 5,021 posts
QUOTE (acapryl @ Mar 20 2012, 05:15 PM) <{POST_SNAPBACK}>
ive did the atf flush but didnt change the filter or oil pan coz its quite expensive.
so my car move smoother now. however it doesnt rectify the problem when i on the aircond, the power dropped a lot. the mechanic said my wiring has problem due to the old wire. so my car dont have enough electric to supply for the whole operation. dats why power drop. really ah?
filter cannot be expensive lah...should change since u open it up....
what u mean by power drop a lot? how u tell alot ?
acapryl
Posted 20 March 2012 - 07:45 PM
acapryl
  • 80 posts
QUOTE (fkmfkm @ Mar 20 2012, 05:31 PM) <{POST_SNAPBACK}>
power drop here means.. i give u example :
if i dont on the aircond, then my power will be 100%. so my car are very fast like dis. but when i on aircond, the pickup reduce, feel less torque, feel very2 heavy. the difference is significant. its like losing 20% of total power.
another phenomena is, when i on the light, wiper, or move the mirror up or down, the timing get really low. like engine wanna dead. if move both passenger and drivers mirror, the more timing drop.
for dis reason that mechanic said my car dont have enuf electricity supply
Posted 20 March 2012 - 09:06 PM
  • 71,492 posts
QUOTE (acapryl @ Mar 20 2012, 07:45 PM) <{POST_SNAPBACK}>
The power drop, means the air con compressor is heavy. Even my manual car, when want to do fast runs I will turn off the air con compressor..... smile_tongue.gif
As for the Idling speed dropping when using electrical load, yes my old car gets that too. Unless your idling can be adjusted manually to a higher speed, then can solve that problem.
acapryl
Posted 21 March 2012 - 12:27 AM
acapryl
  • 80 posts
QUOTE (vr2turbo @ Mar 20 2012, 09:06 PM) <{POST_SNAPBACK}>
we have the same prob then..
so i need 2 service the aircond compressor lah
Posted 21 March 2012 - 01:33 PM
  • 71,492 posts
QUOTE (acapryl @ Mar 21 2012, 12:27 AM) <{POST_SNAPBACK}>
Check the compressor first, whether is like that or need service?
Anyway, running at high RPM with air con compressor on is not good for it either.... smile_wink.gif
acapryl
Posted 22 March 2012 - 11:18 AM
acapryl
  • 80 posts
QUOTE (vr2turbo @ Mar 21 2012, 01:33 PM) <{POST_SNAPBACK}>
yeah when im speeding normally i dont on aircond.
where can service compressor leh? all workshop said must change.. all want easy work.. denso can ah
Posted 22 March 2012 - 11:22 AM
  • 71,492 posts
QUOTE (acapryl @ Mar 22 2012, 11:18 AM) <{POST_SNAPBACK}>
I think most members will tell you air con station.....let me find the topic.... smile_tongue.gif
Ah! just below only....
http://forum.autowor...h...0&start=320
acapryl
Posted 23 March 2012 - 01:00 AM
acapryl
  • 80 posts
QUOTE (vr2turbo @ Mar 22 2012, 11:22 AM) <{POST_SNAPBACK}>
Posted 23 March 2012 - 02:03 PM
  • 71,492 posts
QUOTE (acapryl @ Mar 23 2012, 01:00 AM) <{POST_SNAPBACK}>
ShiftVQV6
Posted 23 March 2012 - 03:10 PM
ShiftVQV6
  • 5,659 posts
pinjam to ask.... is it normal to change automatic gear cable ?? does this cable get spoil easily?
