light crank pulley for Waja?
nofear1979
Posted 25 March 2008 - 09:13 AM
nofear1979
    Hot Rod
  • PipPipPipPip
  • 14,648 posts
Hi,
i was thinking to change the original crank pulley to another light crank
pulley...
but i understand that this will wear out alot on the timing belt.. is it
true?
any other bad thing about changing it to light crank pulley?? mine are
waja 2005..
please advice..
drexchan
Posted 25 March 2008 - 10:48 PM
drexchan
    Hot Rod
  • PipPipPipPip
  • 14,758 posts
Why should it wear the timing belt faster? It's not even driving or being
driven by the timing belt.
Both crank timing gear and the crank pulley are driven directly by the
crankshaft.
Might sound bias but there's no other brand other than Mythelogy
Lightened Dampened Crank Pulley that i will recommend.
Posted 26 March 2008 - 12:16 AM
  • Staff
  • 16,953 posts
drex,
what makes the Mythelogy Crank Pulley better than other aftermarket crank
pulleys?
how much does the thing + installation cost?
I am considering one, but not so soon la.
drexchan
Posted 26 March 2008 - 12:47 AM
drexchan
    Hot Rod
  • PipPipPipPip
  • 14,758 posts
I am not expected to make a sales here but since you ask..
It's the only light weight pulley that comes with an elastomer insert as
vibration dampener (like our OEM pulley) and is within our budget.
Machined out from a homogeneous block of 6-series aluminum alloy billet.
Balancing checked or reject. Optimized weight reduction.
Dyno proven for improving engine efficiency. Without sacrifying charging
& a/c efficiency as the size is exactly same as OEM pulley.
nofear1979
Posted 26 March 2008 - 09:53 AM
nofear1979
    Hot Rod
  • PipPipPipPip
  • 14,648 posts
thank you very much for the infor..
actually the sales guy told me that the crank pulley might wear out the
timing belt.. a little bit.. i was confuse that day..
Hammercar
Posted 26 March 2008 - 12:02 PM
Hammercar
  • 144 posts
drex,
do you have dyno chart for campro enjine to share with us on the gain
you've mentioned?
drexchan
Posted 26 March 2008 - 12:03 PM
drexchan
    Hot Rod
  • PipPipPipPip
  • 14,758 posts
I think he means the auxilary belts. Not the timing belt.
Belt wearing also depends on the machining quality and surface
preparation of the pulley. If the groove aren't out of shape or too sharp
and it's hard anodized, it should be just as good as steel pulley in term
of belt wearing.
maddriver
Posted 27 March 2008 - 08:19 AM
maddriver
  • 3,668 posts
i've been using the pulley mentioned by drex for quite some time
now.......not only do the revs climb faster, in some cases when i'm not
wacking the car, i actually save fuel too.......
Hammercar
Posted 27 March 2008 - 09:17 AM
Hammercar
  • 144 posts
drex,
do you have the dyno chart for campro engine? maybe from your customer?
do you have a distributor in penang? i know a lot of people in penang in
interested, but we can't drive to KL just to install the LCP.
maddriver
Posted 27 March 2008 - 04:01 PM
maddriver
  • 3,668 posts
we are using one of those pulleys in the comming malaysian rally
championships this weekend........... i'm quite sure postage can be
arranged.
