Kancil wheel alignment
Posted 09 May 2003 - 12:39 PM
only, not sure if there is anywhere cheaper
Posted 10 May 2003 - 01:31 PM
i mean, in total, it is rm200 for one camber alignment? like this i can
change 2 new tyres already!
Posted 10 May 2003 - 01:57 PM
http://www.autoworld...m/allposts.asp?
summary=1&Forum=ap309675587&access=1&status=1&subject=Chamber+screw%3F%
3F+usefull%3F%3F+useless%3F%3F
Posted 10 May 2003 - 02:30 PM
Sent my gf's kelisa to do alignment n balancing. However, the tyreman's
skill ma ma oni. So vibrate at around 80kmh up to 85kmh. Then okay and latr
vibrates frm 110kmh onwards. Have to look for a new tyreman.
Posted 12 May 2003 - 12:38 AM
speed up to 100kmh
anybody can help me in this?
Posted 12 May 2003 - 01:38 AM
are doing. Those that do don't teach the newbies. So you will get ppl doing
the balancing n alignment. Some just meddle a bit and then that's it. So
far i've patronize 5 tyremen. Oni 1 i'm sure is good and the other one ok
oni. The 3 are completely hopeless. Look for one that do alignment n
balancing (onwheel/offwheel) If they take a while longer i think they are
ok. Some just take 1/2 hour to do everything. Hahaha these ppl are jokers.
I dun think it will even be stable at 80kmh
Posted 12 May 2003 - 10:19 AM
so far i only done camber alignment for both of my front wheels only, and
i did it at different time n different mechanic to spread the cost, we
only need to do camber align on the wheels that is misaligned
i try to enter the forum u posted above but it says topic invalid
lately, my kancil front wheel has been emitting sound, it can heard when
the car is running at very low speed n when i turn the steering wheel, u
hv any clue?
Posted 12 May 2003 - 01:37 PM
No worries about reading the topic. you cna try to search in the tyres and
rims forum, i think it is on the second page.
as for the front wheel emitting soung in slow speed WHILE turning...i
think your drive shaft is starting to give you headache.
as long as the sound is not the tak tak tak sound, then i think your shaft
(eeek...no pun intended) is ok. if it is jsut humming sound, check your
air pressure.
Posted 12 May 2003 - 03:05 PM
absorber ready to go liao. Then if faster speed oso got absorber gone liao.
Posted 12 May 2003 - 03:58 PM
repair, i pump 200 for front n 180 for rear all these while, no sound, but
now it got, i scare its the wheel bearing as i havent change since i
bought the car, approaching 60k km already, i think its a bit early for
the shaft to kong, the absorber still stiff enuf to absorb spring
oscillation
the sound is also heard when i turn the steering wheel at low speed,
actually at high speed i think oso got sound one but maybe i din heard cos
the kancil engine n wind noise very loud
