Any Owner Of Honda Elysion Here?
#641
Posted 30 April 2014 - 05:40 PM
#642
Posted 02 May 2014 - 05:32 PM
Hello mrorange70. Saya tukar absorber depan dan belakang pada masa yang sama selepas 3+ tahun. Saya tidak tahu absorber sudah tiba masa untuk diganti apabila tukar tayar. Selepas tukar tayar depan dan belakang, ada bunyi eek eek. kadang kadang bunyi krek krekk apabila lalu road hump / bump. Bila lalu road hump, rasa seperti terhempas dan bouncy toing toingg. Pada mulanya saya ingatkan tayar baru terlalu keras, tapi tayar pressure elok saja.
#643
Posted 06 May 2014 - 07:11 AM
I have PM you my contact.
Regards,
#644
Posted 14 May 2014 - 04:26 PM
I own Ely 3.0 2007 since more than a year ago. So far very satisfied with it, no regret.
But since mid last year i noticed that my engine is producing a slight vibration when the rpm reaches 2.5k and above. I can feel the vibration from the steering and sometimes on the floor as well.
Do you have experienced it before? What could be the possible cause? I think it could be related to the engine mountings but since this model has several of them, it would be hard to determine which one is spoilt. And the cost of them are quite expensive.
Thanks.
#645
Posted 14 May 2014 - 06:31 PM
Thanks.
Hi acermet,
I never had that kind of problem yet.
The 3.0 Ely uses two active engine mountings and I don't think they are the problem.
Maybe u can replace all the rubber bushes on each of the front lower arm. Replace also the front anti roll arm.
Regards,
#646
Posted 15 May 2014 - 02:36 PM
Can you pm me your recommended workshop since not all workshop have experience in fixing Ely
#647
Posted 16 May 2014 - 11:52 AM
Hi Acermet,
Just emailed you his contact and mine too.
Regards,
#648
Posted 31 July 2014 - 07:00 PM
Regards,
Hi bro Roselan,
Was wondering if you could also provide me the contact of a service workshop of the Elysion. Its really hard to come by a service centre for our kinda cars.
Am an owner of a 3.5 Elysion Prestige and am starting to see some age creeping up with it and hence, some parts such as absorbers and mounts needs replacement but unfortunately the Honda 3S centres don't really have the capacity to repair these cars. Hence, any good reputable mechanics or work shops would be much appreciated.
#649
Posted 08 August 2014 - 11:13 AM
Hi roulette23,
Sorry for the late reply. I have pm the foreman's number.
Regards,
#650
Posted 08 August 2014 - 11:44 PM
Regards,
Thanks, Roselan. Sure is appreciated for sharing your contact.
