Problem with Vios auto transmission
Posted 02 November 2006 - 02:57 PM
I better fu*ck myself with metal pipe lorr..
Ma*Chee*Bye !!
Posted 02 November 2006 - 03:20 PM
Posted 02 November 2006 - 08:23 PM
running, u kenot shift
from P to R w/o pressing
d shift lock button
if d car's engine is
running, then u can shift
d shift lock button but
u hv to step on d brake
pedal
Not true. Please refer to page 75 of the Vios Owners Manual
Posted 03 November 2006 - 10:52 AM
recommend me verify from UMW service centre if i can push the gear lever
of my car from P to R wihout depressing the shift lock.'
are you saying that every time u reverse your vios you have to press down
the shift lock? then i guess you are the one who need UMW service.. LOL
Posted 03 November 2006 - 11:10 AM
Vios is one of the cars I am currently having and the need to depress the
shift lock button to engage R from P, with the brake pedal depressed, is
there all the time since the car was delivered, and the same for the
Camry I had previously.
This is also consistent with what the owner's manual has clearly spelt
out.
Posted 03 November 2006 - 11:18 AM
one too. im not so sure with your vios but if you think you are right
then youre right!! cheers
Posted 03 November 2006 - 11:27 AM
Not trying to engage in any one-upmanship here. Just sharing what I know,
that's all. Please dont take any offence.
I am certain I am right because the car's transmission shifting is
functioning exactly according to what is stated in the manual, and I make
it a point to read and understand the manual each time I take delivery of
a particular car.
Posted 03 November 2006 - 01:02 PM
n tpl
i know where v r
heading here LOL
there seems to b a
misunderstanding /
misinterpretation here
from wat sps mentioned:
i can sum dat he is
refering to d button
on d shifter as d `shift
lock button`
if so, then yes, u hv
to depress d button b4
u can shift from P to R
but wat tpl n I was
championing is d little
black button on on d
upper left of d shifter
base plate (hope u guys
can imagine dat)
so, its a whole lot of
confusion here
hope d sky is clear now
p.s. i dun drive vios
btw, wats d API out there
Posted 03 November 2006 - 01:06 PM
push, when car not running, with ignition key turned on position (without
twisting into starter mode)...can shift or not?
cefiro also got this button, but never tried to shift before starting...
BBA,
kenot
