It's the only new model in the D segment. I'm not sure what the sales figures are usually like for the Camry but I'd expect them to be shifting much more than that in their first month. Sales will only go down from here.
Toyota Camry 2012
#261
Posted 29 July 2012 - 08:22 PM
#262
Posted 25 March 2014 - 09:50 AM
And as when necessary, for overtaking for example, just floor the accelerator, down shift (1-2 gears) will take place for extra torque to pull the car quickly and safely. But in case of 6-7 gears transmission, the same driver action will cause the transmission to down shift through more gears (2-3 gears, for example), the end result will be the same acceleration times due to more time losses in gear changes.
#263
Posted 25 March 2014 - 02:03 PM
Aiyo... if that is so, why the trends is getting more gear? ZF already come out with 9 speed. Current 3 series is getting 8 speed tranny? And thereby claiming more fuel economy?
You just sound like the company man that saying esc is not really required therefore for the low end spec, no esc is equipped. But for high spec, it does. Again, if 4 speeds tranny is just good enough, why you put a 6 speeds tranny on the 2.5 model while previously 2.4 also 4 speeds box too?
#264
Posted 25 March 2014 - 02:41 PM
that's becuase of marketing. people more and more want new tech so call. The 4AT in Camry is nicer to drive than the Accord 5AT seriously. The Camry is so so quiet where the new Accord still lagging behind for NVH albeit much claim about improvement.
#265
Posted 25 March 2014 - 04:09 PM
For NVH, I totally agree..
#266
Posted 26 March 2014 - 08:39 AM
Generally speaking, what is important is the lowest gear for take-off and the tallest gear for fuel economy. In between, more gears give more option on the spread of gearing to match the power/torque map. But with so much electronics involved in controlling the engine operating parameters and variables, there are many ways to tweak and optimise the engine dynamics response without the need of having additional ratio.
Ultimately, the best is CVT with infinite number of gear ratios.. so in my opinion, 4AT or 5AT doesn't really make so much different....
#267
Posted 09 April 2014 - 04:44 PM
Bro elan,
Have you bought the Camry ? Thanks.
#268
Posted 29 April 2014 - 09:50 PM
Huhu.. yea, after some thoughtful considerations on some cars in the same segment....
#269
Posted 01 May 2014 - 09:15 PM
Bro elan,
So you go with Camry 2.0 G ? Or the X version?
#270
Posted 18 August 2014 - 09:13 PM
