1.8 Gearbox Again!
rain
Posted 03 January 2011 - 04:47 PM
rain
  • 34 posts
[b]Hey guys,
Guess what!!! GB problem again.
Senario
1st gear, trottle it..( normal )
2nd gear, trottle it..( does not change gear till high RPM and gear something like slips )
3rd and 4th gear...( gear still slips like when in 2nd..when lepas trottle, the RPM drops ..much like a normal auto gearbox )
Normally this 1.8s, when we cruiz ..about 90km/h, RPM should be about 2.5K right? But I'am getting about 3 plus. Then when I lepas minyak, my RPM drops. This is not suppose to happen to the DPO GB right?...We should have some kind of engine breaking when we lepas minyak right?
SO I pun frust...so I tarik la...1st, 2nd...and guess what...2nd gear I pull pass 4.3 or 4.4RPM the gear enggaged like normal. No slip. Then to 3rd and 4th like normal...the car was fine after that.
BUT when I slow down and the GB shifts back in 2nd ...there it starts again.
QUESTION!!!!...WHAT COULD BE WRONG? Suspects?
1) Valve body solinoid valve?...but which?..there are 8 in total?
2) Brake band?....normally if i cannot move forward but can go backwards..I think that would be it..but not this case
3) Not enough AFT?...oready check it
4) Clutch?....but if it is...then it should be constant slip...not back to normal after I Rev the darn thing
5) Drity AFT?.....Maybe la...what you guys think?
6) TCU...???
7) Are there any other sensors that I miss out?
What you guys think?..iam out of idea?
turnip
Posted 03 January 2011 - 11:15 PM
turnip
  • 165 posts
Waja 1.8 user here,
I was having that problem due to my coolant dripping onto my gearbox and wires.Having those slippery gear changes, ESPECIALLY when Jams on sunny hot days at highways.I let it cool down and drove during midnight.No problems.
My case was the wires or connectors behind the gearbox were wet and dirty.Asked my foreman to fire it with air gun.
So far okay.
as a human you must seek for the truth
Waja 1.8X
Engine : F4P 771 auto(same as Renault Laguna II)
Spark plug : Should be the default "Champion RFC 87YCL opening 0.9" but using some cheapo spark plugs now =_="
Fuel System : Sagem S2000
Torque (x / o.min) : 170Nm/3750
Top speed (km / h) : 198
0-100 km / h (sec) : 11
Air Filter : Stock(gonna change to K&N as recommended by brother Arazakmy)
rain
Posted 04 January 2011 - 06:17 PM
rain
  • 34 posts
QUOTE (turnip @ Jan 3 2011, 11:15 PM) <{POST_SNAPBACK}>
Waja 1.8 user here,
So far okay.
Bro,
My problem is much like yours. Just that the temp has no effect to this problem. Drive at night or day or even after the car has been sitting in the porch for 2 or 3 days. Any other clues
That could me out? And BTW, thoso connectors were the first I clean.
Gunnerzz
Posted 05 January 2011 - 09:35 PM
Gunnerzz
  • 3,102 posts
QUOTE (rain @ Jan 4 2011, 06:17 PM) <{POST_SNAPBACK}>
Bro,
how old is your battery?
nbj6343
Posted 09 February 2011 - 08:16 PM
nbj6343
    5th Gear
  • 5 posts
hi,rain;
I think is your gearbox sensor failure, go to workshop check .
my gearbox sensor rencently also short, D is blinking & auto gearbox light is on, no power, sometime may change to 2nd gear automatic, go to workshop (no proton workshop), check with computer, & change the sensor, now,is fine.
Posted 13 February 2011 - 03:43 AM
4798
  • 61 posts
DONT WASTE YR MONEY TO REPAIR IT, EVEN PROTON SC DONT WANT TO WARRANTY U.
ON MY EXPRIENCE MANY OF MY CUSTOMER WASTE A FEW THOUSAND TO REPAIR THIS GEARBOX..ONE OF THEM SPEND ALMOST 12K . 2X CHANGE THE GEARBOX ,ECU,TCU ETC.
IM A PROTON WAJA SPECIALIST GARAGE. I DONE A LOT OF CONVERSION OF THIS PROTON WAJA 1.8 AND I HAVE A LOT OF THIS PROTON WAJA 1.8 PARTS.
MY PACKAGE:-
1.8 RENAULT ENGINE > 1.8 SOHC MITSUBISHI ENGINE RM 6K
1.8 RENAULT ENGINE > 1.8 DOHC MITSUBISHI GSR TURBO FROM 9K>12K
1.8 RENAULT ENGINE > 1.6 DOHC MITSUBISHI MIVEC FROM 8K> 9K
1.8 RENAULT ENGINE > 1.6 SOHC PROTON ENGINE RM 4K
1.8RENAULT ENGINE > 2.0 v6 QUAD CAM MITSUBISHI MIVEC RM 7K
1.8 RENAULT ENGINE > 2.0 DOHC TURBO FROM 9K > 14K
http://www.mudah.my/...rts-8409661.htm
limking
Posted 14 February 2011 - 12:08 AM
limking
  • 2,887 posts
smile_thumbup.gif smile_approve.gif smile_thumbup.gif Agreed but also can try using Lucas Stop Slip tranmission oil addictive for a try out .
vishant
Posted 27 February 2011 - 10:16 PM
vishant
    Driver
  • 37 posts
rain is this a secondhand car???
Vishant selvarajah
turnip
Posted 01 March 2011 - 09:44 AM
turnip
  • 165 posts
QUOTE (rain @ Jan 3 2011, 04:47 PM) <{POST_SNAPBACK}>
[b]Hey guys,
Senario
6) TCU...???
try cleaning the flywheel, happens to me before.Try sending to Renautech.Ask for Mr.William, he know his stuffs.My car now is there.Just revived it after so long didn't move. smile_tongue.gif
Waja 1.8X
arazakmy
Posted 06 March 2011 - 10:38 PM
arazakmy
  • 2,905 posts
QUOTE (turnip @ Mar 1 2011, 09:44 AM) <{POST_SNAPBACK}>
MY WAJA 1.8 STILL MOVING STRONG
