[official] Proton Exora Bold And Prime
#241
Posted 27 April 2012 - 04:58 PM
1st time, stop at traffic light in D. Car will not move when green. Restart the car, ok. The service centre change oil control value.
2nd time, drive from Klang to Malacca. During idling, the RPM drop and then go up to 1.5 then normal. Repeated for 5 times. The service centre do adaption.
3rd time, driving out from a junction, the engine just die. Restart the car,ok. The service centre delete error code. Say it confuse the ECU.
All this happen within 1 month of purchase. Even thought everyone got exited about the Preve in my office. No one dare to buy one now. 1 of them that is so eager to buy Preve, brought a vios instate. Maybe he did not enjoy the trip picking me up and sending me to proton.
#242
Posted 30 April 2012 - 10:14 AM
Problem found :- when I had my first service change my oil at 1,000 km at PROTON EDAR MUTIARA DAMANSARA
they didn't tightened the nut and it has been leaking for 1 month!
#243
Posted 30 April 2012 - 07:38 PM
wah... this kind of mistake also can ah??
nvr go that PESC again.. hihi
#244
Posted 01 May 2012 - 09:20 AM
Anyone of you having problem on EB driver seat?
My driver seat back can rock backward and forward everytime if I lean or un-lean on it. Did some checks and confirmed that the seat back will rock backward when force is exerted on it and it will rock forward when force is released. Though the movement is very small but it is very annoying especially during driving and breaking and I wonder it is safe.
The other matter is steering off centre. The steering is a bit to the right when holding it on straight road. It looks like when they did the alignment, they didn't lock the steering in centre position. Do you have this problem too?
I haven't sent to SC for checking but need some information from you on this matter.
#245
Posted 01 May 2012 - 07:27 PM
I do feel the slight rocking of the driver seat when you brake.
The engine RPM stays at 1 even when you stop at traffic lights.
The horn sounds like a ship
Remote control lock and unlock sounds are very soft. Sometimes you are not sure if you have locked the car or not.
High engine sound outside was expected. But it gets more louder when you switch your aircon on.
Anything I mention to my inexperienced SA . He says " the car comes like that "
I like
The space inside the car
Pick up in the low gears.
Sound system ( Good for the car price )
Stability of the car. Handling and braking has been good
Air con is good and i like the flow outlets for the 2 back row seats
So far I am satisfied with the buy. What happens in next few months and how the SC service my car?..Wait and see.
#246
Posted 01 May 2012 - 09:07 PM
yes, some is facing that problem as well. they said is seat frame problem.
#247
Posted 01 May 2012 - 09:10 PM
seat frame problem, can claim in PESC
Mine is less than 1, please check at PESC
cut cost, only 1 bm horn given. Normally it's come with a pair, but p1 giv 1 unit only.
recent proton using the same module.
aircond fan sound... have to live with it
I like
#248
Posted 01 May 2012 - 09:54 PM
How about air con? Do you happen to notice that the cooling is up and down? Leave your car in idle state, turn the fan to level 2, put your hand in front of the air outlet and feel the cool air coming out from there. Do you see the cooling is kind of up and down? I notice, the cooling somehow correlated to the engine. If you observe carefully, the cooling power drops when the engine/fan run "slower/quieter" and increases when the engine/fan run "faster/louder". I wonder this is related to the alternator.
Also do you notice the dashboard light will suddenly turn dimmer at the interval where the engine/fan switch from slower/quieter" to faster/louder" and vice versa.
#249
Posted 02 May 2012 - 10:24 AM
Hi CKL,
Yes, I have the same experience as you had. Light dimmed little bit then back to normal when engine fan is turned on. This is probably because of change of load on the electrical circuit. I guess the circuit designer didn't put enough capacitors to handle such sudden change of load. But can live with that.
I also noticed the same thing with the aircond, that it oscillates. For me, it is only obvious when the weather is hot, and my air cond temperature knob is turned only 1 tick above 0 (means not cool). Apart from that, not obvious. So I workaround it by always having the temperature knob at least 2 ticks above 0.
My left rear brake light also dimmer than the right rear brake light. SC ordered a new one for me, still waiting.
And I have the most dreaded 1-way-valve problem. Scheduled an appointment with Penang Juru SC next week to get it fixed, was told need to put my car there for at least 3 days.
As I had my exora bold for longer period of time, more negative stuffs pop up . But still ok for an 80K car, particularly the pickup power and ample passenger space.
#250
Posted 02 May 2012 - 11:31 AM
Initially I thought the sound was from motorcycles or other vehicles but I realised sometimes there were no vehicles around.
Does anyone have this problem?
